With increasing adoption and deployment of AI in industrial and edge/embedded systems, NVIDIA is announcing the following product updates:
1H2021 - Industrial version of the Jetson AGX Xavier module that is form factor, pin and software compatible
April, 2020 - Updated Jetson AGX Xavier module with memory increased to 32GB for support of increasingly complex AI models and accelerated computing algorithms
Now - The Jetson AGX Xavier Developer Kit is updated with the same memory increase to 32GB
Now - The Jetson Nano Developer Kit is updated to support the production Jetson Nano module and the upcoming Jetson Xavier NX module
Details about the new industrial Jetson AGX Xavier module (Available 1H2021)
Suitable for industrial environments with extended temperature range, increased shock and vibration specifications and 10 year operational lifetime
100% form factor, pin, and software compatible with other Jetson AGX Xavier series modules
Includes 32 GB of memory with support for ECC
Designed for safety with internal Safety Cluster Engine (SCE): a dedicated ARM® Cortex®-R5F subsystem for integrated fault detection mechanisms, lock-step subsystems, and in-field self tests
Functional safety documentation package for integration in industrial and robotics safety related systems (early access in 2H2020 upon request).
Support for an external safety MCU
Details about the updated Jetson AGX Xavier module (Available April 2020 Now) Part Number 900-82888-0040-000 replaces previous version (PN: 900-82888-0000-000)
Memory increased from 16 GB to 32 GB
Price stays the same: $899 (1KU+)
Details about the updated Jetson AGX Xavier Developer Kit (Available Now) Part Number 945-82972-004n-000 replaces previous version (PN: 945-82972-000n-000)
Price stays the same: $699
Details about the updated Jetson Nano Developer Kit (Available Now) Part Number 945-13450-0000-100 replaces previous version (PN: 945-13450-0000-000)
Supports production Jetson Nano module
Supports production Jetson Xavier NX module (Available March 2020 Now)
2nd CSI Camera connector
Full design files available now at Jetson Download Center
I assume the new Nano developer kit will allow simultaneous access to both CSI camera connectors. If so, how will this be supported? Is there a demo example?
Referring to “Jetson Nano Developer Kit is updated to support the production Jetson Nano module and the upcoming Jetson Xavier NX module”, does it affect the code that was developed with older Nano devices?
Sure. You can use gst-launch-1.0 command like here except sensor-id=5 in that example would become sensor-id=1 for your second camera (and deprecated nvcamerasrc replaced with nvarguscamerasrc):
What is the name of the new Jetson Nano revision and where can we find design files for the most recent revision of the Jetson Nano? So far, I’ve only been able to find the previous design (B01, I think it is) and I haven’t been able to locate the desired documentation for the newest revision.
It appears that, with the addition of the second camera, the 8 pin button header has been moved underneath the processor which, unfortunately, means there’s not actually enough space for the headers in most Jetson Nano cases. It appears I won’t be able to actually use any of the buttons without doing some soldering due to the new design.
Is the assumption that anyone who plans on using the new button header location will need a larger case size to utilize it since the pins themselves have been moved to the edge of the board (rather than moving them further back to give them space to use header pins)?
The new revision of the Jetson Nano Developer Kit is identified by part number 945-13450-0000-100. It includes:
non-production specification Jetson Nano module P3448-0000 with PCB revision B01
Reference carrier board P3449 with PCB revision B01
The same B01 revision PCB is used by this P3448-0000 module and by the P3448-0002 production module. (There are differences in components, though. The most obvious is that P3448-0000 stuffs microSD Card slot, whereas P3448-0002 stuffs eMMC.)
The P3449 B01 carrier board supports any Jetson Nano module with PCB revision B01.
