I’m trying to port some code to CUDA but ran into a problem with using the cuFFT tool. I’ve managed to reproduce the error in the following code:
#define _USE_MATH_DEFINES 1
#include <math.h>
#include
#include <time.h>
#include
using namespace std;
#include <cuda_runtime.h>
#include <cufft.h>
global void mean();
int main(int argc, char* argv)
int n = 64;
int size = n*n;
int ret = 0;
cufftHandle plan;
cufftComplex *idata, *odata, host_array;
for (int counter =0; counter < size; counter++)
host_array[counter].x = counter;
host_array[counter].y = counter*counter;
ret = cudaMalloc((void**)&idata, sizeof(cufftComplex)*size);
ret = cudaMalloc((void**)&odata, sizeof(cufftComplex)*size);
mean <<<1, n*n>>> ();
/* Create a 2D FFT plan. */
ret = cufftPlan2d(&plan, n, n, CUFFT_C2C);
ret = cudaMemcpy(idata, host_array, sizeof(cufftComplex)*size, cudaMemcpyHostToDevice);
/* Use the CUFFT plan to transform the signal out of place. */
ret = cufftExecC2C(plan, idata, odata, CUFFT_FORWARD);
/* Note: idata != odata indicates an out-of-place transformation
to CUFFT at execution time. */
ret = cudaMemcpy(host_array, odata, sizeof(cufftComplex)*size, cudaMemcpyDeviceToHost);
/* Inverse transform the signal in place */
ret = cufftExecC2C(plan, odata, odata, CUFFT_INVERSE);
/* Destroy the CUFFT plan. */
ret = cufftDestroy(plan);
cudaFree(idata); cudaFree(odata);
return 0;
global void mean()
I’m running Ubuntu 9.10 with a GeForce 210 installed.
user@computer:~/Documents/cudadev$ uname -a
Linux 2.6.31-22-generic #65-Ubuntu SMP Thu Sep 16 16:21:34 UTC 2010 x86_64 GNU/Linux
user@computer:~/Documents/cudadev$ nvcc --version
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2010 NVIDIA Corporation
Built on Tue_Apr_27_19:18:26_PDT_2010
Cuda compilation tools, release 3.1, V0.2.1221
user@computer:~/Documents/cudadev$ nvcc testfft.cu -lcufft
user@computer:~/Documents/cudadev$ ./a.out
cutilCheckMsg() CUTIL CUDA error: spRadix0064B_kernel<FFT_FORWARD>(main) execution failed
in file </home/buildmeister/build/rel/gpgpu/toolkit/r3.1/cufft/src/accel/interface/spRadix0064B.cu>, line 35 : invalid configuration argument.
Another thread about a similar error mentions data alignment. However, if I remove the mean<<<>>>(), everything runs just fine (with all return values = 0)…
