I’m running into an unexpected issue trying to flash a Xavier NX eMMC module after having burned SBK / PKC keys into the fuses. Running
sudo ./flash.sh -u keys/pkc-sign-key.pem -v keys/sbk.key -s keys/pkc-sign-key.pem -r -y SBKPKC jetson-xavier-nx-devkit-emmc mmcblk0p1
fails when it starts writing the secondary_gpt part:
(((earlier log messages omitted)))
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed --bct br_bct_BR.bct --applet rcm_2_signed.rcm --applet_softfuse rcm_1_signed.rcm --cmd "secureflash;reboot" --cfg secureflash.xml --chip 0x19 --mb1_bct mb1_bct_MB1.bct_sigheader.encrypt.signed --mem_bct mem_rcm.bct_sigheader.encrypt.signed --mb1_cold_boot_bct mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed --mem_bct_cold_boot mem_coldboot_sigheader.bct.signed --bins "mb2_bootloader nvtboot_recovery_t194.bin_sigheader.encrypt.signed; mts_preboot preboot_c10_prod_cr_sigheader.bin.encrypt.signed; mts_mce mce_c10_prod_cr_sigheader.bin.encrypt.signed; mts_proper mts_c10_prod_cr_sigheader.bin.encrypt.signed; bpmp_fw bpmp_t194_sigheader.bin.encrypt.signed; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed; spe_fw spe_t194_sigheader.bin.encrypt.signed; tlk tos-trusty_t194_sigheader.img.encrypt.signed; eks eks_sigheader.img.encrypt.signed; bootloader_dtb tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed"
saving flash command in flashcmd.txt
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0158 ] Parsing partition layout
[ 0.0170 ] tegraparser_v2 --pt secureflash.xml.tmp
[ 0.0190 ]
[ 0.0190 ] Boot Rom communication
[ 0.0213 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_1_signed.rcm --rcm rcm_2_signed.rcm
[ 0.0225 ] BR_CID: 0xe80219116459e5871000000013048180
[ 0.2286 ] Boot Rom communication completed
[ 1.4692 ]
[ 2.4741 ] tegrarcm_v2 --isapplet
[ 2.4762 ] Applet version 01.00.0000
[ 3.3577 ]
[ 3.3578 ] Sending BCTs
[ 3.3614 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1.bct_sigheader.encrypt.signed --download bct_mem mem_rcm.bct_sigheader.encrypt.signed
[ 3.3632 ] Applet version 01.00.0000
[ 4.2339 ] Sending bct_bootrom
[ 4.2341 ] [................................................] 100%
[ 4.2355 ] Sending bct_mb1
[ 4.2422 ] [................................................] 100%
[ 4.2460 ] Sending bct_mem
[ 4.3001 ] [................................................] 100%
[ 4.3761 ]
[ 4.3762 ] Generating blob
[ 4.3823 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 4.3841 ] number of images in blob are 11
[ 4.3850 ] blobsize is 5900536
[ 4.3852 ] Added binary blob_nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed of size 263840
[ 4.3927 ] Added binary blob_nvtboot_recovery_t194.bin_sigheader.encrypt.signed of size 181152
[ 4.3935 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt.signed of size 24016
[ 4.3942 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt.signed of size 143200
[ 4.3949 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt.signed of size 3430416
[ 4.3968 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt.signed of size 856352
[ 4.3985 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed of size 281984
[ 4.3992 ] Added binary blob_spe_t194_sigheader.bin.encrypt.signed of size 94960
[ 4.3999 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt.signed of size 410560
[ 4.4007 ] Added binary blob_eks_sigheader.img.encrypt.signed of size 5136
[ 4.4013 ] Added binary blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed of size 208736
[ 4.4027 ]
[ 4.4028 ] Sending bootloader and pre-requisite binaries
[ 4.4047 ] tegrarcm_v2 --download blob blob.bin
[ 4.4060 ] Applet version 01.00.0000
[ 5.1505 ] Sending blob
[ 5.1507 ] [................................................] 100%
