Hello everyone,
We have a customized TK1 board. And an error occurred when flashing a new operating system on this board. The log is as following.
susan@susan:~/TK1/Linux_for_Tegra$ sudo ./flash.sh pcp_64g_s924m mmcblk0p1
[sudo] password for susan:
copying bctfile(/home/susan/TK1/Linux_for_Tegra/bootloader/ardbeg/BCT/TK1_PM375_JETSON_TK1_PCP_ddr3_256Mx16x4_K4W4G1646E-BC1A_924MHz.cfg)... done.
copying bootloader(/home/susan/TK1/Linux_for_Tegra/bootloader/ardbeg/u-boot.bin)... done.
populating kernel to rootfs... done.
populating jetson-tk1_extlinux.conf.emmc to rootfs... done.
done.
Making system.img...
populating rootfs from /home/susan/TK1/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 4243456( 1036 blks) ==> 28:4243468
1: SKP: 20480( 5 blks) ==> 4243496:20492
2: RAW: 4096( 1 blks) ==> 4243508:4108
2785: SKP: 4096( 1 blks) ==> 3171144360:4108
2786: RAW: 208896( 51 blks) ==> 3171144372:208908
2787: SKP: 2007257088( 490053 blks) ==> 3171353280:2007257100
2788: RAW: 4096( 1 blks) ==> 3171353292:4108
2789: SKP: 57344( 14 blks) ==> 3171357400:57356
2790: RAW: 4096( 1 blks) ==> 3171357412:4108
2791: SKP: 2095955968( 511708 blks) ==> 3171361520:2095955980
-- Total: -----------------------------------------------------------
2792 CHUNK 60078080000(14667500 blks) ==> 3171361532(774250 blks)
done.
system.img built successfully.
copying dtbfile(/home/susan/TK1/Linux_for_Tegra/kernel/dtb/tegra124-jetson_tk1-pm375-000-c00-00.dtb)... done.
copying cfgfile(/home/susan/TK1/Linux_for_Tegra/bootloader/ardbeg/cfg/gnu_linux_fastboot_emmc_full.cfg) to flash.cfg... done.
creating gpt(ppt.img)...
*** GPT Parameters ***
Device Sector Size ------- 512
device size -------------- 62547558400
bootpart size ------------ 8388608
userpart size ------------ 62539169792
Erase Block Size --------- 2097152
FS Buffer size ----------- 4096
Partition Config file ---- flash.cfg
Visible partition flag --- GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(20 partitions) ***
[ BCT] BH 0 16383 8.0MiB
[ PPT] UH 0 4095 2.0MiB ppt.img
[ PT] UH 4096 8191 2.0MiB
[ EBT] UH 8192 16383 4.0MiB u-boot.bin
[ LNX] UH 16384 49151 16.0MiB
[ SOS] UH 49152 61439 6.0MiB
[ NVC] UH 61440 65535 2.0MiB
[ MPB] UH 65536 77823 6.0MiB
[ MBP] UH 77824 90111 6.0MiB
[ GP1] UH 90112 94207 2.0MiB
[ APP] UV 94208 117434207 57294.9MiB system.img
[ DTB] UV 117434208 117442399 4.0MiB tegra124-jetson_tk1-pm375-000-c00-00.dtb
[ EFI] UV 117442400 117573471 64.0MiB
[ USP] UV 117573472 117581663 4.0MiB
[ TP1] UV 117581664 117589855 4.0MiB
[ TP2] UV 117589856 117598047 4.0MiB
[ TP3] UV 117598048 117606239 4.0MiB
[ WB0] UV 117606240 117610335 2.0MiB
[ UDA] UV 117610336 122142719 2213.1MiB
[ GPT] UH 122142720 122146815 2.0MiB gpt.img
copying flasher(/home/susan/TK1/Linux_for_Tegra/bootloader/ardbeg/fastboot.bin)... done.
Existing flashapp(/home/susan/TK1/Linux_for_Tegra/bootloader/nvflash) reused.
*** Flashing target device started. ***
./nvflash --bct TK1_PM375_JETSON_TK1_PCP_ddr3_256Mx16x4_K4W4G1646E-BC1A_924MHz.cfg --setbct --configfile flash.cfg --create --bl fastboot.bin --odmdata 0x6309C000 --go
Nvflash 4.13.0000 started
BR_CID: 0x340010017410b1031800000005068340
rcm version 0X400001
Skipping BoardID read at miniloader level
usb read error (71): Protocol error
unable to retrieve platform info NvError 0x8
Failed flashing ardbeg.
We did not see the same error on another board with the same hardware. I would like to know where the hardware is broken? RAM or SOC?!
