Flashing BSP issue on Xavier NX 16GB
Hi @WayneWWW
Thanks for the cooperation. I actually found the bug.
It was in the documentation where they specified SW3 is for Force recovery and SW4 is for the power button, but it is vice versa.
I am able to flash the board successfully by using
sudo ./install.sh
Actually I have no idea about what you are talking about. If the error is just you pressed the wrong button, then what you are telling now also not match to the error symptom.
But anyway, glad you can use it now.
Hi @WayneWWW
Actually I successfully flashed the board using
sudo ./install.sh
it got flashed on EMMC. But I need to flash on NVME or SDCARD. I also tried to reflash again for SDCARD and it got no error and flashed successful. But when I start the board it got stuck on NVIDIA logo screen. I think I need to clear the emmc first to reflash for NVME/SDCARD. So if you can guide me on how to do that.
I also tried this thread but it didnt work.
No, you don’t and should not clear emmc first to reflash nvme. Just follow the steps from your board vendor.
Yes I have and successfully flashed on sdcard as the logs says
*  Step 1: Build the flashing environment    *
Create flash environment 0
~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
Finish creating flash environment 0.
*  Step 2: Boot the device with flash initrd image *
~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/temp_initrdflash/bootloader0 ~/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
./tegraflash.py --bl nvtboot_recovery_cpu_t194_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x19 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "mb2_bootloader nvtboot_recovery_t194_sigheader.bin.encrypt; mts_preboot preboot_c10_prod_cr_sigheader.bin.encrypt; mts_mce mce_c10_prod_cr_sigheader.bin.encrypt; mts_proper mts_c10_prod_cr_sigheader.bin.encrypt; bpmp_fw bpmp_t194_sigheader.bin.encrypt; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt; spe_fw spe_t194_sigheader.bin.encrypt; tlk tos-trusty_t194_sigheader.img.encrypt; eks eks_sigheader.img.encrypt; kernel boot0.img; kernel_dtb kernel_tegra194-p3668-all-p3509-0000.dtb; bootloader_dtb tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt"    --ramcode 1  --instance 1-3 --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0000 ] rcm boot with presigned binaries
[   0.0000 ] Boot Rom communication
[   0.0023 ] tegrarcm_v2 --instance 1-3 --chip 0x19 0 --rcm rcm_1_encrypt.rcm --rcm rcm_2_encrypt.rcm --skipuid
[   0.0030 ] Boot Rom communication completed
[   1.0254 ]
[   2.0313 ] tegrarcm_v2 --instance 1-3 --isapplet
[   2.0339 ] Applet version 01.00.0000
[   2.0751 ]
[   2.0751 ] Sending BCTs
[   2.0779 ] tegrarcm_v2 --instance 1-3 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   2.0801 ] Applet version 01.00.0000
[   2.1045 ] Sending bct_bootrom
[   2.1046 ] [................................................] 100%
[   2.1057 ] Sending bct_mb1
[   2.1114 ] [................................................] 100%
[   2.1154 ] Sending bct_mem
[   2.1657 ] [................................................] 100%
[   2.2429 ]
[   2.2430 ] Generating blob
[   2.2489 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[   2.2511 ] number of images in blob are 13
[   2.2522 ] blobsize is 61180568
[   2.2526 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 263840
[   2.2976 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 181152
[   2.2980 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[   2.2984 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 143200
[   2.2991 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[   2.3003 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[   2.3016 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt of size 391616
[   2.3020 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[   2.3023 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 410560
[   2.3026 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[   2.3028 ] Added binary blob_boot0.img of size 54976512
[   2.3308 ] Added binary blob_kernel_tegra194-p3668-all-p3509-0000.dtb of size 199248
[   2.3459 ] Added binary blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of size 203344
[   2.3807 ]
[   2.3808 ] Sending bootloader and pre-requisite binaries
[   2.3830 ] tegrarcm_v2 --instance 1-3 --download blob blob.bin
[   2.3836 ] Applet version 01.00.0000
[   2.3992 ] Sending blob
[   2.3992 ] [                                                ] 001%
[   2.3992 ] [.                                               ] 003%
[   2.3992 ] [..                                              ] 005%
[   2.3992 ] [...                                             ] 006%
[   2.3992 ] [....                                            ] 008%
[   2.3992 ] [.....                                           ] 010%
[   2.3992 ] [.....                                           ] 011%
[   2.3992 ] [......                                          ] 013%
[   2.3992 ] [.......                                         ] 015%
[   2.3992 ] [........                                        ] 017%
[   2.3992 ] [.........                                       ] 018%
[   2.3992 ] [..........                                      ] 020%
[   2.3992 ] [...........                                     ] 022%
[   2.3992 ] [...........                                     ] 023%
[   2.3992 ] [............                                    ] 025%
[   2.3992 ] [.............                                   ] 027%
[   2.3992 ] [..............                                  ] 029%
[   2.3992 ] [...............                                 ] 030%
[   2.3992 ] [................                                ] 032%
[   2.3992 ] [.................                               ] 034%
[   2.3992 ] [.................                               ] 035%
[   2.3992 ] [..................                              ] 037%
[   2.3992 ] [...................                             ] 039%
[   2.3992 ] [....................                            ] 041%
[   2.3992 ] [.....................                           ] 042%
[   2.3992 ] [......................                          ] 044%
[   2.3992 ] [.......................                         ] 046%
[   2.3992 ] [.......................                         ] 047%
[   2.3992 ] [........................                        ] 049%
[   2.3992 ] [.........................                       ] 051%
[   2.3992 ] [..........................                      ] 053%
[   2.3992 ] [...........................                     ] 054%
[   2.3992 ] [............................                    ] 056%
[   2.3992 ] [.............................                   ] 058%
