I have this code, basiclly the example NVIDIA provides for using shared memory. I am using this to compute multiplication of a vector by a matrix of size 1K * (1K*2K) and larger. The problem is that it’s faster than CUBLAS functions cublasSgemm or cublasSgemv. Shouldn’t CUBLAS be faster? Here is the time for the mentioned size:
GPU time: 60 us
GPU time (CUBLAS): 450 us
(the time is only for computation, not communication)
Kernel Code:
#ifndef _MATRIXMUL_KERNEL_H_
#define _MATRIXMUL_KERNEL_H_
#include <stdio.h>
#include "matrixMul.h"
#define CHECK_BANK_CONFLICTS 0
#if CHECK_BANK_CONFLICTS
#define AS(i) cutilBankChecker(((float*)&As[0]), j)
#define BS(i, j) cutilBankChecker(((float*)&Bs[0][0]), (BLOCK_SIZE * i + j))
#else
#define AS(i) As[i]
#define BS(i, j) Bs[i][j]
#endif
//! Matrix multiplication on the device: C = A * B
//! wA is A's width and wB is B's width
__global__ void
matrixMul( float* C, float* A, float* B, int wA, int wB)
// Block index
int bx = blockIdx.x;
int by = blockIdx.y;
// Thread index
int tx = threadIdx.x;
int ty = threadIdx.y;
// Index of the first sub-matrix of A processed by the block
int aBegin = wA * BLOCK_SIZE * by;
// Index of the last sub-matrix of A processed by the block
int aEnd = aBegin + wA - 1;
// Step size used to iterate through the sub-matrices of A
int aStep = BLOCK_SIZE;
// Index of the first sub-matrix of B processed by the block
int bBegin = BLOCK_SIZE * bx;
int bEnd = bBegin + wB - 1;
// Step size used to iterate through the sub-matrices of B
int bStep = BLOCK_SIZE * wB;
// Csub is used to store the element of the block sub-matrix
// that is computed by the thread
float Csub = 0;
// Loop over all the sub-matrices of A and B
// required to compute the block sub-matrix
for (int a = aBegin, b = bBegin;
a <= aEnd;
a += aStep, b += bStep) {
// Declaration of the shared memory array As used to
// store the sub-matrix of A
__shared__ float As[BLOCK_SIZE];
// Declaration of the shared memory array Bs used to
// store the sub-matrix of B
__shared__ float Bs[BLOCK_SIZE][BLOCK_SIZE];
// Load the matrices from device memory
// to shared memory; each thread loads
// one element of each matrix
AS(tx) = A[a + tx];
BS(ty, tx) = B[b + wB * ty + tx];
// Synchronize to make sure the matrices are loaded
__syncthreads();
// Multiply the two matrices together;
// each thread computes one element
// of the block sub-matrix
for (int k = 0; k < BLOCK_SIZE; ++k)
Csub += AS(k) * BS(k, tx);
// Synchronize to make sure that the preceding
// computation is done before loading two new
// sub-matrices of A and B in the next iteration
__syncthreads();
// Write the block sub-matrix to device memory;
// each thread writes one element
int c = wB * BLOCK_SIZE * by + BLOCK_SIZE * bx;
C[c + wB * ty + tx] = Csub;
#endif // #ifndef _MATRIXMUL_KERNEL_H_
The way I call the kernel: (WA & WB are width of the vectore and width of the matrix respectively.)
timer = 0;
cutilCheckError(cutCreateTimer(&timer));
cutilCheckError(cutStartTimer(timer));
// setup execution parameters
dim3 threads(BLOCK_SIZE, BLOCK_SIZE);
dim3 grid(WC / threads.x, 1);
// execute the kernel
matrixMul<<< grid, threads >>>(d_C, d_A, d_B, WA, WB);
// check if kernel execution generated and error
cutilCheckMsg("Kernel execution failed");
// stop and destroy timer
cutilCheckError(cutStopTimer(timer));
printf("Processing time: %f (ms) \n", cutGetTimerValue(timer));
cutilCheckError(cutDeleteTimer(timer));
For CUBLAS, the code is similar to simpleCUBLAS example in SDK.
Thanks,
- eka
