fatal error with cutil.lib
I am trying to compile a cuda program and got the following error:
fatal error LNK1181: cannot open input file ‘cutil.lib’
How can I resolve it?
Thanks,
you need to provide library path for cutil.lib, for example, I install SDK 2.3 in winxp pro x64, then cutil64.lib (64-bit) locates
at directory C:\Documents and Settings\All Users\Application Data\NVIDIA Corporation\NVIDIA CUDA SDK\C\common\lib.
You can use absolute path instead, say set library as
C:\Documents and Settings\All Users\Application Data\NVIDIA Corporation\NVIDIA CUDA SDK\C\common\lib\cutil64.lib
in project setting if you use Visual studio.
remember to add
to enviroment variable PATH, or you will have run-time error since cutil.dll is not found.
