Please guide me how to build ffmpeg on windows.
My objective is use scale_npp filter. I can use nvenc_h264 and nvenc_hevc on basic ffmpeg build,but in basic ffmpeg build scale_npp support is not.
I followed NVIDIA reference document. I used cuda 10.0 version for windows 10. and 4.2.1 ffmpeg version. visual studio 14.0 .
If I run this configure:
./configure --enable-nonfree --enable-shared --enable-cuda-nvcc --enable-libnpp --toolchain=msvc --extra-cflags=-I/c:/ffmpeg-4.2/nv_sdk --extra-ldflags=-libpath:c:/ffmpeg-4.2/nv_sdk --disable-static --prefix=/c/ffmpeg-4.2/DLLS
It works fine. but when I Add
./configure --enable-cuda --enable-cuvid --enable-nvenc --enable-nonfree --enable-libnpp --toolchain=msvc --extra-cflags=-I/c:/ffmpeg-4.2/nv_sdk --extra-ldflags=-libpath:c:/ffmpeg-4.2/nv_sdk --disable-static --prefix=/c/ffmpeg-4.2/DLLS
I faced ERROR: cuvid requested, but not all dependencies are satisfied: ffnvcodec.
Lots of document says problem is due to pkg-config path but they not explain properly.
I set path before ./configure like,
PKG_CONFIG_PATH="/usr/lib/pkgconfig" ./configure
but no luck.
My full PKG_CONFIG_PATH is C:\DEV\msys64\usr\lib\pkgconfig, in which my ffnvcodec.pc file is available.
Please help.
