I’m trying to boot a Xavier NX from an NVME drive with a custom kernel, and device tree. Everything works fine when booting from EMMC memory, however when using ./tools/kernel_flash/l4t_initrd_flash.sh
to flash the jetson, I am not able to flash update just the DTB partition. I would like a simple way to update the device tree only so that our workflow for developing the device tree and kernel modules is similar to using the usual flash.sh
tool where we can update just the device tree with sudo ./flash.sh -r -k kernel-dtb -d kernel/dtb/tegra194-p3668-all-p3509-0000.dtb jetson-xavier-nx-devkit-emmc mmcblk0p1
I’ve tried using dd
to copy the file bootloader/kernel_tegra194-p3668-0000-p3509-0000.dtb.sb
into the partition which the device tree is in, but not had much success. I’ve also tried using the FDT
flag in the /boot/extlinux/extlinux.conf
file but also not succeeded.
If anyone could share a simple workflow with some steps for updating only the Device Tree partition on a device booting from NVME that would be appreciated.