[   2.3992 ] [.............................                   ] 059%
[   2.3992 ] [..............................                  ] 061%
[   2.3992 ] [...............................                 ] 063%
[   2.3992 ] [................................                ] 065%
[   2.3992 ] [.................................               ] 066%
[   2.3992 ] [..................................              ] 068%
[   2.3992 ] [...................................             ] 070%
[   2.3992 ] [...................................             ] 071%
[   2.3992 ] [....................................            ] 073%
[   2.3992 ] [.....................................           ] 075%
[   2.3992 ] [......................................          ] 077%
[   2.3992 ] [.......................................         ] 078%
[   2.3992 ] [........................................        ] 080%
[   2.3992 ] [.........................................       ] 082%
[   2.3992 ] [.........................................       ] 083%
[   2.3992 ] [..........................................      ] 085%
[   2.3992 ] [...........................................     ] 087%
[   2.3992 ] [............................................    ] 089%
[   2.3992 ] [.............................................   ] 090%
[   2.3992 ] [..............................................  ] 092%
[   2.3992 ] [............................................... ] 094%
[   2.3992 ] [............................................... ] 095%
[   2.3992 ] [................................................] 097%
[   2.3992 ] [................................................] 099%
[   2.3992 ] [................................................] 100%
[  11.1373 ]
[  11.1428 ] tegrarcm_v2 --instance 1-3 --boot rcm
[  11.1467 ] Applet version 01.00.0000
[  11.1788 ]
[  11.1788 ] RCM-boot started
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ...Run command: if [ -f /qspi/l4t_flash_from_kernel.sh ]; then USER=root /qspi/l4t_flash_from_kernel.sh --no-reboot --qspi-only ; fi on root@fe80::1%enp0s20f0u3
4194304
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/flash.idx
Number of lines is 62
max_index=61
4194304
Flash index file is /qspi/internal/flash.idx
max_index=61
[ 0]: l4t_flash_from_kernel: Starting to flash to qspi
Erasing 64 Kibyte @ 0 --  0 % complete writing item=49, 1:3:primary_gpt, 512, 19968, gpt_primary_1_3.bin, 16896, fixed-<reserved>-0, 99948142dfd2190c5bc86f29242f2392e8c55b67
Writing primary_gpt partition with gpt_primary_1_3.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/gpt_primary_1_3.bin of=/dev/sda bs=1 skip=0  seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0153784 s, 1.1 MB/s
Erasing 64 Kibyte @ 10000 --  0 % complete Writing primary_gpt partition done
Erasing 64 Kibyte @ 20000 --  0 % complete
Erasing 64 Kibyte @ 30000 --  0 % complete
Erasing 64 Kibyte @ 40000 --  0 % complete Writing secondary_gpt partition with gpt_secondary_1_3.bin
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/gpt_secondary_1_3.bin of=/dev/sda bs=1 skip=0  seek=15757983232 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0922078 s, 183 kB/s
Writing secondary_gpt partition done
[ 2]: l4t_flash_from_kernel: Successfully create gpt for emmc
[ 2]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/flash.idx
Number of lines is 14
max_index=13
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 4bce7ec3958d9bf37f7ff89b52570ee87f6cf140
Erasing 64 Kibyte @ 50000 --  0 % complete
Erasing 64 Kibyte @ 60000 --  1 % complete Writing primary_gpt partition with gpt_primary_9_0.bin
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_9_0.bin of=/dev/sdd bs=1 skip=0  seek=512 count=16896
Erasing 64 Kibyte @ 70000 --  1 % complete 16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0418926 s, 403 kB/s
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/sdd appears to be used, you can fix the GPT to use all of the space (an extra 4095 blocks) or continue with the current setting?
Erasing 64 Kibyte @ 80000 --  1 % complete
Erasing 64 Kibyte @ 90000 --  1 % complete
Erasing 64 Kibyte @ a0000 --  1 % complete
Erasing 64 Kibyte @ b0000 --  2 % complete Writing secondary_gpt partition with gpt_secondary_9_0.bin
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_9_0.bin of=/dev/sdd bs=1 skip=0  seek=127863340544 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0301809 s, 560 kB/s
Error: The backup GPT table is not at the end of the disk, as it should be.  Fix, by moving the backup to the end (and removing the old backup)?
Fix/Ignore? Fix
Fix/Ignore? Fix
Erasing 64 Kibyte @ c0000 --  2 % complete Model: ext0 0 (scsi)
Disk /dev/sdd: 128GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End    Size    File system  Name               Flags
 1      20.5kB  118GB  118GB                APP                msftdata
 2      118GB   118GB  67.1MB               kernel             msftdata
 3      118GB   118GB  67.1MB               kernel_b           msftdata
 4      118GB   118GB  459kB                kernel-dtb         msftdata
 5      118GB   118GB  459kB                kernel-dtb_b       msftdata
 6      118GB   118GB  66.1MB               recovery           msftdata
 7      118GB   118GB  524kB                recovery-dtb       msftdata
 8      118GB   118GB  262kB                kernel-bootctrl    msftdata
 9      118GB   118GB  262kB                kernel-bootctrl_b  msftdata
10      118GB   119GB  315MB                RECROOTFS          msftdata
11      119GB   128GB  9235MB               UDA                msftdata
[ 4]: l4t_flash_from_kernel: Expanding last partition to fill the storage device
Erasing 64 Kibyte @ d0000 --  2 % complete
Erasing 64 Kibyte @ e0000 --  2 % complete
Erasing 64 Kibyte @ f0000 --  2 % complete
Erasing 64 Kibyte @ 100000 --  3 % complete
Erasing 64 Kibyte @ 110000 --  3 % complete
Erasing 64 Kibyte @ 120000 --  3 % complete [ 5]: l4t_flash_from_kernel: Successfully create gpt for external device
Run command: partprobe on root@fe80::1%enp0s20f0u3
Erasing 64 Kibyte @ 130000 --  3 % complete Warning: Error fsyncing/closing /dev/mmcblk0rpmb: Input/output error
Erasing 64 Kibyte @ 140000 --  3 % complete
Erasing 64 Kibyte @ 150000 --  4 % complete
Erasing 64 Kibyte @ 160000 --  4 % complete
Erasing 64 Kibyte @ 170000 --  4 % complete
Erasing 64 Kibyte @ 180000 --  4 % complete [ 6]: l4t_flash_from_kernel: Starting to flash to emmc
[ 6]: l4t_flash_from_kernel: Starting to flash to external device
max_index=61
max_index=13
writing item=0, 9:0:master_boot_record, 0, 512, mbr_9_0.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
writing item=2, 9:0:APP, 20480, 118111600640, , , fixed-<reserved>-1,
Formatting APP partition /dev/sdd1 ...
