I also tried flashing emmc this way but it didnt works.
sudo ./flash.sh jetson-xavier-nx-nx215b mmcblk0p1
scs@scs-Latitude-3400:~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra$ sudo ./flash.sh jetson-xavier-nx-nx215b mmcblk0p1
[sudo] password for scs:
# L4T BSP Information:
# R32 , REVISION: 6.1
# Target Board Information:
# Name: jetson-xavier-nx-nx215b, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0045 ] Generating RCM messages
[ 0.0061 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0067 ] Header already present for /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0113 ]
[ 0.0135 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0136 ] Assuming zero filled SBK key
[ 0.0156 ] tegrasign_v3.py --file /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0157 ] Assuming zero filled SBK key
[ 0.0257 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0287 ]
[ 0.0319 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0364 ]
[ 0.0406 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0435 ] RCM 0 is saved as rcm_0.rcm
[ 0.0549 ] RCM 1 is saved as rcm_1.rcm
[ 0.0550 ] RCM 2 is saved as rcm_2.rcm
[ 0.0550 ] List of rcm files are saved in rcm_list.xml
[ 0.0550 ]
[ 0.0551 ] Signing RCM messages
[ 0.0592 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0594 ] Assuming zero filled SBK key
[ 0.0851 ] Copying signature to RCM mesages
[ 0.0878 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0898 ]
[ 0.0898 ] Boot Rom communication
[ 0.0920 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0932 ] RCM version 0X190001
[ 0.0947 ] Boot Rom communication completed
[ 1.1110 ]
[ 2.1172 ] tegrarcm_v2 --isapplet
[ 2.1198 ] Applet version 01.00.0000
[ 2.1359 ]
[ 2.1406 ] tegrarcm_v2 --ismb2
[ 2.1761 ]
[ 2.1809 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.1842 ]
[ 2.1885 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.1919 ] adding BCH for nvtboot_applet_t194.bin
[ 2.2045 ]
[ 2.2130 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.2133 ] Assuming zero filled SBK key
[ 2.2231 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.2268 ]
[ 2.2292 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.2302 ] Applet version 01.00.0000
[ 2.2486 ] Sending mb2
[ 2.2494 ] [................................................] 100%
[ 2.2644 ]
[ 2.2690 ] tegrarcm_v2 --boot recovery
[ 2.2725 ] Applet version 01.00.0000
[ 2.2956 ]
[ 3.3030 ] tegrarcm_v2 --isapplet
[ 3.3245 ]
[ 3.3290 ] tegrarcm_v2 --ismb2
[ 3.3339 ] MB2 Applet version 01.00.0000
[ 3.3528 ]
[ 3.3573 ] tegrarcm_v2 --ismb2
[ 3.3596 ] MB2 Applet version 01.00.0000
[ 3.3763 ]
[ 3.3818 ] Retrieving board information
[ 3.3862 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 3.3876 ] MB2 Applet version 01.00.0000
[ 3.3923 ] Saved platform info in chip_info.bin
[ 3.3973 ] Chip minor revision: 2
[ 3.3980 ] Bootrom revision: 0xf
[ 3.3981 ] Ram code: 0x2
[ 3.3981 ] Chip sku: 0xde
[ 3.3981 ] Chip Sample: non es
[ 3.3981 ]
[ 3.3988 ] Retrieving EEPROM data
[ 3.3989 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 3.4001 ] MB2 Applet version 01.00.0000
[ 3.4046 ] Saved platform info in /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 3.4393 ]
[ 3.4396 ] Rebooting to recovery mode
[ 3.4459 ] tegrarcm_v2 --ismb2
[ 3.4500 ] MB2 Applet version 01.00.0000
[ 3.4723 ]
[ 3.4725 ] Rebooting to recovery mode
[ 3.4768 ] tegrarcm_v2 --reboot recovery
[ 3.4793 ] MB2 Applet version 01.00.0000
[ 3.5203 ]
Board ID(3668) version(301) sku(0003) revision(B.0)
Copy /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb to /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec
copying bctfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying bctfile1(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying minratchet_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)... done.
copying device_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying misc_cold_boot_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying gpioint_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying pmic_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying pmc_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying prod_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying scr_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying bootrom_config(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying dev_params(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)... done.
