Flash failure when flashing to multiple Jetson devices
I am trying to flash my custom BSP(based on Jetson Linux 35.5.0) to two identical custom boards(based on Xavier NX) at the same time by using the method in the developer guide:Flashing to Multiple Jetson Devices. Now assume that the name of my custom board is “custom_board”.
1.Run the following command:
sudo BOARDID=3668 FAB=301 BOARDSKU=0001 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --network usb0 -massflash 5 custom_board mmcblk0p1
2.Connect the two custom Jetson devices to the flashing hosts(Ubuntu18.04).
3.Ensure that the two custom devices have the identical hardware revision.
I have checked the /etc/nv_boot_control.conf on the two custom boards and they are completely identical:
TNSPEC 3668-301-0001-G.0-1-2-custom_board-
COMPATIBLE_SPEC 3668-301---1--custom_board-
TEGRA_LEGACY_UPDATE false
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x19
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
4.Place all of the connected Jetson devices into RCM mode.
5.Run the following command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --network usb0 --massflash 5
However, the two boards got stuck in the same error.
board1:
Waiting for target to boot-up...
Unknown device, absolute path in /dev/ or /sys expected.
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
mount: /mnt/proc: mount point does not exist.
Flash failure
Cleaning up...
board2:
Waiting for device to expose ssh ...Run command: flash on fc00:1:1:1::2
SSH ready
Flash failure
Cleaning up...
How can I solve this problem? Thanks very much.
Hi qian.yuan,
Have you tried using initrd to flash one board independantly?
Could you use --massflash 2 in your case?
Please also share the full flash log as file here for further check.
board 1 full flash log:
flash_1-10_0_20241101-161959.log (9.6 KB)
board 2 full flash log:
flash_1-1_1_20241101-161959.log (9.6 KB)
Yes, I have tried using initrd to flash one board independantly.
When I use this command, the board can be flashed successfully:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh custom_board mmcblk0p1
But when I use the following command, I encountered the same error:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --network usb0 --massflash 1
And this is the full flash log:
flash_1-10_0_20241104-143203.log (9.5 KB)
After using --massflash 2, I still encountered the same error.
Please share the full flash log when you use initrd script to flash the board successfully.
I would also like to check the log when you run this command to generate mass flash package.
flash_one_board_independently_1-10_0_20241104-140211.log (42.0 KB)
MobaXterm_10.5.82.30_20241106_154938 (copy).log (11.4 MB)
SSH ready
Flash failure
Cleaning up...
When you are using mfi package to flash the board, the mount point can not be found.
I can not find any helpful message in current log.
Could you reproduce the similar issue on the devkit?
Or have you also verified with the latest JP5.1.4(R35.6.0)?
After reading some scripts related to l4t_initrd_flash.sh, I rechecked my customized BSP and customized rootfs, and found that three folders were missing in my customized rootfs: /proc, /sys, /dev. Therefore, I added these three folders to my rootfs, and the problem was solved.
Thank you all the same. Really appreciate your support.
