Hi, i ran the sample application as the user guide told with the command
“deepstream-app -c samples/configs/deepstream-app/source30_720p_dec_infer-resnet_tiled_display_int8.txt”.
But i got failed and the error is only about:
** ERROR: main:490: Failed to set pipeline to PAUSED
Quitting
App run failed
I have followed the instructions to install all the prerequisites, as well as DeepStream SDK 2.0.
I don’t know how to solve it? Please help me, thanks.
Hi dbangfa:
If the application runs into errors, cannot create gst elements, try again
after removing gstreamer cache rm $(HOME)/.cache/gstreamer-1.0/
registry.x86_64.bin
wayne zhu
It also doesn’t work. Any other solution to deal with it?
Hi Suixiaodan,
From this, I can’t get conclusion.
Make sure:
- don’t use other vendor’s graphic card for display
- Make sure driver version is same as our document.
wayne zhu
