I’m trying to use the Flex library (The Nvidia one not the bison/lex/flexx/yacc one) I’m just trying the demo in the documentation and I keep getting told that NULL does not exist. Is there some lib that defines this or perhaps is there a standard definition that Nvidia uses or the Cuda libraries define for this ?
I’m afraid I’m originally from a Matlab/python background and have not had much opportunity to fiddle with C and it’s relations, though I’ve read up somewhat.
If it helps any I’ve done the following :
Create a new blank/empty project solution in MS visual studio.
Point it towards the flex library and compiled.
If I must pass the example code from the manual or provide a ZIP or something please let me know.
Next go to the linker, Linker>Input, and include ‘flexDebug_64.dll’ or ‘flexRelease_64.dll’ under Additional Dependencies. Also under Additional Library Directories include a link to …\flex\lib.
It seems you also have to change the setting Build>Configuration Manager to allow for 64 bit. Create this under active solution platforms.
Finally copy the FlexRelease/Debug dll to …{PROJECT}\x64\Debug. I suspect there will be a similarly named folder for releasess.
The code still requires two modifications. The example in the document refers to two variables that are not defined the first is called finished, a bool that needs to be specified the second is a timer provided by the flex library. In version 0.8 one could supposedly set this timer to NULL, in version 0.9 VS is happy if you simply use a flextimer reference. The modified code is given below.
#include <flex.h>
const int maxParticles = 65536;
const int maxDiffuse = 0;
int main(void)
flexInit();
FlexSolver* solver = flexCreateSolver(maxParticles, maxDiffuse);
bool finished = false;
FlexTimers timer;
while (!finished)
const float dt = 1.0f / 60.0f;
// tick solver with one sub-step
flexUpdateSolver(solver, dt, 1, &timer);
flexDestroySolver(solver);
flexShutdown();
return 0;
A further development. I tried compiling the FlexDemo on my machine. It howeevr keeps throwing an R6010 Error, abort() is called. Would any one have an idea why this might be ?
