The method atomicAdd could not pass the compile
the method is used in the global method.
my cuda’s version is cuda11.6,and my ide is VS2022,
the command line is
(Approximate command-line. Settings inherited from host are not visible below.)
(Please see the output window after a build for the full command-line)
Driver API (NVCC Compilation Type is .cubin, .gpu, or .ptx)
set CUDAFE_FLAGS=–sdk_dir "C:\Program Files (x86)\Windows Kits\10"
“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.6\bin\nvcc.exe” --use-local-env -ccbin “C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.35.32215\bin\HostX64\x64” -x cu -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -o x64\Debug%(Filename)%(Extension).obj “%(FullPath)”
Runtime API (NVCC Compilation Type is hybrid object or .c file)
“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.6\bin\nvcc.exe” --use-local-env -ccbin “C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.35.32215\bin\HostX64\x64” -x cu -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -Xcompiler "/EHsc /nologo /FS /Zi " -o x64\Debug%(Filename)%(Extension).obj “%(FullPath)”
What is the error message?
You are compiling for the default architecture, which would be sm_52 in this case. There are various flavors of atomicAdd that won’t be useable with that setting, such as double. Otherwise, as already indicated, more info is needed, such as the code and the error.
