I have made a custom Tegra K1 board, I want to boot from SD card. I followed http://demotomohiro.github.io/hardware/jetson_tk1/setup/external_storage.html as it is. But it is failing.
Kindly if you can let me know!
Terminal:
owais@ubuntu:~/Tegra/Linux_for_Tegra$ sudo ./flash.sh jetson-tk1 mmcblk1p1
copying bctfile(/home/owais/Tegra/Linux_for_Tegra/bootloader/ardbeg/BCT/PM375_Hynix_2GB_H5TC4G63AFR_H5TC4G63CFR_RDA_924MHz.cfg)... done.
copying bootloader(/home/owais/Tegra/Linux_for_Tegra/bootloader/ardbeg/u-boot.bin)... done.
populating kernel to rootfs... done.
populating jetson-tk1_extlinux.conf.sdcard to rootfs... done.
done.
copying dtbfile(/home/owais/Tegra/Linux_for_Tegra/kernel/dtb/tegra124-jetson_tk1-pm375-000-c00-00.dtb)... done.
copying cfgfile(/home/owais/Tegra/Linux_for_Tegra/bootloader/ardbeg/cfg/gnu_linux_fastboot_emmc_full.cfg) to flash.cfg... done.
creating gpt(ppt.img)...
*** GPT Parameters ***
Device Sector Size ------- 512
device size -------------- 15766388736
bootpart size ------------ 8388608
userpart size ------------ 15758000128
Erase Block Size --------- 2097152
FS Buffer size ----------- 4096
Partition Config file ---- flash.cfg
Visible partition flag --- GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(20 partitions) ***
[ BCT] BH 0 16383 8.0MiB
[ PPT] UH 0 4095 2.0MiB ppt.img
[ PT] UH 4096 8191 2.0MiB
[ EBT] UH 8192 16383 4.0MiB u-boot.bin
[ LNX] UH 16384 49151 16.0MiB
[ SOS] UH 49152 61439 6.0MiB
[ NVC] UH 61440 65535 2.0MiB
[ MPB] UH 65536 77823 6.0MiB
[ MBP] UH 77824 90111 6.0MiB
[ GP1] UH 90112 94207 2.0MiB
[ APP] UV 94208 29454335 14336.0MiB
[ DTB] UV 29454336 29462527 4.0MiB tegra124-jetson_tk1-pm375-000-c00-00.dtb
[ EFI] UV 29462528 29593599 64.0MiB
[ USP] UV 29593600 29601791 4.0MiB
[ TP1] UV 29601792 29609983 4.0MiB
[ TP2] UV 29609984 29618175 4.0MiB
[ TP3] UV 29618176 29626367 4.0MiB
[ WB0] UV 29626368 29630463 2.0MiB
[ UDA] UV 29630464 30773247 558.0MiB
[ GPT] UH 30773248 30777343 2.0MiB gpt.img
copying flasher(/home/owais/Tegra/Linux_for_Tegra/bootloader/ardbeg/fastboot.bin)... done.
Existing flashapp(/home/owais/Tegra/Linux_for_Tegra/bootloader/nvflash) reused.
*** Flashing target device started. ***
./nvflash --boardid 0x177 0x00 0x03 --bct PM375_Hynix_2GB_H5TC4G63AFR_H5TC4G63CFR_RDA_924MHz.cfg --setbct --configfile flash.cfg --create --bl fastboot.bin --odmdata 0x6009C000 --go
Nvflash 4.13.0000 started
BR_CID: 0x34001001741141021c000000060001c0
rcm version 0X400001
Skipping BoardID read at miniloader level
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x00000001741141021c000000060001c0
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
auxInfo->NCTBoardInfo->proc_board_id is 375
auxInfo->NCTBoardInfo->proc_sku is 0
auxInfo->NCTBoardInfo->proc_fab is 3
BCT sent successfully
sending file: tegra124-jetson_tk1-pm375-000-c00-00.dtb
- 59661/59661 bytes sent
tegra124-jetson_tk1-pm375-000-c00-00.dtb sent successfully
odm data: 0x6009c000
downloading bootloader -- load address: 0x83d88000 entry point: 0x83d88000
sending file: fastboot.bin
- 594363/594363 bytes sent
fastboot.bin sent successfully
waiting for bootloader to initialize
bootloader downloaded successfully
ML execution and Cpu Handover took 4 Secs
Partition backup took 0 Secs
setting device: 2 3
deleting device partitions
creating partition: BCT
creating partition: PPT
creating partition: PT
creating partition: EBT
creating partition: LNX
creating partition: SOS
creating partition: NVC
creating partition: MPB
creating partition: MBP
creating partition: GP1
creating partition: APP
creating partition: DTB
creating partition: EFI
creating partition: USP
creating partition: TP1
creating partition: TP2
creating partition: TP3
creating partition: WB0
creating partition: UDA
creating partition: GPT
sending file: ppt.img
\ 2097152/2097152 bytes sent
ppt.img sent successfully
sending file: u-boot.bin
- 439856/439856 bytes sent
u-boot.bin sent successfully
sending file: gpt.img
gpt.img sent successfully
Create, format and download took 6 Secs
failed executing command 26 NvError 0x120002
command failure/warning: sync failed (bad data)
bootloader status: partition table is invalid, missing required information (code: 14) message: nverror:0x2 (0x2) Sync 5485 flags: 0
Failed flashing ardbeg.
Serial Log:
[0000.000] [TegraBoot] (version UNDEF_BUILD)
[0000.003] Reset reason: power on reset
[0000.007] Processing in recovery mode
[0000.010] Established communication link with host
[0001.050] Downloaded bct successfully
[0001.060] No Battery Present
[0001.063] Sdram initialization is successful
[0001.103] Downloaded DTB successfully
[0001.117] No Battery Present
[0001.413] Downloaded bootloader successfully
[0001.417] CPU-bootloader entry address: 0x83d88000
[0001.422] BoardId: 375
[0001.424] Vpr Carveout Base=0x0f4600000 Size=0x00ba00000
[0001.429] Tsec Carveout Base=0x0f2600000 Size=0x002000000
[0001.434] Lp0 Carveout Base=0x0f25ff000 Size=0x000001000
[0001.439] Xusb Carveout Base=0x0f2300000 Size=0x000200000
[0001.445] Platform-DebugCarveout: 0
[0001.471] CPU power rail is up
[0001.474] Performing RAM repair
[0001.477] CPU clock init successful
[0001.480] Starting CPU & Halting co-processor
