We got Xavier NX with DDR :16G SOM recently and try to use the following command to flash our image which is flashed and booted successfully from 8G SOM befor,but if we flash bootloader and rootfs images with one command:
Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c
tools/kernel_flash/flash_l4t_external.xml --showlogs ms-nx-dvt2-nvme internal
our system stops at bootloader logo on monitor screen when startup.
Here is the console log when boot the NX :
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x2
[0000.059] I> rst_source : 0xb
[0000.062] I> rst_level : 0x1
[0000.065] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 32 MB
[0000.082] I> Qspi initialized successfully
[0000.086] I> Active Boot chain : 1
[0000.089] I> Boot-device: QSPI
[0000.092] I> Qspi flash params source = brbct
[0000.098] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.104] I> Temperature = 31500
[0000.107] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.111] W> Skipping boost for clk: BPMP_APB
[0000.115] W> Skipping boost for clk: AXI_CBB
[0000.119] W> Skipping boost for clk: AON_CPU_NIC
[0000.124] W> Skipping boost for clk: CAN1
[0000.127] W> Skipping boost for clk: CAN2
[0000.132] I> Boot-device: QSPI
[0000.134] I> Boot-device: QSPI
[0000.137] I> Qspi flash params source = mb1bct
[0000.141] I> Qspi using bpmp-dma
[0000.144] I> Qspi clock source : pllc_out0
[0000.148] I> Qspi reinitialized
[0000.151] I> Qspi flash params source = mb1bct
[0000.156] I> ECC region[0]: Start:0x0, End:0x0
[0000.161] I> ECC region[1]: Start:0x0, End:0x0
[0000.165] I> ECC region[2]: Start:0x0, End:0x0
[0000.169] I> ECC region[3]: Start:0x0, End:0x0
[0000.173] I> ECC region[4]: Start:0x0, End:0x0
[0000.177] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.183] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.187] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.192] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.196] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.202] E> FAILED: Thermal config
[0000.209] E> FAILED: MEMIO rail config
[0000.221] I> Boot-device: QSPI
[0000.224] I> Qspi flash params source = mb1bct
[0000.233] I> Qspi flash params source = mb1bct
[0000.245] I> Qspi flash params source = mb1bct
[0000.311] I> Qspi flash params source = mb1bct
[0000.320] I> Qspi flash params source = mb1bct
[0000.349] I> Qspi flash params source = mb1bct
[0000.361] I> MB1 done
main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.369] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8cd8)
[0000.370] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.370] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.371] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.377] W> device prod register failed
[0000.381] I> Boot-device: QSPI
[0000.384] I> Boot_device: QSPI_FLASH instance: 0
[0000.389] I> QSPI Flash Size = 32 MB
[0000.394] I> Qspi initialized successfully
[0000.395] I> qspi flash-0 params source = boot args
[0000.405] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.406] I> Active Boot chain : 1
[0000.409] I> parsing oem signed section of bpmp-fw header done
[0000.415] I> bpmp-fw binary init read from storage
[0000.420] I> oem authentication of bpmp-fw header done
[0000.433] I> bpmp-fw binary done read from storage
[0000.434] I> bpmp-fw: Authentication init Done
[0000.435] I> parsing oem signed section of cpubl header done
[0000.439] I> cpubl binary init read from storage
[0000.443] I> bpmp-fw: Authentication Finalize Done
[0000.448] I> oem authentication of cpubl header done
[0000.456] I> cpubl binary done read from storage
[0000.457] I> cpubl: Authentication init Done
[0000.461] I> parsing oem signed section of rce header done
[0000.466] I> rce binary init read from storage
[0000.471] I> Relocating BR-BCT
[0000.474] I> cpubl: Authentication Finalize Done
[0000.478] I> oem authentication of rce header done
[0000.483] I> rce binary done read from storage
[0000.487] I> rce: Authentication init Done
[0000.491] I> parsing oem signed section of ape header done
[0000.496] I> ape binary init read from storage
[0000.501] I> rce: Authentication Finalize Done
[0000.505] I> oem authentication of ape header done
[0000.509] I> ape binary done read from storage
[0000.514] I> ape: Authentication init Done
[0000.518] I> parsing oem signed section of tos header done
[0000.523] I> tos binary init read from storage
[0000.527] I> ape: Authentication Finalize Done
[0000.532] I> oem authentication of tos header done
[0000.539] I> tos binary done read from storage
[0000.540] I> tos: Authentication init Done
[0000.545] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.551] I> bpmp-fw-dtb binary init read from storage
[0000.555] I> tos: Authentication Finalize Done
[0000.561] I> oem authentication of bpmp-fw-dtb header done
[0000.565] I> bpmp-fw-dtb binary done read from storage
[0000.570] I> bpmp-fw-dtb: Authentication init Done
[0000.575] I> parsing oem signed section of cpubl-dtb header done
[0000.581] I> cpubl-dtb binary init read from storage
[0000.585] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.637] I> oem authentication of cpubl-dtb header done
[0000.638] I> cpubl-dtb binary done read from storage
[0000.638] I> cpubl-dtb: Authentication init Done
[0000.639] I> parsing oem signed section of eks header done
[0000.640] I> eks binary init read from storage
[0000.641] I> cpubl-dtb: Authentication Finalize Done
[0000.641] I> oem authentication of eks header done
[0000.646] I> eks binary done read from storage
[0000.650] I> eks: Authentication init Done
[0000.654] I> eks: Authentication Finalize Done
[0000.658] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc_init: Missing emc dt table!
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
��mrq initialized
��[0001.001] I> Welcome to Cboot
[0001.002] I> Cboot Version: t194-6bce4f5b
��WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
��[0001.002] I> CPU-BL Params @ 0xf2820000
[0001.008] I> 0) Base:0x00000000 Size:0x00000000
[0001.012] I> 1) Base:0xf1100000 Size:0x00100000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
��[0001.017] I> 2) Base:0xf2000000 Size:0x00200000
��clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
��[0001.032] I> 3) Base:0xf1200000 Size:0x00200000
��ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
��[0001.055] I> 4) Base:0xf1000000 Size:0x00100000
[0001.099] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.104] I> 6) Base:0xf3800000 Size:0x00400000
[0001.108] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.112] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.117] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.121] I> 10) Base:0xf3000000 Size:0x00800000
[0001.126] I> 11) Base:0x40000000 Size:0x00040000
[0001.130] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.135] I> 13) Base:0x40046000 Size:0x00002000
[0001.139] I> 14) Base:0x40048000 Size:0x00002000
��Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs_t194_init: no EMC tables, aborting
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.144] I> 15) Base:0xac000000 Size:0x00004000
[0001.234] I> 16) Base:0x4004a000 Size:0x00002000
[0001.239] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.243] I> 18) Base:0x4004c000 Size:0x00002000
[0001.248] I> 19) Base:0xf2200000 Size:0x00600000
[0001.252] I> 20) Base:0x4004e000 Size:0x00002000
[0001.256] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.261] I> 22) Base:0x00000000 Size:0x00000000
[0001.265] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.270] I> 24) Base:0xf6000000 Size:0x02000000
[0001.274] I> 25) Base:0x40050000 Size:0x00002000
[0001.279] I> 26) Base:0x40040000 Size:0x00006000
[0001.283] I> 27) Base:0xf1800000 Size:0x00400000
[0001.288] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.292] I> 29) Base:0xf1400000 Size:0x00400000
[0001.297] I> 30) Base:0x00000000 Size:0x00000000
[0001.301] I> 31) Base:0x00000000 Size:0x00000000
[0001.306] I> 32) Base:0xf8000000 Size:0x08000000
[0001.310] I> 33) Base:0x00000000 Size:0x00000000
[0001.314] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.319] I> 35) Base:0xab000000 Size:0x01000000
[0001.323] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.328] I> 37) Base:0xf2800000 Size:0x00800000
[0001.332] I> 38) Base:0x80000000 Size:0x20000000
[0001.337] I> 39) Base:0xb0000000 Size:0x08000000
[0001.341] I> 40) Base:0x00000000 Size:0x00000000
[0001.346] I> 41) Base:0x00000000 Size:0x00000000
[0001.350] I> 42) Base:0x00000000 Size:0x00000000
[0001.355] I> 43) Base:0x00000000 Size:0x00000000
[0001.359] I> 44) Base:0x00000000 Size:0x00000000
[0001.364] I> 45) Base:0x00000000 Size:0x00000000
[0001.368] GIC-SPI Target CPU: 0
[0001.371] Interrupts Init done
[0001.374] calling constructors
[0001.377] initializing heap
[0001.379] I> Heap: [0xa0699b50 ... 0xab000000]
[0001.384] initializing threads
[0001.387] initializing timers
[0001.389] creating bootstrap completion thread
[0001.394] top of bootstrap2()
[0001.396] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.401] initializing platform
[0001.404] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.410] W> device prod register failed
[0001.413] I> Bl_dtb @0xaaf00000
[0001.418] W> "plugin-manager" doesn't exist, creating
[0001.421] W> "ids" doesn't exist, creating
[0001.425] W> "connection" doesn't exist, creating
[0001.430] W> "configs" doesn't exist, creating
[0001.440] E> failed to read label property for node 168136: 13
[0001.443] E> failed to read reg property for node 168200: 13
[0001.448] E> failed to read reg property for node 168252: 13
[0001.454] E> failed to read reg property for node 168336: 13
[0001.460] I> Find /i2c@3160000's alias i2c0
[0001.460] I> Reading eeprom i2c=0 address=0x50
[0001.491] I> Device at /i2c@3160000:0x50
[0001.492] I> Reading eeprom i2c=0 address=0x57
[0001.516] I> Device at /i2c@3160000:0x57
[0001.519] I> Find /i2c@c240000's alias i2c1
[0001.519] I> Reading eeprom i2c=1 address=0x50
[0001.522] E> I2C: slave not found in slaves.
