I could not find neither nvidia-smi.exe file nor C:\Program Files\NVIDIA Corporation\NVSMI folder in my lenovo thinkpad E470 laptop with windows 10 OS, NVIDIA Geforce 940MX GPU.
I have installed
- Visual Studio Community 2015 with Update 3
- CUDA 8.0
nvcc --version output is
Copyright (c) 2005-2016 NVIDIA Corporation
Built on Mon_Jan__9_17:32:33_CST_2017
Cuda compilation tools, release 8.0, V8.0.60
gcc --version output is
gcc.exe (GCC) 4.7.0 20111220 (experimental)
when I run deviceQuery.exe, I am getting output as below
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 38
→ no CUDA-capable device is detected
Result = FAIL
whenever I want to import keras, I get warning as below
“WARNING (theano.sandbox.cuda): The cuda backend is deprecated and will be removed in the next release (v0.10). Please switch to the gpuarray backend. You can get more information about how to switch at this URL:
Converting to the new gpu back end(gpuarray) · Theano/Theano Wiki · GitHub
WARNING (theano.sandbox.cuda): CUDA is installed, but device gpu is not available (error: Unable to get the number of gpus available: no CUDA-capable device is detected)
Using Theano backend.”
Sometimes gpu works and sometimes does not work after some minutes(installing cuda again and running oceanfft.exe). I am getting frustrated for the cuda set up properly. Please help me to resolve the issue.