Existing bootloader(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign boot.img kernel
version 1.0.0
[ 0.0004 ] Generating signature
[ 0.0026 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0027 ] Assuming zero filled SBK key : not reading
[ 0.0026 ] Generating ratchet blob
[ 0.0045 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0066 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0075 ]
[ 0.0078 ] header_magic: 414e4452
[ 0.0111 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[ 0.0129 ]
[ 0.0157 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[ 0.0170 ] adding BCH for 1_boot.img
[ 0.8546 ]
[ 0.8588 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.8589 ] Assuming zero filled SBK key : not reading
[ 0.9486 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 1.3616 ]
[ 1.3883 ] Signed file: /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x27f1800 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
30412 blocks
_BASE_KERNEL_VERSION=4.9.253-tegra
~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
66148 blocks
Making Recovery image...
copying recdtbfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000233995 s, 85.5 kB/s
Existing sosfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb)... done.
Existing scefile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign kernel_tegra194-p3668-all-p3509-0000.dtb kernel_dtb
version 1.0.0
[ 0.0005 ] Generating signature
[ 0.0041 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0042 ] Assuming zero filled SBK key : not reading
[ 0.0041 ] Generating ratchet blob
[ 0.0066 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0085 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0110 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0110 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0110 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0110 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0110 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0111 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0111 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0111 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0111 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0111 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0111 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0111 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0111 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0111 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0112 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0112 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0112 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0112 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0112 ]
[ 0.0114 ] header_magic: d00dfeed
[ 0.0135 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0153 ]
[ 0.0180 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
[ 0.0191 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0270 ]
[ 0.0308 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0310 ] Assuming zero filled SBK key : not reading
[ 0.0408 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 0.0447 ]
[ 0.0452 ] Signed file: /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x30a4e to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra194-p3668-all-p3509-0000.dtb to rootfs... done.
Making system.img...
populating rootfs from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
generating sig file of Image ... /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign ./boot/Image kernel
version 1.0.0
[ 0.0031 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0031 ] Assuming zero filled SBK key : not reading
[ 0.0030 ] Generating ratchet blob
[ 0.0055 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0061 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0077 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0077 ]
[ 0.0080 ] header_magic: c05614
[ 0.0105 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0123 ]
[ 0.0146 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_Image zerosbk
[ 0.0154 ] adding BCH for 1_Image
[ 0.7467 ]
[ 0.7500 ] tegrasign_v3.py --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.7500 ] Assuming zero filled SBK key : not reading
[ 0.8567 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 1.2106 ]
[ 1.2830 ] Signed file: /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/Image_sigheader.encrypt
l4t_sign_image.sh: Generate header for Image_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x2109008 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/Image.sig
done.
done.
generating sig file of kernel_tegra194-p3668-all-p3509-0000.dtb ... /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign ./boot/dtb/kernel_tegra194-p3668-all-p3509-0000.dtb kernel_dtb
version 1.0.0
[ 0.0006 ] Generating signature
[ 0.0029 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0030 ] Assuming zero filled SBK key : not reading
[ 0.0029 ] Generating ratchet blob
[ 0.0047 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0053 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0056 ]
[ 0.0062 ] header_magic: d00dfeed
[ 0.0082 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0093 ]
[ 0.0112 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
[ 0.0118 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0167 ]
[ 0.0200 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0202 ] Assuming zero filled SBK key : not reading
[ 0.0330 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 0.0385 ]
[ 0.0391 ] Signed file: /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/dtb/kernel_tegra194-p3668-all-p3509-0000.dtb.sig
done.
done.
generating sig file of initrd ... /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/initrd data
version 1.0.0
[ 0.0027 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0028 ] Assuming zero filled SBK key : not reading
[ 0.0036 ] header_magic: 1f8b0800
[ 0.0056 ] tegrahost_v2 --chip 0x19 --align 1_initrd
[ 0.0068 ]
[ 0.0087 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_initrd zerosbk
[ 0.0097 ] adding BCH for 1_initrd
[ 0.1665 ]
[ 0.1695 ] tegrasign_v3.py --key --list 1_initrd_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.1697 ] Assuming zero filled SBK key : not reading
[ 0.2030 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_sigheader.encrypt 1_initrd_sigheader.hash zerosbk
[ 0.2873 ]
[ 0.2922 ] Signed file: /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/initrd_sigheader.encrypt
l4t_sign_image.sh: Generate header for initrd_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x6e72c8 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for initrd_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/initrd.sig
done.