[0001.522] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.524] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.524] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.530] E> eeprom: Retry to read I2C slave device.
[0001.535] E> I2C: slave not found in slaves.
[0001.539] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.547] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.553] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.562] E> eeprom: Failed to read I2C slave device
[0001.567] I> Eeprom read failed 0x3526070d
[0001.571] I> create_pm_ids: id: 3668-0003-301-B, len: 15
[0001.576] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.587] I> create_pm_ids: id: emmc-nvme-28X-b, len: 15
[0001.592] I> config: mem-type:30,power-config:32,misc-config:2b,modem-config:4f,touch-config:42,display-config:2d,, len: 93
[0001.603] I> Adding plugin-manager/ids/3668-0003-301=/i2c@3160000:module@0x50
[0001.611] W> "i2c@3160000" doesn't exist, creating
[0001.615] W> "module@0x50" doesn't exist, creating
[0001.620] I> Adding plugin-manager/ids/emmc-nvme-28X=/i2c@3160000:module@0x57
[0001.627] W> "module@0x57" doesn't exist, creating
[0001.633] I> Adding plugin-manager/cvm
[0001.635] W> "chip-id" doesn't exist, creating
[0001.639] I> Adding plugin-manager/chip-id/A02P
[0001.644] I> Plugin-manager override starting
[0001.649] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.657] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.664] I> Disable plugin-manager status in FDT
[0001.665] I> Plugin-manager override finished successfully
[0001.669] I> gpio framework initialized
[0001.674] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.681] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.688] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.695] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.703] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.710] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.716] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.723] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.730] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.737] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.744] I> fixed regulator driver initialized
[0001.751] I> register 'maxim' power off handle
[0001.752] I> virtual i2c enabled
[0001.755] I> registered 'maxim,max20024' pmic
[0001.759] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.766] I> Boot-device: QSPI
[0001.769] I> Boot_device: QSPI_FLASH instance: 0
[0001.775] I> QSPI source rate = 204000 Khz
[0001.777] I> Requested rate for QSPI clock = 34000 Khz
[0001.783] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.788] I> QSPI Flash Size = 32 MB
[0001.795] I> Qspi initialized successfully
[0001.796] I> qspi flash-0 params source = boot args
[0001.799] I> create_pm_ids: id: 3668-0003-301-B, len: 15
[0001.804] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.815] I> create_pm_ids: id: emmc-nvme-28X-b, len: 15
[0001.820] I> config: mem-type:30,power-config:32,misc-config:2b,modem-config:4f,touch-config:42,display-config:2d,, len: 93
[0001.832] E> Invalid SKU: 3!
[0001.836] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0001.850] I> regulator 'vdd-hdmi-5v0' already enabled
[0001.855] I> regulator 'vdd-hdmi-5v0' already enabled
[0001.855] I> hdmi cable connected
[0001.856] W> set volts not configured for 'vdd-1v0'
[0001.859] W> set volts not configured for 'vdd-1v8-hs'
[0001.862] I> retrieved tmds range from prod_list_hdmi_soc
[0001.870] E> invalid display type
[0001.871] E> cannot find any other nvdisp nodes
[0001.891] I> edid read success
[0001.904] I> edid read success
[0001.904] I> width = 640, height = 480, frequency = 25174825
[0001.905] I> width = 640, height = 480, frequency = 25174825
[0001.905] I> width = 1920, height = 1080, frequency = 148500000
[0001.906] I> width = 1600, height = 900, frequency = 97750000
[0001.909] I> width = 1280, height = 720, frequency = 74250000
[0001.915] I> width = 1920, height = 1080, frequency = 148351648
[0001.921] I> width = 1920, height = 1080, frequency = 148351648
[0001.927] I> width = 1280, height = 720, frequency = 74175824
[0001.932] I> width = 1280, height = 720, frequency = 74175824
[0001.938] I> width = 720, height = 480, frequency = 26973026
[0001.943] I> width = 720, height = 576, frequency = 26973026
[0001.949] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0001.984] I> Load in CBoot Boot Options partition and parse it
[0001.985] E> Error -9 when finding node with path /boot-configuration
[0001.986] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0001.986] I> Using default boot order
[0001.988] I> boot-dev-order :-
[0001.991] I> 1.sd
[0001.992] I> 2.usb
[0001.994] I> 3.nvme
[0001.996] I> 4.emmc
[0001.998] I> 5.net
[0002.000] I> Hit any key to stop autoboot: 4 3 2 1
[0004.008] initializing target
[0004.009] calling apps_init()
[0004.009] starting app kernel_boot_app
[0004.022] I> found decompressor handler: lz4-legacy
[0004.022] I> decompressing BMP blob ...
[0004.031] I> Kernel type = Normal
[0004.031] I> ########## SD (0) boot ##########
[0004.031] I> No sdcard
[0004.032] I> -0 params source =
[0004.032] E> Blockdev open: exit error
[0004.032] E> SD boot failed, err: 724238353
[0007.750] I> ########## NVME (0) boot ##########
[0007.754] I> Initializing nvme device instance 0
[0007.759] I> Initializing nvme controller
[0007.763] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0007.769] I> vpcie3v3-supply not found
[0007.773] I> vpcie12v-supply not found
[0007.776] W> Failed to get nvidia,plat-gpios
[0007.780] I> tegrabl_pcie_soc_preinit: (0):
[0007.784] I> Unpowergate
[0007.787] I> tegrabl_car_clk_disable(0) ...
[0007.791] I> tegrabl_car_rst_set(CORE, 0) ...
[0007.795] I> tegrabl_car_rst_set(APB, 0) ...
[0007.799] I> tegrabl_car_clk_enable(0) ...
[0007.803] I> tegrabl_car_rst_clear(APB, 0) ...
[0007.807] I> tegrabl_set_ctrl_state(0)
[0007.811] I> CLR PCIE_APB:6
[0007.814] I> tegrabl_pcie_soc_init: (0):
[0007.817] I> APPL initialization ...
[0007.821] I> poweron phys
[0007.823] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0007.830] I> tegrabl_power_on_phy: controller 0 not available
[0007.835] E> Failed to power on phy on controller-0
[0007.841] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0007.845] I> Failed to initialize SoC Host PCIe controller
[0007.850] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x1
[0007.857] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0007.863] W> Failed to open NVME-0, err = 80800601
[0007.868] W> Failed to initialize device 10-0
[0007.872] E> NVME (0) boot failed, err: 0x80800601
[0007.877] I> ########## NVME (1) boot ##########
[0007.881] I> Initializing nvme device instance 1
[0007.885] I> Initializing nvme controller
[0007.889] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0007.896] I> vpcie3v3-supply not found
[0007.899] I> vpcie12v-supply not found
[0007.903] W> Failed to get nvidia,plat-gpios
[0007.907] I> tegrabl_pcie_soc_preinit: (1):
[0007.911] I> Unpowergate
[0007.914] I> tegrabl_car_clk_disable(1) ...
[0007.917] I> tegrabl_car_rst_set(CORE, 1) ...
[0007.922] I> tegrabl_car_rst_set(APB, 1) ...
[0007.926] I> tegrabl_car_clk_enable(1) ...
[0007.930] I> tegrabl_car_rst_clear(APB, 1) ...
[0007.934] I> tegrabl_set_ctrl_state(1)
[0007.938] I> CLR PCIE_APB:6
[0007.940] I> tegrabl_pcie_soc_init: (1):
[0007.944] I> APPL initialization ...
