• Hardware Platform: Jetson Orin NX 16Gb
• DeepStream Version: 7.x
• JetPack Version 6.2.x
• TensorRT Version: 10.x
• Issue Type: Feature Request
• Requirement details: nvtracker
Hi DeepStream team,
I’m looking for guidance on building a DeepStream pipeline that supports a “track anything” mode — i.e., the ability to start tracking from a user-selected ROI (or a fixed 100×100 box in the center) even when the target is not part of my trained PGIE classes. I’ve seen this concept referred to as TAM (Track Anything Model).
I will still run PGIE via nvinfer for normal detections, but my application also requires the ability to manually initiate nvtracker / NVDCF.
There are cases where:
- The object is unique / not worth training a class for
- Or it cannot be reliably classified (insufficient stable features)
- But it is trackable via appearance/motion once initialized
Goal
Keep the pipeline GPU / zero-copy and avoid CPU-based OpenCV trackers (CSRT/KCF/MOSSE), since those don’t integrate as cleanly and typically break zero-copy flow.
What I’m trying to do
Inject artificial detections (object metadata) upstream of nvtracker so NVDCF starts tracking a manually provided ROI/bbox
Configure long track persistence (shadow tracking / timeout) so a manually seeded track can survive brief occlusions or detection gaps
Questions
- Is there a supported way to initialize NVDCF tracking from a manual ROI without a PGIE detection?
- If not, is it possible to inject an object as NvDsObjectMeta (or equivalent) before nvtracker (pad probe or custom plugin)?
- What metadata fields are required for NVDCF to accept the injected bbox and assign/maintain a track?
- Which tracker config parameters control shadow age / termination / timeout, and how should they be set for a long-lived manually initiated track?
Thanks in advance, looking over the forum, I can see that there are multiple people asking similar questions and looking for this functionality. Any pointers to sample code, recommended approach, or relevant docs would be very helpful.
