__fAtomicAdd Error unsupported operation
Hi:
I have a Qosmio with a GeForce Gtx 560m. I installed a “pure” (without multilib support) amd64 gentoo and had success installing and compiling nvidia sdk 4.1rc.
The problem I have, is that when i compile with nvcc -arch=sm_20, it says:
/usr/local/cuda/bin/…/include/sm_20_atomic_functions.h(79) Error: unsupported operation
The only function in that file is a float atomic add, which calls __fAtomicAdd. I then change in my .cu file atomicAdd by __fAtomicAdd (i thought that maybe it didn’t enter because the ifdef’s), but now it marks my .cu file, and gets the same error.
I tried:
grep “fAtomicaAdd” *.h /usr/local/cuda/include
and get:
sm_20_atomic_functions.h:extern device device_builtin float __fAtomicAdd(float *address, float val);
sm_20_atomic_functions.h: return __fAtomicAdd(address, val);
(that makes me think it’s not define anywhere, but maybe because is “device_builtin”, maybe it doesn’t need).
I use the function for a global float atomic add. I have already compiled the same file in another linux system (gentoo amd64 without multilib support) with cuda 4.0.
I have gcc version 4.5.3.
Any suggestion, please? Thanks for your time.
Yours:
Luis Ernesto.
