FDT parameter doesn't has effect in extlinux.conf
Hi NVIDIA experts
I have a look the extlinux.conf file, and below code
FDT /boot/dtb/tegra234-p3737-0000+p3701-0005-nv.dtb
But when system boots up, it still get dtb from configuration table
EFI stub: Using DTB from configuration table
Could you please explain why the FDT parameter doesn’t has effect in extlinux.conf??
thanks,
Limeng
Hello @meng.li
Do you have the nvidia-l4t-bootloader dependency package in your Jetson?
If not, please install it and retry to see if the FDT parameter takes effect.
I hope this helps!
Regards!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