done.
generating sig file of extlinux.conf ... /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/extlinux/extlinux.conf data
version 1.0.0
[ 0.0028 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0029 ] Assuming zero filled SBK key : not reading
[ 0.0028 ] header_magic: 54494d45
[ 0.0046 ] tegrahost_v2 --chip 0x19 --align 1_extlinux.conf
[ 0.0053 ]
[ 0.0072 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_extlinux.conf zerosbk
[ 0.0078 ] adding BCH for 1_extlinux.conf
[ 0.0080 ]
[ 0.0108 ] tegrasign_v3.py --key --list 1_extlinux_sigheader.conf_list.xml --pubkeyhash pub_key.key
[ 0.0109 ] Assuming zero filled SBK key : not reading
[ 0.0147 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_extlinux_sigheader.conf.encrypt 1_extlinux_sigheader.conf.hash zerosbk
[ 0.0156 ]
[ 0.0158 ] Signed file: /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: Generate header for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: chip 0x19: add 0x350 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/extlinux/extlinux.conf.sig
done.
done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
copying cfgfile(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t194_spi_emmc_p3668.xml) to flash.xml... done.
Existing flasher(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0xB8190000 --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p3668-all-p3509-0000.dtb" --trim_bpmp_dtb --ramcode 1
saving flash command in /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0107 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0108 ] Assuming zero filled SBK key
[ 0.0025 ] Generating RCM messages
[ 0.0048 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0056 ] Header already present for mb1_t194_prod.bin
[ 0.0088 ]
[ 0.0191 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0192 ] Assuming zero filled SBK key
[ 0.0215 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0216 ] Assuming zero filled SBK key
[ 0.0183 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0214 ]
[ 0.0239 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0249 ]
[ 0.0270 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0300 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0305 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0305 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0305 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0305 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0305 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0305 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0305 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0305 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0306 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0306 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0306 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0306 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0306 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0306 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0306 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0306 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0306 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0306 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0306 ]
[ 0.0337 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0360 ] RCM 0 is saved as rcm_0.rcm
[ 0.0459 ] RCM 1 is saved as rcm_1.rcm
[ 0.0469 ] RCM 2 is saved as rcm_2.rcm
[ 0.0469 ] List of rcm files are saved in rcm_list.xml
[ 0.0470 ]
[ 0.0471 ] Signing RCM messages
[ 0.0587 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0589 ] Assuming zero filled SBK key
[ 0.0607 ] Copying signature to RCM mesages
[ 0.0638 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0660 ]
[ 0.0660 ] Parsing partition layout
[ 0.0676 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0706 ]
[ 0.0707 ] Reading ramcode from backup chip_info.bin file
[ 0.0709 ] RAMCODE Read from Device: 2
[ 0.0710 ] Generating BPMP dtb for ramcode - 2
[ 0.1568 ] Old BPMP dtb size - 387506 bytes
[ 0.1568 ] New BPMP dtb size - 168338 bytes
[ 0.1569 ]
[ 0.1572 ] Creating list of images to be signed
[ 0.1594 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 0.1601 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.1606 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.1610 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.1634 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.1637 ] adding BCH for spe_t194.bin