mke2fs 1.44.1 (24-Mar-2018)
Creating filesystem with 28835840 4k blocks and 7208960 inodes
Filesystem UUID: 78d788f8-fa83-4abc-9ccf-8fba142163e5
Superblock backups stored on blocks:
	32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
	4096000, 7962624, 11239424, 20480000, 23887872
Allocating group tables:   0/880       done
Writing inode tables:   0/880       done
Creating journal (131072 blocks):
Erasing 64 Kibyte @ 190000 --  4 % complete writing item=48, 1:3:master_boot_record, 0, 512, mbr_1_3.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
writing item=50, 1:3:APP, 20480, 15032385536, , , fixed-<reserved>-1,
Formatting APP partition /dev/sda1 ...
Erasing 64 Kibyte @ 1a0000 --  5 % complete
Erasing 64 Kibyte @ 1b0000 --  5 % complete Creating filesystem with 3670016 4k blocks and 917504 inodes
Filesystem UUID: ebc8df3b-8c71-4cd7-9d96-5d1d80da3eb6
Allocating group tables:   0/112       done
Writing inode tables:   0/112       done
Erasing 64 Kibyte @ 1c0000 --  5 % complete Creating journal (16384 blocks):
Erasing 64 Kibyte @ 1d0000 --  5 % complete
Erasing 64 Kibyte @ 1e0000 --  5 % complete
Erasing 64 Kibyte @ 1f0000 --  6 % complete
Erasing 64 Kibyte @ 200000 --  6 % complete
Erasing 64 Kibyte @ 210000 --  6 % complete
Erasing 64 Kibyte @ 220000 --  6 % complete
Erasing 64 Kibyte @ 230000 --  6 % complete
Erasing 64 Kibyte @ 240000 --  7 % complete
Erasing 64 Kibyte @ 250000 --  7 % complete
Erasing 64 Kibyte @ 260000 --  7 % complete done
Writing superblocks and filesystem accounting information:   0/112
Erasing 64 Kibyte @ 270000 --  7 % complete   4/112
Erasing 64 Kibyte @ 280000 --  7 % complete
Erasing 64 Kibyte @ 290000 --  8 % complete
Erasing 64 Kibyte @ 2a0000 --  8 % complete
Erasing 64 Kibyte @ 2b0000 --  8 % complete
Erasing 64 Kibyte @ 2c0000 --  8 % complete
Erasing 64 Kibyte @ 2d0000 --  8 % complete
Erasing 64 Kibyte @ 2e0000 --  8 % complete
Erasing 64 Kibyte @ 2f0000 --  9 % complete done
Formatting APP parition done
Erasing 64 Kibyte @ 300000 --  9 % complete Formatting APP partition /dev/sda1 ...
tar --xattrs -xpf /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/system.img  --checkpoint=10000 --warning=no-timestamp --numeric-owner  -C  /tmp/ci-Q49UPddODc
Erasing 64 Kibyte @ 310000 --  9 % complete
Erasing 64 Kibyte @ 320000 --  9 % complete
Erasing 64 Kibyte @ 330000 --  9 % complete
Erasing 64 Kibyte @ 340000 -- 10 % complete
Erasing 64 Kibyte @ 350000 -- 10 % complete
Erasing 64 Kibyte @ 360000 -- 10 % complete
Erasing 64 Kibyte @ 370000 -- 10 % complete
Erasing 64 Kibyte @ 380000 -- 10 % complete
Erasing 64 Kibyte @ 390000 -- 11 % complete
Erasing 64 Kibyte @ 3a0000 -- 11 % complete
Erasing 64 Kibyte @ 3b0000 -- 11 % complete
Erasing 64 Kibyte @ 3c0000 -- 11 % complete
Erasing 64 Kibyte @ 3d0000 -- 11 % complete
Erasing 64 Kibyte @ 3e0000 -- 12 % complete
Erasing 64 Kibyte @ 3f0000 -- 12 % complete
Erasing 64 Kibyte @ 400000 -- 12 % complete
Erasing 64 Kibyte @ 410000 -- 12 % complete
Erasing 64 Kibyte @ 420000 -- 12 % complete
Erasing 64 Kibyte @ 430000 -- 13 % complete
Erasing 64 Kibyte @ 440000 -- 13 % complete
Erasing 64 Kibyte @ 450000 -- 13 % complete
Erasing 64 Kibyte @ 460000 -- 13 % complete
Erasing 64 Kibyte @ 470000 -- 13 % complete
Erasing 64 Kibyte @ 480000 -- 14 % complete
Erasing 64 Kibyte @ 490000 -- 14 % complete
Erasing 64 Kibyte @ 4a0000 -- 14 % complete
Erasing 64 Kibyte @ 4b0000 -- 14 % complete writing item=51, 1:3:kernel, 15032406016, 67108864, boot_sigheader.img.encrypt, 41887744, fixed-<reserved>-2, d2e11688bb258601aa1012d454ecb5580187a9a5
Writing kernel partition with boot_sigheader.img.encrypt
Get size of partition through connection.