[0007.947] I> poweron phys
[0007.950] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0007.956] I> tegrabl_power_on_phy: controller 1 not available
[0007.962] E> Failed to power on phy on controller-1
[0007.967] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0007.971] I> Failed to initialize SoC Host PCIe controller
[0007.977] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(1); error=0x1
[0007.983] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0007.990] W> Failed to open NVME-1, err = 80800601
[0007.994] W> Failed to initialize device 10-1
[0007.999] E> NVME (1) boot failed, err: 0x80800601
[0008.003] I> ########## NVME (2) boot ##########
[0008.008] I> Initializing nvme device instance 2
[0008.012] I> Initializing nvme controller
[0008.016] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0008.022] I> vpcie3v3-supply not found
[0008.026] I> vpcie12v-supply not found
[0008.030] W> Failed to get nvidia,plat-gpios
[0008.034] I> tegrabl_pcie_soc_preinit: (2):
[0008.038] I> Unpowergate
[0008.040] I> tegrabl_car_clk_disable(2) ...
[0008.044] I> tegrabl_car_rst_set(CORE, 2) ...
[0008.048] I> tegrabl_car_rst_set(APB, 2) ...
[0008.052] I> tegrabl_car_clk_enable(2) ...
[0008.056] I> tegrabl_car_rst_clear(APB, 2) ...
[0008.061] I> tegrabl_set_ctrl_state(2)
[0008.064] I> CLR PCIE_APB:6
[0008.067] I> tegrabl_pcie_soc_init: (2):
[0008.071] I> APPL initialization ...
[0008.074] I> poweron phys
[0008.077] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0008.083] I> tegrabl_power_on_phy: controller 2 not available
[0008.088] E> Failed to power on phy on controller-2
[0008.094] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0008.098] I> Failed to initialize SoC Host PCIe controller
[0008.103] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0008.110] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0008.116] W> Failed to open NVME-2, err = 80800601
[0008.121] W> Failed to initialize device 10-2
[0008.125] E> NVME (2) boot failed, err: 0x80800601
[0008.130] I> ########## NVME (3) boot ##########
[0008.134] I> Initializing nvme device instance 3
[0008.139] I> Initializing nvme controller
[0008.143] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0008.149] I> vpcie3v3-supply not found
[0008.153] I> vpcie12v-supply not found
[0008.156] W> Failed to get nvidia,plat-gpios
[0008.160] I> tegrabl_pcie_soc_preinit: (3):
[0008.164] I> Unpowergate
[0008.167] I> tegrabl_car_clk_disable(3) ...
[0008.171] I> tegrabl_car_rst_set(CORE, 3) ...
[0008.175] I> tegrabl_car_rst_set(APB, 3) ...
[0008.179] I> tegrabl_car_clk_enable(3) ...
[0008.183] I> tegrabl_car_rst_clear(APB, 3) ...
[0008.187] I> tegrabl_set_ctrl_state(3)
[0008.191] I> CLR PCIE_APB:6
[0008.194] I> tegrabl_pcie_soc_init: (3):
[0008.197] I> APPL initialization ...
[0008.201] I> poweron phys
[0008.203] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0008.209] I> tegrabl_power_on_phy: controller 3 not available
[0008.215] E> Failed to power on phy on controller-3
[0008.220] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0008.225] I> Failed to initialize SoC Host PCIe controller
[0008.230] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(3); error=0x1
[0008.236] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0008.243] W> Failed to open NVME-3, err = 80800601
[0008.248] W> Failed to initialize device 10-3
[0008.252] E> NVME (3) boot failed, err: 0x80800601
[0008.256] I> ########## NVME (4) boot ##########
[0008.261] I> Initializing nvme device instance 4
[0008.265] I> Initializing nvme controller
[0008.270] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0008.276] I> vpcie3v3-supply not found
[0008.279] I> vpcie12v-supply not found
[0008.283] W> Failed to get nvidia,plat-gpios
[0008.287] I> tegrabl_pcie_soc_preinit: (4):
[0008.291] I> Unpowergate
[0008.294] I> tegrabl_car_clk_disable(4) ...
[0008.297] I> tegrabl_car_rst_set(CORE, 4) ...
[0008.302] I> tegrabl_car_rst_set(APB, 4) ...
[0008.306] I> tegrabl_car_clk_enable(4) ...
[0008.310] I> tegrabl_car_rst_clear(APB, 4) ...
[0008.314] I> tegrabl_set_ctrl_state(4)
[0008.317] I> CLR PCIE_APB:6
[0008.320] I> tegrabl_pcie_soc_init: (4):
[0008.324] I> APPL initialization ...
[0008.327] I> poweron phys
[0008.330] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0008.336] I> tegrabl_power_on_phy: power on phy @0x3f40000
[0009.441] C> Failed to link up controller-4
[0009.443] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0009.443] I> Failed to initialize SoC Host PCIe controller
[0009.443] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(4); error=0x12
[0009.444] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0009.444] W> Failed to open NVME-4, err = 80800612
[0009.448] W> Failed to initialize device 10-4
[0009.453] E> NVME (4) boot failed, err: 0x80800612
[0009.457] I> ########## NVME (5) boot ##########
[0009.462] I> Initializing nvme device instance 5
[0009.466] I> Initializing nvme controller
[0009.471] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0009.476] I> vpcie3v3-supply not found
[0009.480] I> vpcie12v-supply not found
[0009.484] W> Failed to get nvidia,plat-gpios
[0009.488] I> tegrabl_pcie_soc_preinit: (5):
[0009.492] I> Unpowergate
[0009.495] I> tegrabl_car_clk_disable(5) ...
[0009.498] I> tegrabl_car_rst_set(CORE, 5) ...
[0009.503] I> tegrabl_car_rst_set(APB, 5) ...
[0009.507] I> tegrabl_car_clk_enable(5) ...
[0009.511] I> tegrabl_car_rst_clear(APB, 5) ...
[0009.515] I> tegrabl_set_ctrl_state(5)
[0009.518] I> CLR PCIE_APB:6
[0009.521] I> tegrabl_pcie_soc_init: (5):
[0009.525] I> APPL initialization ...
[0009.528] I> poweron phys
[0009.531] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0009.537] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0009.542] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0009.548] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0009.553] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0009.558] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0009.564] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0009.569] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0009.574] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0009.709] I> PCIe controller-5 link is up
[0009.710] I> tegra_pcie_info[5].cfg0_base = 0x3a000000
[0009.710] I> tegra_pcie_info[5].cfg1_base = 0x3a020000
[0009.711] I> tegra_pcie_info[5].atu_dma_base = 0x3a040000
[0009.711] I> tegra_pcie_bus[5].mem = 0x3a200000
[0009.711] I> Scanning busnr: 0 devfn: 0
[0009.712] I> PCIe IDs: 0x1ad010de
[0009.715] I> PCIe RID_CC: 0x60400a1
[0009.718] I> Scanning busnr: 1 devfn: 0
[0009.722] I> PCIe IDs: 0xf1a68086
[0009.725] I> PCIe RID_CC: 0x1080203
[0009.728] I> PCI Config: I/O=0x3a100000, Memory=0x3a200000
[0009.734] I> MEM64 bar_num=0 bar=0x3a200000
[0009.738] I> Number of PCIe devices detected: 2
[0009.742] I> NVME page size: 4096
[0009.746] I> NVMe serial number: PHHH0112025E128A
[0009.750] I> NVMe model number: INTEL SSDPEKKW128G8
[0009.757] I> NVMe firmware revision: 004C
[0009.761] I> block_count: 250069680
[0009.764] I> supported_lba: 0
[0009.767] I> block_size_log2: 0x9
[0009.770] I> tegrabl_create_io_queue_cmd: queue size: 2
[0009.775] I> tegrabl_create_io_queue_cmd: queue size: 2
[0009.780] I> nvme device id 000a0005
[0009.784] I> nvme-5 params source =
[0009.788] I> Found 12 partitions in NVME (instance 5)
[0009.792] I> Look for boot partition
[0009.795] I> Fallback: assuming 0th partition is boot partition
[0009.801] I> Set 1th partition is boot partition
[0009.806] I> Detect filesystem
[0009.809] I> Loading kernel-bootctrl from partition
[0009.813] I> Loading partition kernel-bootctrl at 0xa15a0000 from device(0xa)
[0009.822] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0009.827] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0009.834] I> Loading extlinux.conf ...
[0009.838] I> Loading extlinux.conf binary from rootfs ...
[0009.843] I> rootfs path: /nvme/boot/extlinux/extlinux.conf
[0009.849] I> Loading extlinux.conf sig file from rootfs ...
[0009.854] I> rootfs path: /nvme/boot/extlinux/extlinux.conf.sig
[0009.860] I> Validate extlinux.conf ...
[0009.863] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0009.870] I> Encryption fuse is not ON
[0009.874] I> L4T boot options
[0009.877] I> [1]: "primary kernel"
[0009.880] I> Enter choice:
[0010.883] I> Continuing with default option: 1
[0010.883] I> Loading kernel ...
[0010.883] I> Loading kernel binary from rootfs ...
