I have a Xavier NX setup to boot from NVME with Jetpack 5.0.2. It is flashed using this command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1 -c ./tools/kernel_flash/flash_l4t_nvme.xml -S 30GiB --showlogs jetson-xavier-nx-devkit-emmc nvme0n1p1
It works fine and the device tree changes I have made can be found in /proc/device-tree
. The problem is that I would like to set the device tree using the FDT option in the file /boot/extlinux/extlinux.conf
. however no changes made here seem to do anything.
Here is the content of the file:
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
FDT /boot/dtb/kernel_tegra194-p3668-0001-p3509-0000.dtb
INITRD /boot/initrd
APPEND ${cbootargs} root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
I have also tried to replace the file in /boot/dtb
without changing the name, and it also has no impact.
This is annoying to me because I would like to be able to boot from NVME, and modify the device tree without having to flash the jetson.
Any help appreciated.