41887744 bytes from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/boot_sigheader.img.encrypt to /dev/sda: 1KB block=40906 remainder=0
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/boot_sigheader.img.encrypt of=/dev/sda bs=1K skip=0  seek=14680084 count=40906
Erasing 64 Kibyte @ 4c0000 -- 14 % complete
Erasing 64 Kibyte @ 4d0000 -- 15 % complete
Erasing 64 Kibyte @ 4e0000 -- 15 % complete
Erasing 64 Kibyte @ 4f0000 -- 15 % complete
Erasing 64 Kibyte @ 500000 -- 15 % complete
Erasing 64 Kibyte @ 510000 -- 15 % complete
Erasing 64 Kibyte @ 520000 -- 16 % complete
Erasing 64 Kibyte @ 530000 -- 16 % complete done
Writing superblocks and filesystem accounting information:   0/880
Erasing 64 Kibyte @ 540000 -- 16 % complete
Erasing 64 Kibyte @ 550000 -- 16 % complete
Erasing 64 Kibyte @ 560000 -- 16 % complete
Erasing 64 Kibyte @ 570000 -- 16 % complete
Erasing 64 Kibyte @ 580000 -- 17 % complete
Erasing 64 Kibyte @ 590000 -- 17 % complete
Erasing 64 Kibyte @ 5a0000 -- 17 % complete
Erasing 64 Kibyte @ 5b0000 -- 17 % complete
Erasing 64 Kibyte @ 5c0000 -- 17 % complete
Erasing 64 Kibyte @ 5d0000 -- 18 % complete
Erasing 64 Kibyte @ 5e0000 -- 18 % complete
Erasing 64 Kibyte @ 5f0000 -- 18 % complete
Erasing 64 Kibyte @ 600000 -- 18 % complete
Erasing 64 Kibyte @ 610000 -- 18 % complete
Erasing 64 Kibyte @ 620000 -- 19 % complete
Erasing 64 Kibyte @ 630000 -- 19 % complete
Erasing 64 Kibyte @ 640000 -- 19 % complete
Erasing 64 Kibyte @ 650000 -- 19 % complete
Erasing 64 Kibyte @ 660000 -- 19 % complete
Erasing 64 Kibyte @ 670000 -- 20 % complete
Erasing 64 Kibyte @ 680000 -- 20 % complete
Erasing 64 Kibyte @ 690000 -- 20 % complete
Erasing 64 Kibyte @ 6a0000 -- 20 % complete
Erasing 64 Kibyte @ 6b0000 -- 20 % complete
Erasing 64 Kibyte @ 6c0000 -- 21 % complete   2/880
Erasing 64 Kibyte @ 6d0000 -- 21 % complete
Erasing 64 Kibyte @ 6e0000 -- 21 % complete
Erasing 64 Kibyte @ 6f0000 -- 21 % complete
Erasing 64 Kibyte @ 700000 -- 21 % complete
Erasing 64 Kibyte @ 710000 -- 22 % complete
Erasing 64 Kibyte @ 720000 -- 22 % complete
Erasing 64 Kibyte @ 730000 -- 22 % complete
Erasing 64 Kibyte @ 740000 -- 22 % complete
Erasing 64 Kibyte @ 750000 -- 22 % complete
Erasing 64 Kibyte @ 760000 -- 23 % complete
Erasing 64 Kibyte @ 770000 -- 23 % complete
Erasing 64 Kibyte @ 780000 -- 23 % complete
Erasing 64 Kibyte @ 790000 -- 23 % complete
Erasing 64 Kibyte @ 7a0000 -- 23 % complete
Erasing 64 Kibyte @ 7b0000 -- 24 % complete
Erasing 64 Kibyte @ 7c0000 -- 24 % complete
Erasing 64 Kibyte @ 7d0000 -- 24 % complete
Erasing 64 Kibyte @ 7e0000 -- 24 % complete
Erasing 64 Kibyte @ 7f0000 -- 24 % complete
Erasing 64 Kibyte @ 800000 -- 25 % complete
Erasing 64 Kibyte @ 810000 -- 25 % complete
Erasing 64 Kibyte @ 820000 -- 25 % complete
Erasing 64 Kibyte @ 830000 -- 25 % complete
Erasing 64 Kibyte @ 840000 -- 25 % complete
Erasing 64 Kibyte @ 850000 -- 25 % complete
Erasing 64 Kibyte @ 860000 -- 26 % complete
Erasing 64 Kibyte @ 870000 -- 26 % complete
Erasing 64 Kibyte @ 880000 -- 26 % complete
Erasing 64 Kibyte @ 890000 -- 26 % complete
Erasing 64 Kibyte @ 8a0000 -- 26 % complete
Erasing 64 Kibyte @ 8b0000 -- 27 % complete
Erasing 64 Kibyte @ 8c0000 -- 27 % complete
Erasing 64 Kibyte @ 8d0000 -- 27 % complete
Erasing 64 Kibyte @ 8e0000 -- 27 % complete
Erasing 64 Kibyte @ 8f0000 -- 27 % complete
Erasing 64 Kibyte @ 900000 -- 28 % complete
Erasing 64 Kibyte @ 910000 -- 28 % complete done
Erasing 64 Kibyte @ 920000 -- 28 % complete Formatting APP partition /dev/sdd1 ...