[ 0.1663 ] adding BCH for spe_t194.bin
[ 0.1680 ] adding BCH for nvtboot_t194.bin
[ 0.1708 ] adding BCH for nvtboot_t194.bin
[ 0.1740 ] Header already present for preboot_c10_prod_cr.bin
[ 0.1776 ] Header already present for preboot_c10_prod_cr.bin
[ 0.1778 ] Header already present for mce_c10_prod_cr.bin
[ 0.1785 ] Header already present for mce_c10_prod_cr.bin
[ 0.1810 ] adding BCH for mts_c10_prod_cr.bin
[ 0.1880 ] adding BCH for mts_c10_prod_cr.bin
[ 0.2523 ] Header already present for warmboot_t194_prod.bin
[ 0.3162 ] Header already present for warmboot_t194_prod.bin
[ 0.3171 ] adding BCH for xusb_sil_rel_fw
[ 0.3181 ] adding BCH for xusb_sil_rel_fw
[ 0.3205 ] adding BCH for cboot_t194.bin
[ 0.3230 ] adding BCH for cboot_t194.bin
[ 0.3315 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.3402 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.3451 ] adding BCH for tos-trusty_t194.img
[ 0.3499 ] adding BCH for tos-trusty_t194.img
[ 0.3576 ] adding BCH for eks.img
[ 0.3652 ] adding BCH for eks.img
[ 0.3654 ] adding BCH for adsp-fw.bin
[ 0.3659 ] adding BCH for adsp-fw.bin
[ 0.3673 ] adding BCH for camera-rtcpu-rce.img
[ 0.3694 ] adding BCH for camera-rtcpu-rce.img
[ 0.3756 ] adding BCH for bpmp_t194.bin
[ 0.3833 ] adding BCH for bpmp_t194.bin
[ 0.4108 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 0.4271 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 0.4302 ] adding BCH for boot.img
[ 0.4609 ] adding BCH for boot.img
[ 1.2266 ] adding BCH for kernel_tegra194-p3668-all-p3509-0000.dtb
[ 1.9748 ] adding BCH for kernel_tegra194-p3668-all-p3509-0000.dtb
[ 1.9784 ] adding BCH for recovery.img
[ 2.0792 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb.rec
[ 2.9730 ]
[ 2.9731 ] Filling MB1 storage info
[ 2.9731 ] Generating br-bct
[ 2.9750 ] Performing cfg overlay
[ 2.9750 ] ['tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 2.9752 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1.cfg
[ 3.0588 ]
[ 3.0589 ] Updating dev and MSS params in BR BCT
[ 3.0590 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.1160 ]
[ 3.1160 ] Updating bl info
[ 3.1182 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 3.1197 ]
[ 3.1197 ] Generating signatures
[ 3.1302 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 3.1303 ] Assuming zero filled SBK key
[ 3.5603 ] Generating br-bct
[ 3.5626 ] Performing cfg overlay
[ 3.5626 ] ['/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1.cfg']
[ 3.5626 ] Updating dev and MSS params in BR BCT
[ 3.5627 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.6262 ]
[ 3.6263 ] Updating bl info
[ 3.6286 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.6309 ]
[ 3.6310 ] Updating smd info
[ 3.6332 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 3.6341 ]
[ 3.6342 ] Updating Odmdata
[ 3.6363 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 3.6376 ]
[ 3.6376 ] Get Signed section of bct
[ 3.6400 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 3.6410 ]
[ 3.6434 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 3.6441 ] Assuming zero filled SBK key
[ 3.7042 ]
[ 3.7042 ] Updating BCT with signature
[ 3.7083 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 3.7117 ]
[ 3.7119 ] Generating coldboot mb1-bct
[ 3.7184 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 3.7206 ] MB1-BCT version: 0x1
[ 3.7214 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 3.7225 ] Added Platform Config 0 data with size :- 2432
[ 3.7267 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 3.7286 ] Added Platform Config 1 data with size :- 19640
[ 3.7479 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 3.7484 ] Added Platform Config 2 data with size :- 24
[ 3.7488 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 3.7494 ] Added Platform Config 4 data with size :- 348
[ 3.7497 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 3.7501 ] Added Platform Config 3 data with size :- 92
[ 3.7504 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 3.7508 ] Added Platform Config 5 data with size :- 128
[ 3.7511 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 3.7515 ] Added Platform Config 7 data with size :- 392
[ 3.7518 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 3.7521 ] Added Platform Config 9 data with size :- 40
[ 3.7521 ]
[ 3.7522 ] Updating mb1-bct with firmware information
[ 3.7548 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 3.7582 ] MB1-BCT version: 0x1