[0010.884] I> rootfs path: /nvme/boot/Image
[0011.079] I> Loading kernel sig file from rootfs ...
[0011.080] I> rootfs path: /nvme/boot/Image.sig
[0011.081] I> overload load_size to 34484232 (from 34484240)
[0011.081] I> Validate kernel ...
[0011.082] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0011.396] I> Encryption fuse is not ON
[0011.448] I> Loading kernel-dtb ...
[0011.448] I> No kernel-dtb binary path
[0011.449] I> Continue to load from partition ...
[0011.449] I> A/B: bin_type (38) slot 1
[0011.449] I> Loading kernel-dtb_b from partition
[0011.450] I> Loading partition kernel-dtb_b at 0x91000000 from device(0xa)
[0011.457] I> Validate kernel-dtb ...
[0011.457] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0011.462] I> Encryption fuse is not ON
[0011.466] I> Loading ramdisk from rootfs ...
[0011.467] I> Loading ramdisk binary from rootfs ...
[0011.472] I> rootfs path: /nvme/boot/initrd
[0011.517] I> Loading ramdisk sig file from rootfs ...
[0011.518] I> rootfs path: /nvme/boot/initrd.sig
[0011.519] I> overload load_size to 7238344 (from 7238352)
[0011.519] I> Validate ramdisk ...
[0011.519] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0011.586] I> Encryption fuse is not ON
[0011.627] I> removable_boot_load_kernel_and_dtb: force NVME bdev to close !!!
[0011.628] I> Kernel hdr @0xa15a0000
[0011.628] I> Kernel dtb @0x90000000
[0011.628] I> decompressor handler not found
[0011.629] I> Copying kernel image (34484232 bytes) from 0xa15a0000 to 0x80080000 ... [0011.661] I> Done
[0011.662] I> Updated bpmp info to DTB
[0011.663] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0011.664] I> Updated initrd info to DTB
[0011.664] W> WARN: Fail to override "console=none" in commandline
[0011.664] I> Active rootfs suffix: _b
[0011.665] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.667] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.674] I> Active slot suffix: _b
[0011.677] I> add_boot_slot_suffix: slot_suffix = _b
[0011.682] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix=_b tegra_fbmem=0x800000@0xa06a4000 lut_mem=0x2008@0xa069f000 usbcore.ol
[0011.712] I> Updated bootarg info to DTB
[0011.716] W> MAC addr invalid!
[0011.719] E> Failed to get WIFI MAC address
[0011.723] W> MAC addr invalid!
[0011.725] E> Failed to get Bluetooth MAC address
[0011.730] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:5f:97:a7
[0011.736] W> "plugin-manager" doesn't exist, creating
[0011.741] I> Adding /chosen/plugin-manager/cvm
[0011.745] W> "chip-id" doesn't exist, creating
[0011.749] I> Adding /chosen/plugin-manager/chip-id
[0011.754] W> "configs" doesn't exist, creating
[0011.758] I> Adding /chosen/plugin-manager/configs
[0011.763] W> "ids" doesn't exist, creating
[0011.767] I> Adding /chosen/plugin-manager/ids
[0011.772] W> "odm-data" doesn't exist, creating
[0011.776] I> Adding /chosen/plugin-manager/odm-data
[0011.783] W> "memory" doesn't exist, creating
[0011.785] I> [0] START: 0x80000000, END: 0xac000000
[0011.789] I> [1] START: 0xac004000, END: 0xf0ad0000
[0011.794] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0011.799] I> dram_block larger than 80000000
[0011.803] I> [3] START: 0x100000000, END: 0x480000000
[0011.808] I> added [base:0x80000000, size:0x2c000000] to /memory
[0011.814] I> added [base:0xac200000, size:0x44800000] to /memory
[0011.819] I> added [base:0x100000000, size:0x380000000] to /memory
[0011.826] I> Updated memory info to DTB
[0011.829] E> add_disp_param: failed to get display params for du=1
[0011.835] W> "reset" doesn't exist, creating
[0011.840] I> Adding ecid(00000001642db1892000000007018280) to DT
[0011.845] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.850] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0011.855] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0011.859] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.864] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0011.869] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0011.874] I> Deleted cpu@6 node in DT
[0011.877] I> Deleted cpu@7 node in DT
[0011.881] I> Deleted cluster3 node in FDT
[0011.885] I> Update arm-pmu in FDT
[0011.888] I> - update property: interrupts
[0011.892] I> - update property: interrupt-affinity
[0011.897] W> "misc-data" doesn't exist, creating
[0011.901] I> Boot-device: QSPI
[0011.904] W> Unknown boot device
[0011.907] I> Add storage-qspi to plugin-manager/misc-data
[0011.912] I> Add serial number:1420122068300 as DT property
[0011.918] I> Plugin-manager override starting
[0011.922] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0011.929] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0011.936] I> Disable plugin-manager status in FDT
[0011.937] I> Plugin-manager override finished successfully
[0011.943] I> tegrabl_load_kernel_and_dtb: Done
[0011.948] I> SMD partition is updated.
[0011.951] I> QSPI: erasing sectors from 177 - 177
[0011.955] I> QSPI: recoverying tail blocks from 22664 - 22784
[0012.615] I> QSPI: erasing sectors from 176 - 176
[0012.615] I> QSPI: recoverying tail blocks from 22536 - 22656
[0013.303] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5497-d3000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) )1
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06a4000
[ 0.000000] Found lut_mem: 00002008@a069f000
[ 2.000062] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
[ 2.000162] tegradc 15200000.nvdisplay: failed to register ihub bw client
[ 2.004831] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
[ 2.004891] tegradc 15210000.nvdisplay: failed to register ihub bw client
[ 2.540409] lt6911uxc 0-002b: probing lt6911uxc v4l2 sensor at addr 0x2b
[ 2.540849] lt6911uxc 0-002b: Failed to find matching dt id
[ 2.541032] lt6911uxc 0-002b: unable to get platform data
[ 2.541150] lt6911uxc 0-002b: tegra camera driver registration failed
[ 2.541789] lt6911uxc 1-002b: probing lt6911uxc v4l2 sensor at addr 0x2b
[ 2.542045] lt6911uxc 1-002b: Failed to find matching dt id
[ 2.542163] lt6911uxc 1-002b: unable to get platform data
[ 2.542286] lt6911uxc 1-002b: tegra camera driver registration failed
[ 3.902140] lt6911uxc 8-002b: probing lt6911uxc v4l2 sensor at addr 0x2b
[ 3.902501] lt6911uxc 8-002b: Failed to find matching dt id
[ 3.902633] lt6911uxc 8-002b: unable to get platform data
[ 3.902760] lt6911uxc 8-002b: tegra camera driver registration failed
WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
[ 5.425745] cgroup: cgroup2: unknown option "nsdelegate"
[ 7.552438] random: crng init done
[ 7.552656] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.298813] using random self ethernet address
[ 8.299028] using random host ethernet address
[ 9.660666] using random self ethernet address
[ 9.660909] using random host ethernet address
[ 11.752273] Bridge firewalling registered
and the kern log as follows:
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5497-d3000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jul 26 12:19:28 PDT 2021
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 4128253
[ 0.000000] DMA zone: 7160 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 458237 pages, LIFO batch:31
[ 0.000000] Normal zone: 57344 pages used for memmap
[ 0.000000] Normal zone: 3670016 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4063749
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix=_b tegra_fbmem=0x800000@0xa06a4000 lut_mem=0x2008@0xa069f000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix=_b boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=PARTUUID=3b7db058-7f1b-45a1-808d-9a2a72f09740 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29932(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 15427668K/16513012K available (15358K kernel code, 2956K rwdata, 6692K rodata, 8640K init, 612K bss, 331680K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000009] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001142] Console: colour dummy device 80x25
[ 0.001161] console [tty0] enabled
[ 0.001173] bootconsole [tegra_comb_uart0] disabled
[ 0.001202] kmemleak: Kernel memory leak detector disabled
[ 0.001237] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001256] pid_max: default: 32768 minimum: 301
[ 0.002447] Security Framework initialized
[ 0.003318] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.003333] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.005959] ftrace: allocating 47077 entries in 184 pages
[ 0.452494] sched-energy: Sched-energy-costs installed from DT
[ 0.452554] ASID allocator initialised with 65536 entries
[ 0.493700] tegra-id: chipid=21917.
[ 0.493733] tegra-id: opt_subrevision=1.
