I have connected the board with my Ubuntu host with USB. I am following the procedure to flash the board as explained in the quick start guide. I start the board in recovery board (by keeping RECOVERY button S3 pressed and resetting the system). Following are the commands and their output, which are telling me that the board IS detected but unable to boot for flashing.
hamza@hamza-virtual-machine:~/vibrante$ lsusb | grep -i nvidia
Bus 001 Device 068: ID 0955:7940 NVidia Corp.
hamza@hamza-virtual-machine:~/vibrante$ ./vibrante-vcm30t124-linux/utils/scripts/bootburn/bootburn.sh -F “/dev/block/mmcblk0 ext4 $PWD/vibrante-vcm30t124-linux/targetfs” -r mmcblk0
############## Using Binaries ###############
BCT /home/hamza/vibrante/vibrante-vcm30t124-linux/utils/scripts/bootburn/…/bootburn//T124XA_VCM30_T124_Hynix_2GB_H5TC4G63AFR_PBI_792MHz.bct
QB1: /home/hamza/vibrante/vibrante-vcm30t124-linux/utils/scripts/bootburn/…/…/…/bootloader/quickboot1.bin
QB2: /home/hamza/vibrante/vibrante-vcm30t124-linux/utils/scripts/bootburn/…/…/…/bootloader/cpu_stage2.bin
RCM-bootloader: /home/hamza/vibrante/vibrante-vcm30t124-linux/utils/scripts/bootburn/…/…/…/bootloader/rcmboot.bin
Linux Native Kernel: /home/hamza/vibrante/vibrante-vcm30t124-linux/utils/scripts/bootburn/…/…/…/kernel/zImage
Linux Native UncompressKernel: /home/hamza/vibrante/vibrante-vcm30t124-linux/utils/scripts/bootburn/…/…/…/kernel/Image
DTB File: /home/hamza/vibrante/vibrante-vcm30t124-linux/utils/scripts/bootburn/…/…/…/kernel//tegra124-vcm30_t124.dtb
Config file: /home/hamza/vibrante/vibrante-vcm30t124-linux/utils/scripts/bootburn/…/bootburn//quickboot_snor_linux.cfg
Creating Boot Image…
Boot Image Created successfully
Creating RCMBootImg used while flashing
Booting Target for Flashing
Unable to boot the Target. Exiting