[ 3.7583 ]
[ 3.7583 ] Updating mb1-bct with storage information
[ 3.7616 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 3.7628 ] MB1-BCT version: 0x1
[ 3.7632 ]
[ 3.7633 ] Updating mb1-bct with ratchet information
[ 3.7676 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 3.7691 ] MB1-BCT version: 0x1
[ 3.7694 ] FwIndex: 1, MinRatchetLevel: 0
[ 3.7700 ] FwIndex: 2, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 3, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 4, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 5, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 6, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 7, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 11, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 12, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 13, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 14, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 15, MinRatchetLevel: 0
[ 3.7701 ] FwIndex: 16, MinRatchetLevel: 0
[ 3.7702 ] FwIndex: 17, MinRatchetLevel: 0
[ 3.7702 ] FwIndex: 18, MinRatchetLevel: 0
[ 3.7702 ] FwIndex: 19, MinRatchetLevel: 0
[ 3.7702 ] FwIndex: 30, MinRatchetLevel: 0
[ 3.7702 ] FwIndex: 31, MinRatchetLevel: 0
[ 3.7702 ] FwIndex: 32, MinRatchetLevel: 0
[ 3.7702 ]
[ 3.7730 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 3.7743 ]
[ 3.7768 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 3.7779 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 3.7789 ]
[ 3.7898 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.7899 ] Assuming zero filled SBK key
[ 3.7863 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 3.7883 ]
[ 3.7886 ] Generating recovery mb1-bct
[ 3.7912 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 3.7920 ] MB1-BCT version: 0x1
[ 3.7923 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 3.7928 ] Added Platform Config 0 data with size :- 2432
[ 3.7939 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 3.7943 ] Added Platform Config 1 data with size :- 19640
[ 3.8052 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 3.8055 ] Added Platform Config 2 data with size :- 24
[ 3.8058 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 3.8061 ] Added Platform Config 4 data with size :- 348
[ 3.8063 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 3.8067 ] Added Platform Config 3 data with size :- 92
[ 3.8068 ]
[ 3.8068 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 3.8068 ] Added Platform Config 5 data with size :- 128
[ 3.8068 ]
[ 3.8068 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 3.8068 ] Added Platform Config 7 data with size :- 392
[ 3.8068 ]
[ 3.8068 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 3.8068 ] Added Platform Config 9 data with size :- 40
[ 3.8068 ]
[ 3.8069 ] Updating mb1-bct with firmware information
[ 3.8094 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 3.8114 ] MB1-BCT version: 0x1
[ 3.8121 ]
[ 3.8122 ] Updating mb1-bct with storage information
[ 3.8153 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 3.8171 ] MB1-BCT version: 0x1
[ 3.8178 ]
[ 3.8178 ] Updating mb1-bct with ratchet information
[ 3.8214 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 3.8232 ] MB1-BCT version: 0x1
[ 3.8235 ] FwIndex: 1, MinRatchetLevel: 0
[ 3.8237 ] FwIndex: 2, MinRatchetLevel: 0
[ 3.8237 ] FwIndex: 3, MinRatchetLevel: 0
[ 3.8237 ] FwIndex: 4, MinRatchetLevel: 0
[ 3.8238 ] FwIndex: 5, MinRatchetLevel: 0
[ 3.8238 ] FwIndex: 6, MinRatchetLevel: 0
[ 3.8238 ] FwIndex: 7, MinRatchetLevel: 0
[ 3.8238 ] FwIndex: 11, MinRatchetLevel: 0
[ 3.8238 ] FwIndex: 12, MinRatchetLevel: 0
[ 3.8238 ] FwIndex: 13, MinRatchetLevel: 0
[ 3.8238 ] FwIndex: 14, MinRatchetLevel: 0
[ 3.8239 ] FwIndex: 15, MinRatchetLevel: 0
[ 3.8239 ] FwIndex: 16, MinRatchetLevel: 0
[ 3.8239 ] FwIndex: 17, MinRatchetLevel: 0
[ 3.8239 ] FwIndex: 18, MinRatchetLevel: 0
[ 3.8239 ] FwIndex: 19, MinRatchetLevel: 0
[ 3.8239 ] FwIndex: 30, MinRatchetLevel: 0
[ 3.8239 ] FwIndex: 31, MinRatchetLevel: 0
[ 3.8239 ] FwIndex: 32, MinRatchetLevel: 0
[ 3.8239 ]
[ 3.8265 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 3.8280 ]
[ 3.8315 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1.bct zerosbk
[ 3.8329 ] adding BCH for mb1_bct_MB1.bct
[ 3.8342 ]
[ 3.8455 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.8456 ] Assuming zero filled SBK key
[ 3.8439 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 3.8458 ]