[ 0.493779] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.493812] DTS File Name: /home/zyf/code_new/bsp/Linux_for_Metis/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/eswin/platform/t19x/jakku/kernel-dts/D01-11-P02-02-OB-D01-QSPI-EMMC-NVME128.dts
[ 0.493827] DTB Build time: Feb 22 2022 09:28:46
[ 0.544700] CPU1: Booted secondary processor [4e0f0040]
[ 0.577057] CPU2: Booted secondary processor [4e0f0040]
[ 0.608953] CPU3: Booted secondary processor [4e0f0040]
[ 0.641483] CPU4: Booted secondary processor [4e0f0040]
[ 0.673304] CPU5: Booted secondary processor [4e0f0040]
[ 0.673637] Brought up 6 CPUs
[ 0.673658] SMP: Total of 6 processors activated.
[ 0.673674] CPU features: detected feature: Privileged Access Never
[ 0.673681] CPU features: detected feature: LSE atomic instructions
[ 0.673689] CPU features: detected feature: User Access Override
[ 0.673695] CPU features: detected feature: 32-bit EL0 Support
[ 0.677500] CPU: All CPU(s) started at EL2
[ 0.677600] alternatives: patching kernel code
[ 0.702367] devtmpfs: initialized
[ 0.746266] Initilizing CustomIPI irq domain
[ 0.746668] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.746698] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.773942] pinctrl core: initialized pinctrl subsystem
[ 0.774654] OS set in device tree is not L4T.
[ 0.775301] regulator-dummy: no parameters
[ 0.775703] Initializing plugin-manager
[ 0.775898] Plugin module not found
[ 0.775948] Plugin-manager status disabled
[ 0.778515] NET: Registered protocol family 16
[ 0.780897] pstore: using zlib compression
[ 0.780951] console [pstore-1] enabled
[ 0.780960] pstore: Registered ramoops as persistent store backend
[ 0.780970] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.800074] cpuidle: using governor menu
[ 0.802651] bpmp: waiting for handshake
[ 0.802671] bpmp: handshake completed
[ 0.802702] bpmp: synchronizing channels
[ 0.802748] bpmp: channels synchronized
[ 0.802758] bpmp: mail init ok
[ 0.806566] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.806796] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.806803] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.806810] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.806816] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.806860] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.806872] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.806881] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.806888] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.806895] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.806902] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.811855] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[ 0.811969] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.815787] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.818205] tegra_aon_clk_init: ok
[ 0.818228] Registering BPMP clocks...
[ 0.818502] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.819654] Serial: AMBA PL011 UART driver
[ 0.820252] tegra_powergate_init: DONE
[ 0.820363] DTS File Name: /home/zyf/code_new/bsp/Linux_for_Metis/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/eswin/platform/t19x/jakku/kernel-dts/D01-11-P02-02-OB-D01-QSPI-EMMC-NVME128.dts
[ 0.820394] DTB Build time: Feb 22 2022 09:28:46
[ 0.825288] Tegra reboot handler registered.
[ 0.835278] iommu: Adding device 14160000.pcie to group 0
[ 0.836420] iommu: Adding device 141a0000.pcie to group 1
[ 0.838549] iommu: Adding device 2490000.ether_qos to group 2
[ 0.839511] iommu: Adding device 3100000.serial to group 3
[ 0.840335] iommu: Adding device 3110000.serial to group 4
[ 0.840972] iommu: Adding device 3140000.serial to group 5
[ 0.841883] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.842192] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.842228] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.842241] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.842251] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.842343] tegra-pmc: PMC Prod config success
[ 0.842777] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.842795] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.843190] iommu: Adding device 3460000.sdhci to group 6
[ 0.843958] iommu: Adding device 3400000.sdhci to group 7
[ 0.844765] iommu: Adding device 3210000.spi to group 8
[ 0.845243] iommu: Adding device 3230000.spi to group 9
[ 0.845977] iommu: Adding device 3270000.spi to group 10
[ 0.847491] iommu: Adding device 3160000.i2c to group 11
[ 0.848147] iommu: Adding device c240000.i2c to group 12
[ 0.848720] iommu: Adding device 3180000.i2c to group 13
[ 0.849222] iommu: Adding device 3190000.i2c to group 14
[ 0.849852] iommu: Adding device 31b0000.i2c to group 15
[ 0.850287] iommu: Adding device 31c0000.i2c to group 16
[ 0.850716] iommu: Adding device c250000.i2c to group 17
[ 0.851215] iommu: Adding device 31e0000.i2c to group 18
[ 0.851822] iommu: Adding device sound to group 19
[ 0.852654] iommu: Adding device 3510000.hda to group 20
[ 0.853409] iommu: Adding device bc00000.rtcpu to group 21
[ 0.856010] iommu: Adding device 13e10000.host1x to group 22
[ 0.856800] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.857309] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.857912] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.858418] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.859015] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.859551] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.860135] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 0.860759] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 0.861476] iommu: Adding device 15340000.vic to group 31
[ 0.862072] iommu: Adding device 15380000.nvjpg to group 32
[ 0.862393] iommu: Adding device 15500000.tsec to group 33
[ 0.862704] iommu: Adding device 15100000.tsecb to group 34
[ 0.863044] iommu: Adding device 15480000.nvdec to group 35
[ 0.863360] iommu: Adding device 15140000.nvdec1 to group 36
[ 0.863723] iommu: Adding device 154c0000.nvenc to group 37
[ 0.864107] iommu: Adding device 15a80000.nvenc1 to group 38
[ 0.864794] iommu: Adding device 15880000.nvdla0 to group 39
[ 0.865334] iommu: Adding device 158c0000.nvdla1 to group 40
[ 0.866069] iommu: Adding device 15200000.nvdisplay to group 41
[ 0.866428] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06a4000(800000)
[ 0.866444] platform 15200000.nvdisplay: IOVA linear map 0x00000000a069f000(3000)
[ 0.871946] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.872208] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.873673] iommu: Adding device 15210000.nvdisplay to group 42
[ 0.873796] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.875965] iommu: Adding device 15c10000.vi to group 43
[ 0.876276] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.876740] iommu: Adding device 14800000.isp to group 44
[ 0.878012] iommu: Adding device 16000000.pva0 to group 45
[ 0.878897] iommu: Adding device 16800000.pva1 to group 46
[ 0.879477] iommu: Adding device 15810000.se to group 47
[ 0.879987] iommu: Adding device 15820000.se to group 48
[ 0.880355] iommu: Adding device 15830000.se to group 49
[ 0.880717] iommu: Adding device 15840000.se to group 50
[ 0.881021] iommu: Adding device c1a0000.aon to group 51
[ 0.883110] iommu: Adding device d000000.bpmp to group 52
[ 0.884052] bpmp: ping status is 0
[ 0.884427] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.892206] bpmp d000000.bpmp: probe ok
[ 0.894731] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.895338] iommu: Adding device smmu_test to group 53
[ 0.897074] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c10000
[ 0.897109] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c20000
[ 0.897135] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c30000
[ 0.897172] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c40000
[ 0.897193] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2c50000
[ 0.897215] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b80000
[ 0.897238] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2b90000
[ 0.897258] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2ba0000
[ 0.897278] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x2bb0000
[ 0.897297] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1700000
[ 0.897316] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1710000
[ 0.897339] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1720000
[ 0.897360] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1730000
[ 0.897381] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1740000
[ 0.897400] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1750000
[ 0.897421] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1760000
[ 0.897481] mc: mapped MMIO address: 0xffffff800b1b0000 -> 0x1770000
[ 0.897661] mc-err: mcerr ops are set to t19x
[ 0.904550] iommu: Adding device 2600000.dma to group 54
[ 0.910076] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.911543] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.912079] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.921675] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.921808] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.921861] GPIO line 266 (w-disable1) hogged as output/high
[ 0.921905] GPIO line 264 (w-disable2) hogged as output/high
[ 0.921945] GPIO line 265 (suspend-led-gpio) hogged as output/high
[ 0.922390] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.925357] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.925376] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.925386] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.926491] iommu: Adding device 3550000.xudc to group 55
[ 0.927451] iommu: Adding device 3610000.xhci to group 56
[ 0.929921] arm64_ras arm64_ras: probed
[ 0.930567] ras_fhi_enable: FHI 470 enabled on CPU0
[ 0.930710] ras_fhi_enable: FHI 471 enabled on CPU1
[ 0.930842] ras_fhi_enable: FHI 472 enabled on CPU2
[ 0.930982] ras_fhi_enable: FHI 473 enabled on CPU3
[ 0.931110] ras_fhi_enable: FHI 474 enabled on CPU4
[ 0.931255] ras_fhi_enable: FHI 475 enabled on CPU5
[ 0.931748] carmel_ras_enable: RAS enabled on cpu0
[ 0.932129] carmel_ras_enable: RAS enabled on cpu1
[ 0.932521] carmel_ras_enable: RAS enabled on cpu2
[ 0.932905] carmel_ras_enable: RAS enabled on cpu3
[ 0.933357] carmel_ras_enable: RAS enabled on cpu4
[ 0.933754] carmel_ras_enable: RAS enabled on cpu5
[ 0.933984] carmel_ras carmel_ras: probed
[ 0.936672] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.937548] tegra-cbb c600000.aon-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.938852] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.940253] tegra-cbb be00000.rce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.941460] tegra-cbb b600000.sce-noc: noc_secure_irq = 487, noc_nonsecure_irq = 486>
[ 0.942152] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.943856] vdd-ac-bat: 5000 mV
[ 0.944639] vdd-sdmmc1-sw: 3300 mV
[ 0.945143] vdd-1v8-sd: 1800 mV
[ 0.945770] vdd-3v3-cvb: 3300 mV
[ 0.946123] vdd-1v8-cvb: 1800 mV
[ 0.946495] vdd-epb-1v0: 1000 mV
[ 0.946850] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.947252] avdd-cam-2v8: 2800 mV
[ 0.947635] vdd-fan: 5000 mV
[ 0.948066] vdd-hdmi-5v0: 5000 mV
[ 0.948447] vdd_sys_en: 1200 mV
[ 0.997128] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.005458] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.005963] SCSI subsystem initialized
[ 1.006450] libata version 3.00 loaded.