tar --xattrs -xpf /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/system.img  --checkpoint=10000 --warning=no-timestamp --numeric-owner  -C  /tmp/ci-VwadLmPhJg
tar: Read checkpoint 10000
Erasing 64 Kibyte @ 930000 -- 28 % complete
Erasing 64 Kibyte @ 940000 -- 28 % complete
Erasing 64 Kibyte @ 950000 -- 29 % complete
Erasing 64 Kibyte @ 960000 -- 29 % complete
Erasing 64 Kibyte @ 970000 -- 29 % complete
Erasing 64 Kibyte @ 980000 -- 29 % complete
Erasing 64 Kibyte @ 990000 -- 29 % complete
Erasing 64 Kibyte @ 9a0000 -- 30 % complete
Erasing 64 Kibyte @ 9b0000 -- 30 % complete
Erasing 64 Kibyte @ 9c0000 -- 30 % complete tar: Read checkpoint 20000
Erasing 64 Kibyte @ 9d0000 -- 30 % complete
Erasing 64 Kibyte @ 9e0000 -- 30 % complete
Erasing 64 Kibyte @ 9f0000 -- 31 % complete
Erasing 64 Kibyte @ a00000 -- 31 % complete
Erasing 64 Kibyte @ a10000 -- 31 % complete
Erasing 64 Kibyte @ a20000 -- 31 % complete
Erasing 64 Kibyte @ a30000 -- 31 % complete
Erasing 64 Kibyte @ a40000 -- 32 % complete
Erasing 64 Kibyte @ a50000 -- 32 % complete
Erasing 64 Kibyte @ a60000 -- 32 % complete
Erasing 64 Kibyte @ a70000 -- 32 % complete
Erasing 64 Kibyte @ a80000 -- 32 % complete
Erasing 64 Kibyte @ a90000 -- 33 % complete
Erasing 64 Kibyte @ aa0000 -- 33 % complete
Erasing 64 Kibyte @ ab0000 -- 33 % complete
Erasing 64 Kibyte @ ac0000 -- 33 % complete
Erasing 64 Kibyte @ ad0000 -- 33 % complete
Erasing 64 Kibyte @ ae0000 -- 33 % complete
Erasing 64 Kibyte @ af0000 -- 34 % complete
Erasing 64 Kibyte @ b00000 -- 34 % complete
Erasing 64 Kibyte @ b10000 -- 34 % complete
Erasing 64 Kibyte @ b20000 -- 34 % complete
Erasing 64 Kibyte @ b30000 -- 34 % complete
Erasing 64 Kibyte @ b40000 -- 35 % complete
Erasing 64 Kibyte @ b50000 -- 35 % complete
Erasing 64 Kibyte @ b60000 -- 35 % complete
Erasing 64 Kibyte @ b70000 -- 35 % complete
Erasing 64 Kibyte @ b80000 -- 35 % complete
Erasing 64 Kibyte @ b90000 -- 36 % complete
Erasing 64 Kibyte @ ba0000 -- 36 % complete
Erasing 64 Kibyte @ bb0000 -- 36 % complete
Erasing 64 Kibyte @ bc0000 -- 36 % complete
Erasing 64 Kibyte @ bd0000 -- 36 % complete
Erasing 64 Kibyte @ be0000 -- 37 % complete
Erasing 64 Kibyte @ bf0000 -- 37 % complete
Erasing 64 Kibyte @ c00000 -- 37 % complete
Erasing 64 Kibyte @ c10000 -- 37 % complete
Erasing 64 Kibyte @ c20000 -- 37 % complete
Erasing 64 Kibyte @ c30000 -- 38 % complete
Erasing 64 Kibyte @ c40000 -- 38 % complete
Erasing 64 Kibyte @ c50000 -- 38 % complete
Erasing 64 Kibyte @ c60000 -- 38 % complete
Erasing 64 Kibyte @ c70000 -- 38 % complete
Erasing 64 Kibyte @ c80000 -- 39 % complete
Erasing 64 Kibyte @ c90000 -- 39 % complete
Erasing 64 Kibyte @ ca0000 -- 39 % complete
Erasing 64 Kibyte @ cb0000 -- 39 % complete
Erasing 64 Kibyte @ cc0000 -- 39 % complete
Erasing 64 Kibyte @ cd0000 -- 40 % complete
Erasing 64 Kibyte @ ce0000 -- 40 % complete
Erasing 64 Kibyte @ cf0000 -- 40 % complete
Erasing 64 Kibyte @ d00000 -- 40 % complete
Erasing 64 Kibyte @ d10000 -- 40 % complete
Erasing 64 Kibyte @ d20000 -- 41 % complete tar: Read checkpoint 30000
Erasing 64 Kibyte @ d30000 -- 41 % complete
Erasing 64 Kibyte @ d40000 -- 41 % complete
Erasing 64 Kibyte @ d50000 -- 41 % complete
Erasing 64 Kibyte @ d60000 -- 41 % complete
Erasing 64 Kibyte @ d70000 -- 41 % complete
Erasing 64 Kibyte @ d80000 -- 42 % complete
Erasing 64 Kibyte @ d90000 -- 42 % complete
Erasing 64 Kibyte @ da0000 -- 42 % complete
Erasing 64 Kibyte @ db0000 -- 42 % complete
Erasing 64 Kibyte @ dc0000 -- 42 % complete
Erasing 64 Kibyte @ dd0000 -- 43 % complete
Erasing 64 Kibyte @ de0000 -- 43 % complete
Erasing 64 Kibyte @ df0000 -- 43 % complete
Erasing 64 Kibyte @ e00000 -- 43 % complete
Erasing 64 Kibyte @ e10000 -- 43 % complete
Erasing 64 Kibyte @ e20000 -- 44 % complete
Erasing 64 Kibyte @ e30000 -- 44 % complete
