Jetson TK1 problem with flashing JetPack 2.0
we are a group of students who have to work with the Jetson TK1. After the fast start the board was working, but it was nacked. We decided to Flash it with JetPack 2.0. The board keeps giving us the following error:
… done.
copying bootloader(/home/labor/Linux_for_Tegra_tk1/bootloader/ardbeg/u-boot.bin)… done.
populating kernel to rootfs… done.
populating jetson-tk1_extlinux.conf.emmc to rootfs… done.
done.
Reusing existing system.img…
done.
copying dtbfile(/home/labor/Linux_for_Tegra_tk1/kernel/dtb/tegra124-jetson_tk1-pm375-000-c00-00.dtb)… done.
copying cfgfile(/home/labor/Linux_for_Tegra_tk1/bootloader/ardbeg/cfg/gnu_linux_fastboot_emmc_full.cfg) to flash.cfg… done.
creating gpt(ppt.img)…
*** GPT Parameters ***
Device Sector Size ------- 512
device size -------------- 15766388736
bootpart size ------------ 8388608
userpart size ------------ 15758000128
Erase Block Size --------- 2097152
FS Buffer size ----------- 4096
Partition Config file ---- flash.cfg
Visible partition flag — GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(20 partitions) ***
[ BCT] BH 0 16383 8.0MiB
[ PPT] UH 0 4095 2.0MiB ppt.img
[ PT] UH 4096 8191 2.0MiB
[ EBT] UH 8192 16383 4.0MiB u-boot.bin
[ LNX] UH 16384 49151 16.0MiB
[ SOS] UH 49152 61439 6.0MiB
[ NVC] UH 61440 65535 2.0MiB
[ MPB] UH 65536 77823 6.0MiB
[ MBP] UH 77824 90111 6.0MiB
[ GP1] UH 90112 94207 2.0MiB
[ APP] UV 94208 29454335 14336.0MiB system.img
[ DTB] UV 29454336 29462527 4.0MiB tegra124-jetson_tk1-pm375-000-c00-00.dtb
[ EFI] UV 29462528 29593599 64.0MiB
[ USP] UV 29593600 29601791 4.0MiB
[ TP1] UV 29601792 29609983 4.0MiB
[ TP2] UV 29609984 29618175 4.0MiB
[ TP3] UV 29618176 29626367 4.0MiB
[ WB0] UV 29626368 29630463 2.0MiB
[ UDA] UV 29630464 30773247 558.0MiB
[ GPT] UH 30773248 30777343 2.0MiB gpt.img
copying flasher(/home/labor/Linux_for_Tegra_tk1/bootloader/ardbeg/fastboot.bin)… done.
Existing flashapp(/home/labor/Linux_for_Tegra_tk1/bootloader/nvflash) reused.
*** Flashing target device started. ***
./nvflash --bct PM375_Hynix_2GB_H5TC4G63AFR_RDA_924MHz.cfg --setbct --configfile flash.cfg --create --bl fastboot.bin --odmdata 0x6009C000 --go
Nvflash 4.13.0000 started
BR_CID: 0x340010017408f044100000000cfd03c0
rcm version 0X400001
Skipping BoardID read at miniloader level
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x000000017408f044100000000cfd03c0
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
BCT sent successfully
sending file: tegra124-jetson_tk1-pm375-000-c00-00.dtb
  • 57167/57167 bytes sent
    tegra124-jetson_tk1-pm375-000-c00-00.dtb sent successfully
    odm data: 0x6009c000
    downloading bootloader – load address: 0x83d88000 entry point: 0x83d88000
    sending file: fastboot.bin
  • 594363/594363 bytes sent
    fastboot.bin sent successfully
    waiting for bootloader to initialize
    bootloader downloaded successfully
    ML execution and Cpu Handover took 1 Secs
    Partition backup took 0 Secs
    setting device: 2 3
    deleting device partitions
    creating partition: BCT
    creating partition: PPT
    creating partition: PT
    creating partition: EBT
    creating partition: LNX
    creating partition: SOS
    creating partition: NVC
    creating partition: MPB
    creating partition: MBP
    creating partition: GP1
    creating partition: APP
    creating partition: DTB
    creating partition: EFI
    creating partition: USP
    creating partition: TP1
    creating partition: TP2
    creating partition: TP3
    creating partition: WB0
    creating partition: UDA
    creating partition: GPT
    sending file: ppt.img
  • 1048576/2097152 bytes sent
    \ 2097152/2097152 bytes sent
    ppt.img sent successfully
    padded 8 bytes to bootloader
    sending file: u-boot.bin
  • 439872/439872 bytes sent
    u-boot.bin sent successfully
    sending file: system.img
  • 1048576/2477036140 bytes sent
| 2477036140/2477036140 bytes sent
system.img sent successfully
    failed to verify partition
    command failure/warning: create failed (bad data)
    bootloader status: fatal failure to read / write to mass storage (code: 9) message: flags: 0
Failed flashing ardbeg.
Is there someone who had a similiar problem and knows how to fix it?