[ 1.007021] usbcore: registered new interface driver usbfs
[ 1.007095] usbcore: registered new interface driver hub
[ 1.007170] usbcore: registered new device driver usb
[ 1.035754] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.040669] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[ 1.051453] vdd-1v0: at 1000 mV
[ 1.059488] vdd-1v8-hs: at 1800 mV
[ 1.067521] vdd-1v8-ls: at 1800 mV
[ 1.075715] vdd-1v8-ao: at 1800 mV
[ 1.080884] vddio-ddr-1v1: at 1100 mV
[ 1.087324] vdd-rtc: at 800 mV
[ 1.088900] spmic-ldo1: at 2375 mV
[ 1.096662] vdd-ao-3v3: at 3300 mV
[ 1.104693] vddio-emmc-3v3: at 3300 mV
[ 1.106125] spmic-ldo4: at 1587 mV
[ 1.112757] vdd-usb-3v3: at 3300 mV
[ 1.120795] vddio-sdmmc1-3v3: at 3300 mV
[ 1.124833] vdd-csi-1v2: at 1200 mV
[ 1.126130] spmic-ldo8: at 1800 mV
[ 1.132245] GPIO line 246 (gpio_default) hogged as output/high
[ 1.133578] GPIO line 247 (gpio_default) hogged as output/high
[ 1.134177] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.134576] max77620 4-003c: max77620 probe successful
[ 1.135568] media: Linux media interface: v0.10
[ 1.135656] Linux video capture interface: v2.00
[ 1.138210] pps_core: LinuxPPS API ver. 1 registered
[ 1.138220] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.138250] PTP clock support registered
[ 1.138594] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 1.139090] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.139133] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.142760] trusty trusty: trusty version: Built: 12:20:34 Jul 26 2021
[ 1.142871] trusty trusty: selected api version: 3 (requested 3)
[ 1.144851] Advanced Linux Sound Architecture Driver Initialized.
[ 1.145860] Bluetooth: Core ver 2.22
[ 1.145954] NET: Registered protocol family 31
[ 1.145960] Bluetooth: HCI device and connection manager initialized
[ 1.145983] Bluetooth: HCI socket layer initialized
[ 1.145996] Bluetooth: L2CAP socket layer initialized
[ 1.146049] Bluetooth: SCO socket layer initialized
[ 1.151479] camchar: rtcpu character device driver loaded
[ 1.153079] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 1.153264] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 1.155907] clocksource: Switched to clocksource arch_sys_counter
[ 1.217463] VFS: Disk quotas dquot_6.6.0
[ 1.217751] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.218474] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.220864] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.220932] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.221587] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.221599] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.221628] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.221643] nvmap_page_pool_init: Total RAM pages: 4045333
[ 1.221651] nvmap_page_pool_init: nvmap page pool size: 505666 pages (1975 MB)
[ 1.222326] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.223797] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.227070] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.244848] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.245128] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.245403] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.245720] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.245970] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.247719] la/ptsa driver initialized.
[ 1.248335] NET: Registered protocol family 2
[ 1.249725] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.250454] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.251204] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.251390] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.251659] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.252810] NET: Registered protocol family 1
[ 1.254145] RPC: Registered named UNIX socket transport module.
[ 1.254157] RPC: Registered udp transport module.
[ 1.254163] RPC: Registered tcp transport module.
[ 1.254169] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.254200] PCI: CLS 0 bytes, default 64
[ 1.254981] Trying to unpack rootfs image as initramfs...
[ 1.511775] Freeing initrd memory: 7068K
[ 1.549159] host1x 13e10000.host1x: initialized
[ 1.554106] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.562790] audit: initializing netlink subsys (disabled)
[ 1.562964] audit: type=2000 audit(1.120:1): initialized
[ 1.564304] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.578159] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.580160] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.581085] 9p: Installing v9fs 9p2000 file system support
[ 1.588942] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.589183] io scheduler noop registered
[ 1.589512] io scheduler cfq registered (default)
[ 1.597626] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.599599] random: fast init done
[ 1.655825] iommu: Adding device 2993000.adsp to group 57
[ 1.829944] iommu: Adding device aconnect@2a41000:adsp_audio to group 58
[ 1.831525] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.854038] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.854963] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.856257] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.857168] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.857871] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.863177] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.863591] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=5625000, max_bw=5625000
[ 1.869553] tsec 15500000.tsec: initialized
[ 1.872840] tsec 15100000.tsecb: initialized
[ 1.880000] nvdec 15480000.nvdec: initialized
[ 1.885207] nvdec 15140000.nvdec1: initialized
[ 1.895206] falcon 15340000.vic: initialized
[ 1.899104] falcon 15380000.nvjpg: initialized
[ 1.902666] falcon 154c0000.nvenc: initialized
[ 1.906379] falcon 15a80000.nvenc1: initialized
[ 1.910041] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.912507] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.915928] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.918441] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.920645] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.922969] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.925129] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.927811] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.934847] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.944787] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.945459] scare-pigeon 14b00000.isp-thi: initialized
[ 1.956907] pva 16000000.pva0: initialized
[ 1.968232] pva 16800000.pva1: initialized
[ 1.977631] nvdla 15880000.nvdla0: initialized
[ 1.986241] nvdla 158c0000.nvdla1: initialized
[ 1.989519] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.989552] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.989671] tegradccommon 15200000.dc_common: dma mapping done
[ 1.990157] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=78
[ 1.990185] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.990809] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.990856] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.991280] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.991292] tegra_cec 3960000.tegra_cec: probed
[ 1.992438] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.992547] generic_infoframe_type: 0x87
[ 1.992716] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.992792] tegradc 15200000.nvdisplay: Display dc.ffffff800bd50000 registered with id=0
[ 2.000618] tegradc: probe of 15200000.nvdisplay failed with error -7
[ 2.001837] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor
[ 2.001910] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 2.002110] tegradc 15210000.nvdisplay: DT parsed successfully
[ 2.002179] tegradc 15210000.nvdisplay: Display dc.ffffff800bdd0000 registered with id=0
[ 2.005232] tegradc: probe of 15210000.nvdisplay failed with error -7
[ 2.012230] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 2.013646] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 2.013659] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 2.014186] kfuse 3830000.kfuse: initialized
[ 2.021937] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.026033] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 2.028692] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 2.030775] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 2.034258] console [ttyTCU0] enabled
[ 2.035414] [drm] Initialized
[ 2.053568] brd: module loaded
[ 2.061444] loop: module loaded
[ 2.061598] tegra_profiler: version: 1.145, samples/io: 49/28
[ 2.061841] tegra_profiler: auth: init
[ 2.064098] THERMAL EST: found 3 subdevs
[ 2.064114] THERMAL EST num_resources: 0
[ 2.064123] [THERMAL EST subdev 0]
[ 2.064136] [THERMAL EST subdev 1]
[ 2.064146] [THERMAL EST subdev 2]
[ 2.064166] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.064839] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 2.064849] THERMAL EST: thz register success.
