I tried now flashing to the NVMe drive (2T) installed on the device.
Seems the flashing progress went to 95 percent but failed. I note the first error which looks like it could be a bug in the install script?
15:44:59 ERROR: File System and OS - target_image: /var/lib/dpkg/info/nvidia-l4t-init.postinst: line 54: cannot create temp file for here-document: No such file or directory
Thanks. Here’s current status:
I downgraded my host to ubuntu 20.04.
Reinstall SDP 6.0
was able to flash and install SDK components.
(Seems like a lot of problems with host running 22.04…)
Device boots - I can ssh into it. But no HDMI output. Screen gets no signal.
What to do for that?
This has been a 3 day project…getting this to work! Shouldn’t be so hard.
When you mentions HDMI, it means it’s not a DevKit, but some custom carrier board from our third-party vendors. We only supports DP output on Orin Nano DevKit.
You cannot use SDK Manager to flash such boards, and please ask the vendor for the right BSP.
Adapters mostly won’t work.
You need an active DP-HDMI cable that has a chip inside in charge of converting the signal format, or use a DP-DP cable instead.
