I’m running on Windows Vista 32-bit, and on my DirectX Diagnostic test it says that my GPU is GeForce 8400M GT (http://www.nvidia.com/object/geforce_8400M.html). It says that it’s one of the device that is CUDA-enabled product (http://www.nvidia.com/object/cuda_learn_products.html). I installed everything, and I tried to run the sample.cu from the CUDA wizard on Visual Studio C++ Express 2005 (http://forums.nvidia.com/index.php?showtopic=80572). I copied the cutil32D.dll, and I run it in the Debug mode. Here’s what I got:
There is no device.
Press any key to continue . . .
Any ideas? Thanks a lot!
Sibi_A
#2
May be a problem with the driver.
Ensure that you have followed all the steps given below
1 -> http://www.nvidia.com/object/cuda_get.html
2 -> download latest driver for your OS.
3 -> download toolkit for you OS.
4 -> download SDK for you OS.
5 -> Install Driver
6 -> Install toolkit
7 -> Install SDK.
Now go to SDK folder -> browse to “bin\win32\Release”
Run the following -> deviceQuery.exe
Check the output, it should be “There is 1 device supporting CUDA”
~Sibi
I tried to run the deviceQuery.exe
it says:
There’s no device supporting CUDA
Test PASSED
Press ENTER to exit…
tmurray
#4
did you install a newer driver?
Sibi_A
#5
You may copy paste the driver details from the nVidia control panel here.
Such as the forceware driver version.