[ 2.065187] THERMAL EST: end of probe, return err: 0
[ 2.066745] sd: No Scsi addr parsed to reserve index
[ 2.066804] hisi_sas: driver version v1.6
[ 2.089280] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 2.089299] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 2.089311] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 2.089651] 1 ofpart partitions found on MTD device spi6.0
[ 2.089660] Creating 1 MTD partitions on "spi6.0":
[ 2.089697] 0x000000000000-0x000002000000 : "Whole_flash0"
[ 2.094856] libphy: Fixed MDIO Bus: probed
[ 2.096802] tun: Universal TUN/TAP device driver, 1.6
[ 2.096811] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.098168] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.098177] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.098245] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.098250] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.098297] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 2.098301] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 2.098353] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 2.098358] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 2.350378] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 2.351436] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 5f 97 a7
[ 2.351476] Using phyrst_lpmode = 1 from DT
[ 2.351892] libphy: dwc_phy: probed
[ 2.358602] PPP generic driver version 2.4.2
[ 2.359302] PPP BSD Compression module registered
[ 2.359319] PPP Deflate Compression module registered
[ 2.359391] PPP MPPE Compression module registered
[ 2.359402] NET: Registered protocol family 24
[ 2.359665] usbcore: registered new interface driver r8152
[ 2.359894] usbcore: registered new interface driver asix
[ 2.360007] usbcore: registered new interface driver ax88179_178a
[ 2.360042] usbcore: registered new interface driver cdc_ether
[ 2.360090] usbcore: registered new interface driver net1080
[ 2.360126] usbcore: registered new interface driver cdc_subset
[ 2.360252] usbcore: registered new interface driver zaurus
[ 2.360316] usbcore: registered new interface driver cdc_ncm
[ 2.361125] VFIO - User Level meta-driver version: 0.3
[ 2.363716] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.363872] ehci-pci: EHCI PCI platform driver
[ 2.363948] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.363971] ohci-pci: OHCI PCI platform driver
[ 2.364027] ohci-platform: OHCI generic platform driver
[ 2.372980] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 2.376578] tegra-xusb 3610000.xhci: extcon 0: ffffffc3ec0cc000 id
[ 2.378793] usbcore: registered new interface driver uas
[ 2.378892] usbcore: registered new interface driver usb-storage
[ 2.379053] usbcore: registered new interface driver usbserial
[ 2.379851] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 2.379944] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 2.380005] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 2.381071] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 2.381172] tegra-xusb 3610000.xhci: irq 465, io mem 0x03610000
[ 2.382698] hub 1-0:1.0: USB hub found
[ 2.382771] hub 1-0:1.0: 4 ports detected
[ 2.384004] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 2.384026] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 2.384046] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.384453] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.384492] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.384501] usb usb2: Product: xHCI Host Controller
[ 2.384512] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 2.384521] usb usb2: SerialNumber: 3610000.xhci
[ 2.385597] hub 2-0:1.0: USB hub found
[ 2.385652] hub 2-0:1.0: 4 ports detected
[ 2.387145] Wake76 for irq=199
[ 2.387154] Wake77 for irq=199
[ 2.387158] Wake78 for irq=199
[ 2.387163] Wake79 for irq=199
[ 2.387167] Wake80 for irq=199
[ 2.387171] Wake81 for irq=199
[ 2.387175] Wake82 for irq=199
[ 2.387235] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 2.387247] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 2.387881] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 2.388060] tegra-xudc-new 3550000.xudc: device count: 1
[ 2.389714] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 2.389809] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 2.390317] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 2.390335] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 2.392523] mousedev: PS/2 mouse device common for all mice
[ 2.392713] usbcore: registered new interface driver xpad
[ 2.488412] usb usb2: usb_suspend_both: status 0
[ 2.530925] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.534237] Wake73 for irq=42
[ 2.535948] rtc rtc1: alarm rtc device
[ 2.535989] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.536069] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.536522] i2c /dev entries driver
[ 2.541473] lt6911uxc: probe of 0-002b failed with error -14
[ 2.542520] lt6911uxc: probe of 1-002b failed with error -14
[ 2.543938] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 2.556200] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 2.627890] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.630637] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.631086] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.635559] usbcore: registered new interface driver usbhid
[ 2.635568] usbhid: USB HID core driver
[ 2.641003] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 2.641234] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.643432] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 2.648322] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.649773] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.651236] denver_knobs_init:MTS_VERSION:53250041
[ 2.652183] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 2.654274] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.655083] t19x_cache tegra-cache: probed
[ 2.661552] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 2.661584] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 2.663836] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 2.664763] PLL_AON clock registered
[ 2.669631] Clocks initialized successfully
[ 2.674609] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 2.676369] nvpmodel: initialized successfully
[ 2.681176] trusty-virtio trusty:virtio: initializing
[ 2.681676] trusty_ipc virtio0: vring0: va(pa) ffffffc3ecf80000(0) qsz 32 notifyid 1
[ 2.681706] trusty_ipc virtio0: vring1: va(pa) ffffffc3ecf82000(0) qsz 32 notifyid 2
[ 2.682108] trusty-virtio trusty:virtio: initializing done
[ 2.682861] trusty_ipc virtio0: is online
[ 2.687354] tegra-hda 3510000.hda: Override SDO lines to 4
[ 2.688853] usbcore: registered new interface driver snd-usb-audio
[ 2.689613] mmc0: periodic cache flush enabled
[ 2.689682] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.691635] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 2.696648] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 2.701802] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 2.702640] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 2.708104] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.708979] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.709465] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.710248] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.711345] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.729481] usb 1-2: New USB device found, idVendor=0424, idProduct=2744
[ 2.729494] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.729516] usb 1-2: Product: USB2744
[ 2.914830] OPE platform probe
[ 2.915136] OPE platform probe successful
[ 2.987989] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 2.995953] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 3.011048] hub 1-3:1.0: 4 ports detected
[ 3.037553] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.037821] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.038063] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.038293] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.038554] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.038833] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.039015] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.039191] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.039369] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.039581] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.039937] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 3.040172] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 3.040373] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 3.040555] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 3.040740] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 3.040956] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 3.041194] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 3.041416] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 3.041606] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 3.041874] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 3.093780] u32 classifier
[ 3.093803] Actions configured
[ 3.094039] Initializing XFRM netlink socket
[ 3.095053] NET: Registered protocol family 10
[ 3.097674] NET: Registered protocol family 17
[ 3.097719] NET: Registered protocol family 15
[ 3.097868] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.098197] 9pnet: Installing 9P2000 support
[ 3.098377] Key type dns_resolver registered
[ 3.098813] Registered cp15_barrier emulation handler
[ 3.098876] Registered setend emulation handler
[ 3.102035] registered taskstats version 1
[ 3.103357] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 3.106763] OF: PCI: host bridge /pcie@14160000 ranges:
[ 3.106838] OF: PCI: IO 0x36100000..0x361fffff -> 0x36100000
[ 3.106877] OF: PCI: MEM 0x1740000000..0x17ffffffff -> 0x40000000
[ 3.106898] OF: PCI: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 3.303919] usb 1-3.1: new full-speed USB device number 4 using tegra-xusb
[ 3.329547] usb 1-3.1: New USB device found, idVendor=08bb, idProduct=29c3
[ 3.329556] usb 1-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.329563] usb 1-3.1: Product: USB AUDIO CODEC
[ 3.329568] usb 1-3.1: Manufacturer: BurrBrown from Texas Instruments
[ 3.358278] input: BurrBrown from Texas Instruments USB AUDIO CODEC as /devices/3610000.xhci/usb1/1-3/1-3.1/1-3.1:1.3/0003:08BB:29C3.0001/input/input4
[ 3.416891] hid-generic 0003:08BB:29C3.0001: input,hidraw0: USB HID v1.00 Device [BurrBrown from Texas Instruments USB AUDIO CODEC] on usb-3610000.xhci-3.1/input3
[ 3.436081] usb 1-2.3: new high-speed USB device number 5 using tegra-xusb
[ 3.456591] usb 1-2.3: New USB device found, idVendor=1a40, idProduct=0101
[ 3.456600] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.456605] usb 1-2.3: Product: USB 2.0 Hub
[ 3.458166] hub 1-2.3:1.0: USB hub found
[ 3.458289] hub 1-2.3:1.0: 4 ports detected
[ 3.463911] usb 2-3: usb_suspend_both: status 0
[ 3.464180] usb usb2: usb_suspend_both: status 0
[ 3.536048] usb 1-3.4: new full-speed USB device number 6 using tegra-xusb
[ 3.558905] usb 1-3.4: New USB device found, idVendor=10c4, idProduct=ea60
[ 3.558913] usb 1-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.558919] usb 1-3.4: Product: CP2102N USB to UART Bridge Controller
[ 3.558925] usb 1-3.4: Manufacturer: Silicon Labs
[ 3.558929] usb 1-3.4: SerialNumber: fc3169ae29aeea11a689ffef80b3c4aa
[ 3.622407] tegra-pcie-dw 14160000.pcie: link is down
[ 3.622806] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 3.622826] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 3.622860] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 3.622874] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 3.622878] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 3.622947] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 3.623196] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.624123] iommu: Adding device 0004:00:00.0 to group 59
[ 3.624704] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 3.624750] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 3.625243] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 3.625253] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 3.625418] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 3.626027] pcie_pme 0004:00:00.0:pcie001: unloading service driver pcie_pme
[ 3.626183] aer 0004:00:00.0:pcie002: unloading service driver aer
[ 3.626635] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 3.626786] iommu: Removing device 0004:00:00.0 from group 59
[ 3.626874] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 3.629375] tegra-pcie-dw 14160000.pcie: PCIe link is not up...!