Erasing 64 Kibyte @ e40000 -- 44 % complete
Erasing 64 Kibyte @ e50000 -- 44 % complete
Erasing 64 Kibyte @ e60000 -- 44 % complete
Erasing 64 Kibyte @ e70000 -- 45 % complete
Erasing 64 Kibyte @ e80000 -- 45 % complete
Erasing 64 Kibyte @ e90000 -- 45 % complete
Erasing 64 Kibyte @ ea0000 -- 45 % complete tar: Read checkpoint 40000
Erasing 64 Kibyte @ eb0000 -- 45 % complete
Erasing 64 Kibyte @ ec0000 -- 46 % complete
Erasing 64 Kibyte @ ed0000 -- 46 % complete
Erasing 64 Kibyte @ ee0000 -- 46 % complete
Erasing 64 Kibyte @ ef0000 -- 46 % complete
Erasing 64 Kibyte @ f00000 -- 46 % complete
Erasing 64 Kibyte @ f10000 -- 47 % complete
Erasing 64 Kibyte @ f20000 -- 47 % complete
Erasing 64 Kibyte @ f30000 -- 47 % complete
Erasing 64 Kibyte @ f40000 -- 47 % complete
Erasing 64 Kibyte @ f50000 -- 47 % complete
Erasing 64 Kibyte @ f60000 -- 48 % complete
Erasing 64 Kibyte @ f70000 -- 48 % complete
Erasing 64 Kibyte @ f80000 -- 48 % complete
Erasing 64 Kibyte @ f90000 -- 48 % complete
Erasing 64 Kibyte @ fa0000 -- 48 % complete
Erasing 64 Kibyte @ fb0000 -- 49 % complete
Erasing 64 Kibyte @ fc0000 -- 49 % complete
Erasing 64 Kibyte @ fd0000 -- 49 % complete
Erasing 64 Kibyte @ fe0000 -- 49 % complete
Erasing 64 Kibyte @ ff0000 -- 49 % complete
Erasing 64 Kibyte @ 1000000 -- 50 % complete
Erasing 64 Kibyte @ 1010000 -- 50 % complete
Erasing 64 Kibyte @ 1020000 -- 50 % complete
Erasing 64 Kibyte @ 1030000 -- 50 % complete
Erasing 64 Kibyte @ 1040000 -- 50 % complete
Erasing 64 Kibyte @ 1050000 -- 50 % complete
Erasing 64 Kibyte @ 1060000 -- 51 % complete
Erasing 64 Kibyte @ 1070000 -- 51 % complete
Erasing 64 Kibyte @ 1080000 -- 51 % complete
Erasing 64 Kibyte @ 1090000 -- 51 % complete
Erasing 64 Kibyte @ 10a0000 -- 51 % complete
Erasing 64 Kibyte @ 10b0000 -- 52 % complete
Erasing 64 Kibyte @ 10c0000 -- 52 % complete
Erasing 64 Kibyte @ 10d0000 -- 52 % complete
Erasing 64 Kibyte @ 10e0000 -- 52 % complete
Erasing 64 Kibyte @ 10f0000 -- 52 % complete
Erasing 64 Kibyte @ 1100000 -- 53 % complete
Erasing 64 Kibyte @ 1110000 -- 53 % complete
Erasing 64 Kibyte @ 1120000 -- 53 % complete
Erasing 64 Kibyte @ 1130000 -- 53 % complete
Erasing 64 Kibyte @ 1140000 -- 53 % complete
Erasing 64 Kibyte @ 1150000 -- 54 % complete
Erasing 64 Kibyte @ 1160000 -- 54 % complete
Erasing 64 Kibyte @ 1170000 -- 54 % complete
Erasing 64 Kibyte @ 1180000 -- 54 % complete
Erasing 64 Kibyte @ 1190000 -- 54 % complete
Erasing 64 Kibyte @ 11a0000 -- 55 % complete
Erasing 64 Kibyte @ 11b0000 -- 55 % complete
Erasing 64 Kibyte @ 11c0000 -- 55 % complete
Erasing 64 Kibyte @ 11d0000 -- 55 % complete
Erasing 64 Kibyte @ 11e0000 -- 55 % complete
Erasing 64 Kibyte @ 11f0000 -- 56 % complete
Erasing 64 Kibyte @ 1200000 -- 56 % complete
Erasing 64 Kibyte @ 1210000 -- 56 % complete
Erasing 64 Kibyte @ 1220000 -- 56 % complete
Erasing 64 Kibyte @ 1230000 -- 56 % complete
Erasing 64 Kibyte @ 1240000 -- 57 % complete
Erasing 64 Kibyte @ 1250000 -- 57 % complete
Erasing 64 Kibyte @ 1260000 -- 57 % complete
Erasing 64 Kibyte @ 1270000 -- 57 % complete
Erasing 64 Kibyte @ 1280000 -- 57 % complete
Erasing 64 Kibyte @ 1290000 -- 58 % complete
Erasing 64 Kibyte @ 12a0000 -- 58 % complete
Erasing 64 Kibyte @ 12b0000 -- 58 % complete
Erasing 64 Kibyte @ 12c0000 -- 58 % complete
Erasing 64 Kibyte @ 12d0000 -- 58 % complete
Erasing 64 Kibyte @ 12e0000 -- 58 % complete
Erasing 64 Kibyte @ 12f0000 -- 59 % complete
Erasing 64 Kibyte @ 1300000 -- 59 % complete
Erasing 64 Kibyte @ 1310000 -- 59 % complete
Erasing 64 Kibyte @ 1320000 -- 59 % complete
Erasing 64 Kibyte @ 1330000 -- 59 % complete
Erasing 64 Kibyte @ 1340000 -- 60 % complete
Erasing 64 Kibyte @ 1350000 -- 60 % complete tar: Read checkpoint 50000
Erasing 64 Kibyte @ 1360000 -- 60 % complete
Erasing 64 Kibyte @ 1370000 -- 60 % complete
Erasing 64 Kibyte @ 1380000 -- 60 % complete
