I have modified an example code that was provided with the tools required to compile cuda programs. I’ll admit that I am new and have much to learn, but I have been fixing errors for weeks and here is one that I seem to not be able to get rid of:
LINK : fatal error LNK1104: cannot open file ‘.\Debug\matrixMul_gold.obj’
here is the code that I modified please help.
// Utilities and system includes
#include <shrUtils.h>
#include <shrQATest.h>
#include "cutil_inline.h"
#include "matrixMul.h"
// includes, kernels
#include "matrixMul_kernel.cu"
static char *sSDKsample = "matrixMul";
// declaration, forward
void runTest(int argc, char** argv);
void randomInit(float*, int);
void printDiff(float*, float*, int, int, int, float);
//extern "C" // to execute in cpu
//void computeGold(float*, const float*, const float*, unsigned int, unsigned int, unsigned int);
// Program main
int main(int argc, char**argv)
shrQAStart(argc, argv);
printf("[ %s ]\n", sSDKsample);
//shrSetLogFileName ("matrixMul.txt");
shrLog("%s Starting (CUDA tests)...\n\n", argv[0]);
runTest(argc, argv);
//! Run a simple test for CUDA
if(shrCheckCmdLineFlag(argc, (const char**)argv, "device"))
cutilDeviceInit(argc, argv);
else
cutilSafeCall( cudaSetDevice(cutGetMaxGflopsDeviceId()) );
int devID;
cudaDeviceProp props; // device information
// get number of SMs on this GPU
cutilSafeCall(cudaGetDevice(&devID)); // device information
cutilSafeCall(cudaGetDeviceProperties(&props, devID)); // device information
// use a larger block size for Fermi and above
int block_size = (props.major < 2) ? 16 : 32;
printf("Device %d:
#include “cutil_inline.h”
#include “matrixMul.h”
#include “matrixMul_kernel.cu”
static char *sSDKsample = “matrixMul”;
//extern “C” // to execute in cpu
// Program main
printf(“[ %s ]\n”, sSDKsample);
if(shrCheckCmdLineFlag(argc, (const char**)argv, “device”))
else
int devID;
printf("Device %d: \"%s\" with Compute %d.%d capability\n", devID, props.name, props.major, props.minor);
// set seed for rand()
srand(2006);
// Optional Command-line multiplier for matrix sizes
unsigned int uiWA, uiHA, uiWB, uiHB, uiWC, uiHC;
int iSizeMultiple = 5;
shrGetCmdLineArgumenti(argc, (const char**)argv, "sizemult", &iSizeMultiple);
iSizeMultiple = CLAMP(iSizeMultiple, 1, 10);
// For GPUs with fewer # of SM's, we limit the maximum size of the matrix
if (props.multiProcessorCount <= 4) {
uiWA = 2 * block_size * iSizeMultiple;
uiHA = 4 * block_size * iSizeMultiple;
uiWB = 2 * block_size * iSizeMultiple;
uiHB = 4 * block_size * iSizeMultiple;
uiWC = 2 * block_size * iSizeMultiple;
uiHC = 4 * block_size * iSizeMultiple;
} else {
uiWA = WA * iSizeMultiple;
uiHA = HA * iSizeMultiple;
uiWB = WB * iSizeMultiple;
uiHB = HB * iSizeMultiple;
uiWC = WC * iSizeMultiple;
uiHC = HC * iSizeMultiple;
shrLog("\nUsing Matrix Sizes: A(%u x %u), B(%u x %u), C(%u x %u)\n\n",
uiWA, uiHA, uiWB, uiHB, uiWC, uiHC);
// allocate host memory for matrices A and B
unsigned int size_A = uiWA * uiHA;
unsigned int mem_size_A = sizeof(float) * size_A;
float* h_A = (float*)malloc(mem_size_A);
unsigned int size_B = uiWB * uiHB;
unsigned int mem_size_B = sizeof(float) * size_B;
float* h_B = (float*)malloc(mem_size_B);
// initialize host memory
randomInit(h_A, size_A);
randomInit(h_B, size_B);
// allocate device memory
float* d_A, *d_B, *d_C;
unsigned int size_C = uiWC * uiHC;
unsigned int mem_size_C = sizeof(float) * size_C;
// allocate host memory for the result
float* h_C = (float*) malloc(mem_size_C);
cutilSafeCall(cudaMalloc((void**) &d_A, mem_size_A));
cutilSafeCall(cudaMalloc((void**) &d_B, mem_size_B));
// copy host memory to device
cutilSafeCall(cudaMemcpy(d_A, h_A, mem_size_A, cudaMemcpyHostToDevice) );
cutilSafeCall(cudaMemcpy(d_B, h_B, mem_size_B, cudaMemcpyHostToDevice) );