[ 3.631269] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 3.631843] tegra-pcie-dw 141a0000.pcie: Failed to get 3V slot regulator: -19
[ 3.631871] tegra-pcie-dw 141a0000.pcie: Failed to get 12V slot regulator: -19
[ 3.657470] usb 1-2.5: New USB device found, idVendor=0424, idProduct=2740
[ 3.657480] usb 1-2.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.657486] usb 1-2.5: Product: Hub Controller
[ 3.657489] usb 1-2.5: Manufacturer: Microchip Tech
[ 3.741137] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 3.741231] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 3.741262] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 3.741277] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 3.788381] usb 1-2.3.1: Product: HP USB Optical Mouse
[ 3.788386] usb 1-2.3.1: Manufacturer: PixArt
[ 3.792630] input: PixArt HP USB Optical Mouse as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3.1/1-2.3.1:1.0/0003:03F0:134A.0002/input/input5
[ 3.793375] hid-generic 0003:03F0:134A.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt HP USB Optical Mouse] on usb-3610000.xhci-2.3.1/input0
[ 3.851950] tegra-pcie-dw 141a0000.pcie: link is up
[ 3.852594] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 3.852617] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 3.852650] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 3.852664] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 3.852673] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 3.852734] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 3.853018] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.853775] iommu: Adding device 0005:00:00.0 to group 59
[ 3.854574] pci 0005:01:00.0: [8086:f1a6] type 00 class 0x010802
[ 3.854748] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 3.856232] iommu: Adding device 0005:01:00.0 to group 60
[ 3.869443] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 3.869459] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 3.869551] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 3.869589] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 3.869616] pci 0005:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 3.869676] pci 0005:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 3.870215] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 3.870221] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.870229] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 3.870452] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 3.871275] nvme nvme0: pci function 0005:01:00.0
[ 3.871384] nvme 0005:01:00.0: enabling device (0000 -> 0002)
[ 3.891622] tegra-cbb 14040000.cv-noc: noc_secure_irq = 91, noc_nonsecure_irq = 90>
[ 3.892993] usb 1-2.3.2: new low-speed USB device number 9 using tegra-xusb
[ 3.903138] lt6911uxc: probe of 8-002b failed with error -14
[ 3.909526] tegra194-isp5 14800000.isp: initialized
[ 3.922336] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 3.924374] usb 1-2.3.2: New USB device found, idVendor=046d, idProduct=c31c
[ 3.924384] usb 1-2.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.924390] usb 1-2.3.2: Product: USB Keyboard
[ 3.924395] usb 1-2.3.2: Manufacturer: Logitech
[ 3.933492] input: Logitech USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3.2/1-2.3.2:1.0/0003:046D:C31C.0003/input/input6
[ 3.934618] tegra194-vi5 15c10000.vi: initialized
[ 3.942859] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--3 bound
[ 3.943015] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[ 3.943090] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[ 3.944114] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 3.951892] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 3.951961] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 3.951967] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 3.952284] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 3.952361] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 3.952369] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 3.957535] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 3.957690] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 3.957699] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 3.958449] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 3.958560] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 3.958565] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 3.959709] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 3.959918] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 3.959925] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 3.960721] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 3.964345] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.993935] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3610000.xhci-2.3.2/input0
[ 3.996425] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 4.001444] input: Logitech USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3.2/1-2.3.2:1.1/0003:046D:C31C.0004/input/input7
[ 4.061049] hid-generic 0003:046D:C31C.0004: input,hidraw3: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3610000.xhci-2.3.2/input1
[ 4.313753] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 4.315179] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.315711] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 4.316151] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 4.317207] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 4.317525] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 4.318166] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (66)
[ 4.318173] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.320244] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=06bdc710c3c9a48de2881774602bbcf4d0114a58
[ 4.321770] Wake83 for irq=211
[ 4.321980] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 4.322148] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 4.322480] input: gpio-keys as /devices/gpio-keys/input/input8
[ 4.357324] tegra_rtc c2a0000.rtc: setting system clock to 2022-02-22 03:37:02 UTC (1645501022)
[ 4.359251] mmcblk mmc0:0001: Card claimed for testing.
[ 4.440180] bpmp: mounted debugfs mirror
[ 4.457755] ALSA device list:
[ 4.457774] #0: tegra-hda-xnx at 0x3518000 irq 65
[ 4.457779] #1: jetson-xaviernx-ape
[ 4.457785] #2: BurrBrown from Texas Instruments USB AUDIO CODEC at usb-3610000.xhci-3.1, full
[ 4.464664] Freeing unused kernel memory: 8640K
[ 4.545222] Root device found: PARTUUID=3b7db058-7f1b-45a1-808d-9a2a72f09740
[ 5.240919] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.260521] Rootfs mounted over PARTUUID=3b7db058-7f1b-45a1-808d-9a2a72f09740
[ 5.301447] Switching from initrd to actual rootfs
[ 5.420333] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.438457] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.440154] systemd[1]: Detected architecture arm64.
[ 5.453612] systemd[1]: No hostname configured.
[ 5.453662] systemd[1]: Set hostname to <localhost>.
[ 5.590528] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 5.590558] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 5.748409] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.749323] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.749634] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.749792] systemd[1]: Reached target Swap.
[ 5.749896] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.749940] systemd[1]: Reached target User and Group Name Lookups.
[ 5.751562] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.831321] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
[ 5.984175] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 6.326815] systemd-journald[2356]: Received request to flush runtime journal from PID 1
[ 8.876624] cpu-throttle-alert cooling device registered.
[ 8.911244] gpu-throttle-alert cooling device registered.
[ 8.928175] aux-throttle-alert cooling device registered.
[ 9.586866] Mass Storage Function, version: 2009/09/11
[ 9.586900] LUN: removable file: (no medium)
[ 9.802499] rndis0: HOST MAC 12:0c:32:da:34:cc
[ 9.804771] rndis0: MAC 12:0c:32:da:34:cd
[ 9.812060] usb0: HOST MAC 12:0c:32:da:34:ce
[ 9.813942] usb0: MAC 12:0c:32:da:34:cf
[ 9.814113] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 9.849237] l4tbr0: port 1(rndis0) entered blocking state
[ 9.849264] l4tbr0: port 1(rndis0) entered disabled state
[ 9.862487] device rndis0 entered promiscuous mode
[ 9.940143] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 9.973890] l4tbr0: port 2(usb0) entered blocking state
[ 9.973917] l4tbr0: port 2(usb0) entered disabled state
[ 9.974598] device usb0 entered promiscuous mode
[ 9.977766] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.012885] android_work: did not send uevent (0 0 (null))
[ 10.242041] configfs-gadget gadget: high-speed config #1: c
[ 10.242144] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 10.242171] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 10.242195] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 10.242466] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 10.242495] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 10.242517] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 10.242604] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 10.242815] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 10.242867] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 10.242935] android_work: sent uevent USB_STATE=CONFIGURED
[ 10.246849] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 10.246880] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 10.256863] tegra-xudc-new 3550000.xudc: ep 13 disabled
[ 10.256922] tegra-xudc-new 3550000.xudc: ep 8 disabled
[ 10.274866] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 10.274905] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 10.294153] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 10.303008] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.303303] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 10.783308] usbcore: registered new interface driver cp210x
[ 10.783522] usbserial: USB Serial support registered for cp210x
[ 10.786757] cp210x 1-3.4:1.0: cp210x converter detected
[ 10.794398] usb 1-3.4: cp210x converter now attached to ttyUSB0
[ 11.796659] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 12.987260] Netfilter messages via NETLINK v0.30.
[ 12.992712] ctnetlink v0.93: registering with nfnetlink.
[ 13.187364] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.188915] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.555131] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 15.969763] l4tbr0: port 2(usb0) entered blocking state
[ 15.969795] l4tbr0: port 2(usb0) entered forwarding state
[ 15.970070] l4tbr0: port 1(rndis0) entered blocking state
[ 15.970087] l4tbr0: port 1(rndis0) entered forwarding state
[ 15.970387] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 15.970447] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 26.080795] ras_fhi_disable: FHI 474 disabled
[ 26.082853] CPU4: shutdown
[ 26.084246] psci: CPU4 killed (polled 4 ms)
[ 26.128660] ras_fhi_disable: FHI 475 disabled
[ 26.132272] CPU5: shutdown
[ 26.133728] psci: CPU5 killed (polled 0 ms)
However, the system startups and runs normally after we flash bootloader image using command separately:
Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.sh -c tools/kernel_flash/flash_l4t_external.xml --showlogs ms-nx-dvt2-nvme internal.
and we want know what the difference is between these 2 commands when they are flashing bootloader images.
thanks,