[ 3.8460 ] Generating coldboot mem-bct
[ 3.8487 ] tegrabct_v2 --chip 0x19 0 --sdram /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1.cfg --membct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_1.bct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_2.bct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_3.bct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_4.bct
[ 3.8503 ] Packing sdram param for instance[0]
[ 3.9155 ] Packing sdram param for instance[1]
[ 3.9158 ] Packing sdram param for instance[2]
[ 3.9159 ] Packing sdram param for instance[3]
[ 3.9159 ] Packing sdram param for instance[4]
[ 3.9159 ] Packing sdram param for instance[5]
[ 3.9159 ] Packing sdram param for instance[6]
[ 3.9159 ] Packing sdram param for instance[7]
[ 3.9159 ] Packing sdram param for instance[8]
[ 3.9159 ] Packing sdram param for instance[9]
[ 3.9159 ] Packing sdram param for instance[10]
[ 3.9159 ] Packing sdram param for instance[11]
[ 3.9160 ] Packing sdram param for instance[12]
[ 3.9160 ] Packing sdram param for instance[13]
[ 3.9160 ] Packing sdram param for instance[14]
[ 3.9160 ] Packing sdram param for instance[15]
[ 3.9160 ]
[ 3.9160 ] Getting sector size from pt
[ 3.9183 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 3.9206 ]
[ 3.9207 ] BlockSize read from layout is 200
[ 3.9227 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_1.bct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_2.bct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_3.bct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_4.bct
[ 3.9234 ] adding BCH for /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_1.bct
[ 3.9256 ]
[ 3.9279 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 3.9287 ]
[ 3.9307 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot.bct zerosbk
[ 3.9314 ] Header already present for mem_coldboot.bct
[ 3.9318 ]
[ 3.9424 ] tegrasign_v3.py --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.9425 ] Assuming zero filled SBK key
[ 3.9455 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 3.9493 ]
[ 3.9495 ] Generating recovery mem-bct
[ 3.9524 ] tegrabct_v2 --chip 0x19 0 --sdram /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1.cfg --membct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_1.bct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_2.bct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_3.bct /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/8212/tmpghjq7n6n1_4.bct
[ 3.9539 ] Packing sdram param for instance[0]
[ 4.0190 ] Packing sdram param for instance[1]
[ 4.0192 ] Packing sdram param for instance[2]
[ 4.0195 ] Packing sdram param for instance[3]
[ 4.0195 ] Packing sdram param for instance[4]
[ 4.0195 ] Packing sdram param for instance[5]
[ 4.0195 ] Packing sdram param for instance[6]
[ 4.0195 ] Packing sdram param for instance[7]
[ 4.0195 ] Packing sdram param for instance[8]
[ 4.0195 ] Packing sdram param for instance[9]
[ 4.0195 ] Packing sdram param for instance[10]
[ 4.0195 ] Packing sdram param for instance[11]
[ 4.0195 ] Packing sdram param for instance[12]
[ 4.0195 ] Packing sdram param for instance[13]
[ 4.0195 ] Packing sdram param for instance[14]
[ 4.0195 ] Packing sdram param for instance[15]
[ 4.0195 ]
[ 4.0220 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 4.0227 ]
[ 4.0246 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm.bct zerosbk
[ 4.0256 ] adding BCH for mem_rcm.bct
[ 4.0266 ]
[ 4.0373 ] tegrasign_v3.py --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.0374 ] Assuming zero filled SBK key
[ 4.0340 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 4.0354 ]
[ 4.0355 ] Copying signatures
[ 4.0375 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 5.5645 ]
[ 5.5646 ] Boot Rom communication
[ 5.5674 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 5.5681 ] BR_CID: 0x880219116430b0072400000004008280
[ 5.5843 ] RCM version 0X190001
[ 5.5999 ] Boot Rom communication completed
[ 6.6163 ]
[ 7.6230 ] tegrarcm_v2 --isapplet
[ 7.6257 ] Applet version 01.00.0000
[ 7.6287 ]
[ 7.6288 ] Sending BCTs
[ 7.6331 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 7.6363 ] Applet version 01.00.0000
[ 7.6550 ] Sending bct_bootrom
[ 7.6556 ] [................................................] 100%
[ 7.6573 ] Sending bct_mb1
[ 7.6602 ] [................................................] 100%
[ 7.6650 ] Sending bct_mem