cutilSafeCall(cudaMalloc((void**) &d_C, mem_size_C));
// setup execution parameters
dim3 threads(block_size, block_size);
dim3 grid(uiWC / threads.x, uiHC / threads.y);
//create and start timer
unsigned int timer_matrixMul = 0;
// execute the kernel
int nIter = 30;
//normal CUDA method
// For the case where "-cublas" is not specified, we will run the matrixMul kernel
//Performs warmup operation using matrixMul CUDA kernel
if (block_size == 16) {
matrixMul<16><<< grid, threads >>>(d_C, d_A, d_B, uiWA, uiWB);
} else {
matrixMul<32><<< grid, threads >>>(d_C, d_A, d_B, uiWA, uiWB);
cutilDeviceSynchronize();
// Start Timing
cutilCheckError(cutCreateTimer(&timer_matrixMul));
cutilCheckError(cutStartTimer(timer_matrixMul));
for (int j = 0; j < nIter; j++) {
} else {
// check if kernel execution generated and error
cutilCheckMsg("CUDA matrixMul Kernel execution failed");
// stop and destroy timer
cutilCheckError(cutStopTimer(timer_matrixMul));
double dSeconds = cutGetTimerValue(timer_matrixMul)/((double)nIter * 1000.0);
double dNumOps = 2.0 * (double)uiWA * (double)uiHA * (double)uiWB;
double gflops = 1.0e-9 * dNumOps/dSeconds; // converts to gflops
//Log througput, etc
shrLogEx(LOGBOTH | MASTER, 0, "> CUDA matrixMul Throughput = %.4f GFlop/s, Time = %.5f s, Size = %.0f Ops, ",
gflops, dSeconds, dNumOps);
shrLogEx(LOGBOTH | MASTER, 0, "NumDevsUsed = %d, Workgroup = %u\n", 1, threads.x * threads.y);
cutilCheckError(cutDeleteTimer(timer_matrixMul));
// copy result from device to host
cutilSafeCall(cudaMemcpy(h_C, d_C, mem_size_C, cudaMemcpyDeviceToHost) );
// compute reference solution
shrLog("\nComparing GPU results with Host computation...\n\n");
float* reference = (float*)malloc(mem_size_C);
computeGold(reference, h_A, h_B, uiHA, uiWA, uiWB);
// check result (matrixMul) and compare them
printf("Comparing CUDA matrixMul & Host results\n");
shrBOOL resCUDA = shrCompareL2fe(reference, h_C, size_C, 1.0e-6f);
if (resCUDA != shrTRUE)
printDiff(reference, h_C, uiWC, uiHC, 100, 1.0e-5f);
shrLog("CUDA matrixMul compares %s\n\n", (shrTRUE == resCUDA) ? "OK" : "FAIL");
// clean up memory
free(h_A);
free(h_B);
free(h_C);
free(reference);
cutilSafeCall(cudaFree(d_A));
cutilSafeCall(cudaFree(d_B));
cutilSafeCall(cudaFree(d_C));
cutilDeviceReset();
shrQAFinishExit(argc, (const char **)argv, (resCUDA == shrTRUE) ? QA_PASSED : QA_FAILED);
// Allocates a matrix with random float entries.
void randomInit(float* data, int size)
for (int i = 0; i < size; ++i)
data[i] = rand() / (float)RAND_MAX;
void printDiff(float *data1, float *data2, int width, int height, int iListLength, float fListTol)
shrLog(“Listing first %d Differences > %.6f…\n”, iListLength, fListTol);
int i,j,k;
int error_count=0;
for (j = 0; j < height; j++)
if (error_count < iListLength)
shrLog(“\n Row %d:\n”, j);
for (i = 0; i < width; i++)
k = j * width + i;
float fDiff = fabs(data1[k] - data2[k]);
if (fDiff > fListTol)
shrLog(" Loc(%d,%d)\tCPU=%.5f\tGPU=%.5f\tDiff=%.6f\n", i, j, data1[k], data2[k], fDiff);
error_count++;
shrLog(" \n Total Errors = %d\n\n", error_count);
quot;%s
// Program main
else
int devID;
srand(2006);
} else {
int nIter = 30;
} else {
// Start Timing
} else {
// clean up memory
free(h_A);
free(h_B);
free(h_C);
free(reference);
cutilDeviceReset();
int i,j,k;
int error_count=0;
k = j * width + i;
error_count++;
quot; with Compute %d.%d capability\n", devID, props.name, props.major, props.minor);
srand(2006);
} else {
int nIter = 30;
} else {
// Start Timing
} else {
// clean up memory
free(h_A);
free(h_B);
free(h_C);
free(reference);
cutilDeviceReset();
shrLog("Listing first %d Differences > %.6f...\n", iListLength, fListTol);
int i,j,k;
int error_count=0;
shrLog("\n Row %d:\n", j);
k = j * width + i;
error_count++;
