Filesink deepstream sample apps on Jetson Orin Nano
• Hardware Platform (Jetson / GPU) Jetson Orin Nano
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.2
• TensorRT Version
I am using sample deeptream app to save the output video using filesink
Here is the config
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink/nv3dsink(Jetson only) 3=File 4=RTSPStreaming 5=nvdrmvideosink
type=2
sync=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=2
#1=h264 2=h265 3=mpeg4
codec=1
encoder type 0=Hardware 1=Software
enc-type=1
sync=0
bitrate=4000000
profile=2
output-file=out.mp4
source-id=0
Since i read on this that orin doesn’t support HW encoding Gstreamer Nvv4l2h264enc: Cannot identify device '/dev/v4l2-nvenc' - #3 by DaneLLL
Using software encoding give me this
**PERF:  FPS 0 (Avg)
**PERF:  0.00 (0.00)
** INFO: <bus_callback:239>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 279
NvMMLiteBlockCreate : Block : BlockType = 279
** INFO: <bus_callback:225>: Pipeline running
gstnvtracker: Unable to acquire a user meta buffer. Try increasing user-meta-pool-size
Could you add GST_DEBUG=3 to run the deepstream-app demo to open more log?