[ 5.9649 ]
[ 5.9687 ] tegrarcm_v2 --boot recovery
[ 5.9704 ] Applet version 01.00.0000
[ 6.8461 ]
[ 7.8509 ] tegrarcm_v2 --isapplet
[ 8.4575 ]
[ 8.4610 ] tegrarcm_v2 --ismb2
[ 9.3334 ]
[ 9.3371 ] tegradevflash_v2 --iscpubl
[ 9.3389 ] Bootloader version 01.00.0000
[ 9.7738 ] Bootloader version 01.00.0000
[ 9.7747 ]
[ 9.7748 ] Retrieving storage infomation
[ 9.7784 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 9.7801 ] Applet is not running on device. Continue with Bootloader
[ 10.4230 ]
[ 10.4264 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 10.4281 ] Bootloader version 01.00.0000
[ 10.8657 ] Saved platform info in storage_info.bin
[ 10.8672 ]
[ 10.8673 ] Flashing the device
[ 10.8706 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt secureflash.xml.bin
[ 10.8732 ]
[ 10.8762 ] tegradevflash_v2 --pt secureflash.xml.bin --create
[ 10.8777 ] Bootloader version 01.00.0000
[ 11.3097 ] Erasing spi: 0 ......... [Done]
[ 14.3124 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin
[ 14.3132 ] [................................................] 100%
[ 14.3147 ] 000000000d0d0001: o initialize partition table from GPT.
[ 14.4012 ]
[ 14.4012 ]
Error: Return value 1
Command tegradevflash_v2 --pt secureflash.xml.bin --create
On the debug serial I see the following:
main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0054.378] I> Welcome to MB2(TBoot-BPMP) Recovery (version: 00.00.2018.32-mobi
le-21d977c9)
[0054.378] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0054.379] I> Default Heap @ [0xd486400 - 0xd48a400]
[0054.380] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0054.386] W> device prod register failed
[0054.391] I> parsing oem signed section of bpmp-fw header done
[0054.398] I> bpmp-fw binary copied from blob
[0054.404] I> RSA PSS signature check: OK
[0054.404] I> oem authentication of bpmp-fw header done
[0054.409] I> bpmp-fw: Authentication init Done
[0054.413] I> parsing oem signed section of cpubl header done
[0054.419] I> cpubl binary copied from blob
[0054.426] I> bpmp-fw: Authentication Finalize Done
[0054.430] I> RSA PSS signature check: OK
[0054.431] I> oem authentication of cpubl header done
[0054.436] I> cpubl: Authentication init Done
[0054.440] I> parsing oem signed section of tos header done
[0054.446] I> tos binary copied from blob
[0054.449] I> Relocating BR-BCT
[0054.453] I> cpubl: Authentication Finalize Done
[0054.459] I> RSA PSS signature check: OK
[0054.460] I> oem authentication of tos header done
[0054.465] I> tos: Authentication init Done
[0054.469] I> parsing oem signed section of bpmp-fw-dtb header done
[0054.475] I> bpmp-fw-dtb binary copied from blob
[0054.481] I> tos: Authentication Finalize Done
[0054.488] I> RSA PSS signature check: OK
[0054.488] I> oem authentication of bpmp-fw-dtb header done
[0054.492] I> bpmp-fw-dtb: Authentication init Done
[0054.497] I> parsing oem signed section of cpubl-dtb header done
[0054.503] I> cpubl-dtb binary copied from blob
[0054.509] I> bpmp-fw-dtb: Authentication Finalize Done
[0054.608] I> RSA PSS signature check: OK
[0054.608] I> oem authentication of cpubl-dtb header done
[0054.609] I> cpubl-dtb: Authentication init Done
[0054.610] I> parsing oem signed section of eks header done
[0054.610] I> eks binary copied from blob
[0054.612] I> cpubl-dtb: Authentication Finalize Done
[0054.616] I> RSA PSS signature check: OK
[0054.616] I> oem authentication of eks header done
[0054.619] I> eks: Authentication init Done
[0054.623] I> eks: Authentication Finalize Done
[0054.627] I> EKB detected (length: 0x410) @ VA:0x526fb800
��NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 162: ekb_verification: EKB_CMAC verification is not match.