[ 7.7147 ] [................................................] 100%
[ 7.7909 ]
[ 7.7911 ] Generating blob
[ 7.7972 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[ 7.8009 ]
[ 7.8054 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[ 7.8080 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[ 7.8205 ]
[ 7.8320 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.8321 ] Assuming zero filled SBK key
[ 7.8297 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[ 7.8349 ]
[ 7.8372 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[ 7.8381 ]
[ 7.8402 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[ 7.8409 ] adding BCH for blob_nvtboot_recovery_t194.bin
[ 7.8454 ]
[ 7.8563 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.8564 ] Assuming zero filled SBK key
[ 7.8541 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[ 7.8573 ]
[ 7.8613 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[ 7.8629 ]
[ 7.8658 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[ 7.8666 ] Header already present for blob_preboot_c10_prod_cr.bin
[ 7.8670 ]
[ 7.8776 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.8777 ] Assuming zero filled SBK key
[ 7.8735 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.8746 ]
[ 7.8769 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[ 7.8778 ]
[ 7.8801 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[ 7.8810 ] Header already present for blob_mce_c10_prod_cr.bin
[ 7.8831 ]
[ 7.8950 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.8951 ] Assuming zero filled SBK key
[ 7.8914 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.8938 ]
[ 7.8950 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[ 7.8960 ]
[ 7.8996 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[ 7.9004 ] adding BCH for blob_mts_c10_prod_cr.bin
[ 7.9656 ]
[ 7.9767 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.9768 ] Assuming zero filled SBK key
[ 7.9786 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 8.0153 ]
[ 8.0179 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[ 8.0186 ]
[ 8.0206 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t194.bin zerosbk
[ 8.0212 ] adding BCH for blob_bpmp_t194.bin
[ 8.0388 ]
[ 8.0496 ] tegrasign_v3.py --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.0497 ] Assuming zero filled SBK key
[ 8.0481 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[ 8.0577 ]
[ 8.0609 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p3668-a00.dtb
[ 8.0623 ]
[ 8.0656 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p3668-a00.dtb zerosbk
[ 8.0664 ] adding BCH for blob_tegra194-a02-bpmp-p3668-a00.dtb
[ 8.0697 ]
[ 8.0804 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 8.0806 ] Assuming zero filled SBK key
[ 8.0855 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.hash zerosbk
[ 8.0962 ]
[ 8.1021 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[ 8.1046 ]
[ 8.1078 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194.bin zerosbk
[ 8.1093 ] adding BCH for blob_spe_t194.bin
[ 8.1131 ]
[ 8.1246 ] tegrasign_v3.py --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.1247 ] Assuming zero filled SBK key
[ 8.1241 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[ 8.1265 ]
[ 8.1289 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[ 8.1312 ]
[ 8.1334 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-trusty_t194.img zerosbk
[ 8.1344 ] adding BCH for blob_tos-trusty_t194.img
[ 8.1438 ]
[ 8.1547 ] tegrasign_v3.py --key None --list blob_tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 8.1547 ] Assuming zero filled SBK key
[ 8.1514 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[ 8.1571 ]
[ 8.1613 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[ 8.1625 ]
[ 8.1657 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks.img zerosbk
[ 8.1665 ] adding BCH for blob_eks.img
[ 8.1667 ]
[ 8.1773 ] tegrasign_v3.py --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 8.1774 ] Assuming zero filled SBK key
[ 8.1732 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 8.1742 ]
[ 8.1752 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p3668-all-p3509-0000.dtb
[ 8.1760 ]
[ 8.1780 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p3668-all-p3509-0000.dtb zerosbk
[ 8.1786 ] adding BCH for blob_tegra194-p3668-all-p3509-0000.dtb
[ 8.1828 ]
[ 8.1946 ] tegrasign_v3.py --key None --list blob_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 8.1947 ] Assuming zero filled SBK key