Erasing 64 Kibyte @ 1390000 -- 61 % complete
Erasing 64 Kibyte @ 13a0000 -- 61 % complete
Erasing 64 Kibyte @ 13b0000 -- 61 % complete
Erasing 64 Kibyte @ 13c0000 -- 61 % complete
Erasing 64 Kibyte @ 13d0000 -- 61 % complete
Erasing 64 Kibyte @ 13e0000 -- 62 % complete
Erasing 64 Kibyte @ 13f0000 -- 62 % complete
Erasing 64 Kibyte @ 1400000 -- 62 % complete
Erasing 64 Kibyte @ 1410000 -- 62 % complete
Erasing 64 Kibyte @ 1420000 -- 62 % complete
Erasing 64 Kibyte @ 1430000 -- 63 % complete
Erasing 64 Kibyte @ 1440000 -- 63 % complete
Erasing 64 Kibyte @ 1450000 -- 63 % complete
Erasing 64 Kibyte @ 1460000 -- 63 % complete
Erasing 64 Kibyte @ 1470000 -- 63 % complete
Erasing 64 Kibyte @ 1480000 -- 64 % complete
Erasing 64 Kibyte @ 1490000 -- 64 % complete
Erasing 64 Kibyte @ 14a0000 -- 64 % complete
Erasing 64 Kibyte @ 14b0000 -- 64 % complete
Erasing 64 Kibyte @ 14c0000 -- 64 % complete
Erasing 64 Kibyte @ 14d0000 -- 65 % complete
Erasing 64 Kibyte @ 14e0000 -- 65 % complete
Erasing 64 Kibyte @ 14f0000 -- 65 % complete
Erasing 64 Kibyte @ 1500000 -- 65 % complete
Erasing 64 Kibyte @ 1510000 -- 65 % complete
Erasing 64 Kibyte @ 1520000 -- 66 % complete
Erasing 64 Kibyte @ 1530000 -- 66 % complete
Erasing 64 Kibyte @ 1540000 -- 66 % complete tar: Read checkpoint 60000
Erasing 64 Kibyte @ 1550000 -- 66 % complete
Erasing 64 Kibyte @ 1560000 -- 66 % complete
Erasing 64 Kibyte @ 1570000 -- 66 % complete
Erasing 64 Kibyte @ 1580000 -- 67 % complete
Erasing 64 Kibyte @ 1590000 -- 67 % complete
Erasing 64 Kibyte @ 15a0000 -- 67 % complete
Erasing 64 Kibyte @ 15b0000 -- 67 % complete
Erasing 64 Kibyte @ 15c0000 -- 67 % complete
Erasing 64 Kibyte @ 15d0000 -- 68 % complete
Erasing 64 Kibyte @ 15e0000 -- 68 % complete
Erasing 64 Kibyte @ 15f0000 -- 68 % complete
Erasing 64 Kibyte @ 1600000 -- 68 % complete
Erasing 64 Kibyte @ 1610000 -- 68 % complete
Erasing 64 Kibyte @ 1620000 -- 69 % complete
Erasing 64 Kibyte @ 1630000 -- 69 % complete
Erasing 64 Kibyte @ 1640000 -- 69 % complete
Erasing 64 Kibyte @ 1650000 -- 69 % complete
Erasing 64 Kibyte @ 1660000 -- 69 % complete
Erasing 64 Kibyte @ 1670000 -- 70 % complete
Erasing 64 Kibyte @ 1680000 -- 70 % complete
Erasing 64 Kibyte @ 1690000 -- 70 % complete
Erasing 64 Kibyte @ 16a0000 -- 70 % complete
Erasing 64 Kibyte @ 16b0000 -- 70 % complete
Erasing 64 Kibyte @ 16c0000 -- 71 % complete
Erasing 64 Kibyte @ 16d0000 -- 71 % complete
Erasing 64 Kibyte @ 16e0000 -- 71 % complete
Erasing 64 Kibyte @ 16f0000 -- 71 % complete
Erasing 64 Kibyte @ 1700000 -- 71 % complete
Erasing 64 Kibyte @ 1710000 -- 72 % complete
Erasing 64 Kibyte @ 1720000 -- 72 % complete
Erasing 64 Kibyte @ 1730000 -- 72 % complete
Erasing 64 Kibyte @ 1740000 -- 72 % complete
Erasing 64 Kibyte @ 1750000 -- 72 % complete
Erasing 64 Kibyte @ 1760000 -- 73 % complete
Erasing 64 Kibyte @ 1770000 -- 73 % complete
Erasing 64 Kibyte @ 1780000 -- 73 % complete
Erasing 64 Kibyte @ 1790000 -- 73 % complete
Erasing 64 Kibyte @ 17a0000 -- 73 % complete
Erasing 64 Kibyte @ 17b0000 -- 74 % complete
Erasing 64 Kibyte @ 17c0000 -- 74 % complete
Erasing 64 Kibyte @ 17d0000 -- 74 % complete
Erasing 64 Kibyte @ 17e0000 -- 74 % complete
Erasing 64 Kibyte @ 17f0000 -- 74 % complete
Erasing 64 Kibyte @ 1800000 -- 75 % complete
Erasing 64 Kibyte @ 1810000 -- 75 % complete
Erasing 64 Kibyte @ 1820000 -- 75 % complete
Erasing 64 Kibyte @ 1830000 -- 75 % complete
Erasing 64 Kibyte @ 1840000 -- 75 % complete
Erasing 64 Kibyte @ 1850000 -- 75 % complete
Erasing 64 Kibyte @ 1860000 -- 76 % complete
Erasing 64 Kibyte @ 1870000 -- 76 % complete
Erasing 64 Kibyte @ 1880000 -- 76 % complete
Erasing 64 Kibyte @ 1890000 -- 76 % complete
Erasing 64 Kibyte @ 18a0000 -- 76 % complete
Erasing 64 Kibyte @ 18b0000 -- 77 % complete
Erasing 64 Kibyte @ 18c0000 -- 77 % complete