hwkey-agent: 368: key_mgnt_processing: failed (-7)
hwkey-agent: 45: main: Failed to verify or extract EKB (-7).
exit called, thread 0xffffffffea8a4d58, name trusty_app_2_92b92883-f96a-4177
luks-srv: 40: luks-srv is running!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
/uphy is not enabled status = disabled
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0054.979] I> Welcome to TBoot-CPU Recovery
��WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
��[0054.980] I> Heap: [0xa4000000 ... 0xaa000000
[0054.990] I> gpio framework initialized
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0055.000] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio'
driver
[0055.154] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon'
driver
[0055.159] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0055.168] W> fetch_driver_phandle_from_dt: failed to get node with compatible t
i,tca9539
[0055.176] W> fetch_driver_phandle_from_dt: failed to get node with compatible n
xp,tca9539
[0055.180] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0055.186] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0055.194] W> fetch_driver_phandle_from_dt: failed to get node with compatible t
i,tca9539
[0055.202] W> fetch_driver_phandle_from_dt: failed to get node with compatible n
xp,tca9539
[0055.208] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0055.216] I> fixed regulator driver initialized
[0055.227] I> CPU: Nvidia Carmel
[0055.227] I> CPU: MIDR: 0x4e0f0040, MPIDR: 0x80000000
[0055.228] I> chip revision : A02
[0055.230] I> Boot-device: eMMC
[0055.233] I> Boot_device: SDMMC_BOOT instance: 3
[0055.656] I> sdmmc DDR50 mode
[0055.666] I> sdmmc-3 params source = safe params
[0055.667] I> QSPI source rate = 19200 Khz
[0055.668] I> Requested rate for QSPI clock = 19000 Khz
[0055.668] I> BPMP-set rate for QSPI clk = 19200 Khz
[0055.669] I> QSPI Flash Size = 32 MB
[0055.671] E> CR3V cmd failed, (err:0x0)
[0055.674] I> Qspi initialized successfully
[0055.674] I> qspi flash-0 params source = safe params
[0055.675] I> sdmmc bdev is already initialized
[0055.680] I> sdmmc-3 params source = safe params
[0055.700] W> Cannot find any partition table for 00000003
[0055.713] W> Cannot find any partition table for 00010003
[0055.714] W> Cannot find any partition table for 00030000
[0055.714] I> Recovery boot_type: 0
[0055.715] I> Entering 3p server
[0055.715] I> USB configuration success
[0058.339] I> Populate storage info
[0058.791] I> Erasing device 3: 0
[0058.791] I> QSPI: Erasing entire device
[0061.794] I> Writing device 3: 0.
[0061.876] W> Cannot find any partition table for 00030000
[0061.876] E> NV3P_SERVER: Failed to initialize partition table from GPT.
The only other mention I’ve found about the NV3P_SERVER: Failed to initialize partition table from GPT.
was in this thread, where the advice was to the RMA the board. Seeing as this board worked fine until I enabled SBK/PKC, it seems more likely that I’m getting the error due to something related to that.
Fuses used were: JtagDisable
(0x1), SecureBootKey
, Kek0
, Kek1
, Kek2
, PublicKeyHash
, BootSecurityInfo
(0x6), SwReserved
(0x28), and SecurityMode
(0x1).
Possibly relevant is that I burned the fuses while there was a non-signed/non-encrypted OS on the board.
I’ve also tried using nvmassflashgen.sh
, which results in the same error during the nvaflash.sh
run.
Any ideas on what I’m doing / have done wrong would be appreciated, before I subject a second board to the same treatment.