[ 8.1910 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 8.1939 ]
[ 8.1965 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 8.1979 ] number of images in blob are 11
[ 8.1982 ] blobsize is 5785608
[ 8.1983 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 263840
[ 8.2005 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 181152
[ 8.2009 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[ 8.2014 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 143200
[ 8.2018 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[ 8.2023 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[ 8.2035 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt of size 172448
[ 8.2040 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[ 8.2044 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 410560
[ 8.2048 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[ 8.2051 ] Added binary blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of size 203344
[ 8.2069 ]
[ 8.2070 ] Sending bootloader and pre-requisite binaries
[ 8.2092 ] tegrarcm_v2 --download blob blob.bin
[ 8.2099 ] Applet version 01.00.0000
[ 8.2264 ] Sending blob
[ 8.2268 ] [................................................] 100%
[ 9.0567 ]
[ 9.0615 ] tegrarcm_v2 --boot recovery
[ 9.0642 ] Applet version 01.00.0000
[ 9.0898 ]
[ 10.0957 ] tegrarcm_v2 --isapplet
[ 10.5113 ]
[ 10.5158 ] tegrarcm_v2 --ismb2
[ 10.5216 ]
[ 10.5427 ] tegradevflash_v2 --iscpubl
[ 10.5457 ] Bootloader version 01.00.0000
[ 10.5615 ] Bootloader version 01.00.0000
[ 10.5618 ]
[ 10.5619 ] Retrieving storage infomation
[ 10.5668 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 10.5710 ] Applet is not running on device. Continue with Bootloader
[ 10.5907 ]
[ 10.5955 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 10.5993 ] Bootloader version 01.00.0000
[ 10.6035 ] Saved platform info in storage_info.bin
[ 10.6048 ]
[ 10.6049 ] Flashing the device
[ 10.6096 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 10.6150 ]
[ 10.6210 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 10.6235 ] Bootloader version 01.00.0000
[ 10.6257 ] Erasing spi: 0 ......... [Done]
[ 13.6290 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin
[ 13.6309 ] [................................................] 100%
[ 13.7447 ] Erasing sdmmc_user: 3 ......... [Done]
[ 14.0491 ] Writing partition master_boot_record with mbr_1_3.bin
[ 14.0505 ] [................................................] 100%
[ 14.0516 ] Writing partition primary_gpt with gpt_primary_1_3.bin
[ 14.0580 ] [................................................] 100%
[ 14.0596 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin
[ 14.0798 ] [................................................] 100%
[ 14.1011 ] Writing partition mb1 with mb1_t194_prod_sigheader.bin.encrypt
[ 14.1046 ] [................................................] 100%
[ 14.1131 ] Writing partition mb1_b with mb1_t194_prod_sigheader.bin.encrypt
[ 15.6986 ] [................................................] 100%
[ 15.7085 ] Writing partition spe-fw with spe_t194_sigheader.bin.encrypt
[ 17.2951 ] [................................................] 100%
[ 17.2986 ] Writing partition spe-fw_b with spe_t194_sigheader.bin.encrypt
[ 17.9095 ] [................................................] 100%
[ 17.9130 ] Writing partition mb2 with nvtboot_t194_sigheader.bin.encrypt
[ 18.5234 ] [................................................] 100%
[ 18.5311 ] Writing partition mb2_b with nvtboot_t194_sigheader.bin.encrypt
[ 19.6822 ] [................................................] 100%
[ 19.6896 ] Writing partition mts-preboot with preboot_c10_prod_cr_sigheader.bin.encrypt
[ 20.8419 ] [................................................] 100%
[ 20.8438 ] Writing partition mts-preboot_b with preboot_c10_prod_cr_sigheader.bin.encrypt
[ 21.0061 ] [................................................] 100%
[ 21.0078 ] Writing partition mts-mce with mce_c10_prod_cr_sigheader.bin.encrypt
[ 21.1698 ] [................................................] 100%
[ 21.1751 ] Writing partition mts-mce_b with mce_c10_prod_cr_sigheader.bin.encrypt
[ 22.0885 ] [................................................] 100%
[ 22.0940 ] Writing partition mts-proper with mts_c10_prod_cr_sigheader.bin.encrypt
[ 24.7116 ] [............... ] 030%
Error: Return value 3
Command tegradevflash_v2 --pt flash.xml.bin --create
Failed flashing t186ref.