Erasing 64 Kibyte @ 18d0000 -- 77 % complete
Erasing 64 Kibyte @ 18e0000 -- 77 % complete
Erasing 64 Kibyte @ 18f0000 -- 77 % complete
Erasing 64 Kibyte @ 1900000 -- 78 % complete
Erasing 64 Kibyte @ 1910000 -- 78 % complete
Erasing 64 Kibyte @ 1920000 -- 78 % complete
Erasing 64 Kibyte @ 1930000 -- 78 % complete
Erasing 64 Kibyte @ 1940000 -- 78 % complete
Erasing 64 Kibyte @ 1950000 -- 79 % complete
Erasing 64 Kibyte @ 1960000 -- 79 % complete
Erasing 64 Kibyte @ 1970000 -- 79 % complete
Erasing 64 Kibyte @ 1980000 -- 79 % complete
Erasing 64 Kibyte @ 1990000 -- 79 % complete
Erasing 64 Kibyte @ 19a0000 -- 80 % complete
Erasing 64 Kibyte @ 19b0000 -- 80 % complete
Erasing 64 Kibyte @ 19c0000 -- 80 % complete
Erasing 64 Kibyte @ 19d0000 -- 80 % complete
Erasing 64 Kibyte @ 19e0000 -- 80 % complete
Erasing 64 Kibyte @ 19f0000 -- 81 % complete
Erasing 64 Kibyte @ 1a00000 -- 81 % complete
Erasing 64 Kibyte @ 1a10000 -- 81 % complete
Erasing 64 Kibyte @ 1a20000 -- 81 % complete
Erasing 64 Kibyte @ 1a30000 -- 81 % complete
Erasing 64 Kibyte @ 1a40000 -- 82 % complete
Erasing 64 Kibyte @ 1a50000 -- 82 % complete
Erasing 64 Kibyte @ 1a60000 -- 82 % complete
Erasing 64 Kibyte @ 1a70000 -- 82 % complete
Erasing 64 Kibyte @ 1a80000 -- 82 % complete
Erasing 64 Kibyte @ 1a90000 -- 83 % complete
Erasing 64 Kibyte @ 1aa0000 -- 83 % complete
Erasing 64 Kibyte @ 1ab0000 -- 83 % complete tar: Read checkpoint 70000
Erasing 64 Kibyte @ 1ac0000 -- 83 % complete
Erasing 64 Kibyte @ 1ad0000 -- 83 % complete
Erasing 64 Kibyte @ 1ae0000 -- 83 % complete
Erasing 64 Kibyte @ 1af0000 -- 84 % complete
Erasing 64 Kibyte @ 1b00000 -- 84 % complete
Erasing 64 Kibyte @ 1b10000 -- 84 % complete
Erasing 64 Kibyte @ 1b20000 -- 84 % complete
Erasing 64 Kibyte @ 1b30000 -- 84 % complete
Erasing 64 Kibyte @ 1b40000 -- 85 % complete
Erasing 64 Kibyte @ 1b50000 -- 85 % complete
Erasing 64 Kibyte @ 1b60000 -- 85 % complete
Erasing 64 Kibyte @ 1b70000 -- 85 % complete
Erasing 64 Kibyte @ 1b80000 -- 85 % complete
Erasing 64 Kibyte @ 1b90000 -- 86 % complete
Erasing 64 Kibyte @ 1ba0000 -- 86 % complete
Erasing 64 Kibyte @ 1bb0000 -- 86 % complete
Erasing 64 Kibyte @ 1bc0000 -- 86 % complete
Erasing 64 Kibyte @ 1bd0000 -- 86 % complete
Erasing 64 Kibyte @ 1be0000 -- 87 % complete
Erasing 64 Kibyte @ 1bf0000 -- 87 % complete
Erasing 64 Kibyte @ 1c00000 -- 87 % complete
Erasing 64 Kibyte @ 1c10000 -- 87 % complete
Erasing 64 Kibyte @ 1c20000 -- 87 % complete
Erasing 64 Kibyte @ 1c30000 -- 88 % complete tar: Read checkpoint 80000
Erasing 64 Kibyte @ 1c40000 -- 88 % complete
Erasing 64 Kibyte @ 1c50000 -- 88 % complete
Erasing 64 Kibyte @ 1c60000 -- 88 % complete
Erasing 64 Kibyte @ 1c70000 -- 88 % complete
Erasing 64 Kibyte @ 1c80000 -- 89 % complete
Erasing 64 Kibyte @ 1c90000 -- 89 % complete
Erasing 64 Kibyte @ 1ca0000 -- 89 % complete
Erasing 64 Kibyte @ 1cb0000 -- 89 % complete
Erasing 64 Kibyte @ 1cc0000 -- 89 % complete
Erasing 64 Kibyte @ 1cd0000 -- 90 % complete
Erasing 64 Kibyte @ 1ce0000 -- 90 % complete
Erasing 64 Kibyte @ 1cf0000 -- 90 % complete
Erasing 64 Kibyte @ 1d00000 -- 90 % complete
Erasing 64 Kibyte @ 1d10000 -- 90 % complete
Erasing 64 Kibyte @ 1d20000 -- 91 % complete
Erasing 64 Kibyte @ 1d30000 -- 91 % complete
Erasing 64 Kibyte @ 1d40000 -- 91 % complete
Erasing 64 Kibyte @ 1d50000 -- 91 % complete
Erasing 64 Kibyte @ 1d60000 -- 91 % complete
Erasing 64 Kibyte @ 1d70000 -- 91 % complete
Erasing 64 Kibyte @ 1d80000 -- 92 % complete
Erasing 64 Kibyte @ 1d90000 -- 92 % complete
Erasing 64 Kibyte @ 1da0000 -- 92 % complete
Erasing 64 Kibyte @ 1db0000 -- 92 % complete
Erasing 64 Kibyte @ 1dc0000 -- 92 % complete
Erasing 64 Kibyte @ 1dd0000 -- 93 % complete
Erasing 64 Kibyte @ 1de0000 -- 93 % complete
Erasing 64 Kibyte @ 1df0000 -- 93 % complete
Erasing 64 Kibyte @ 1e00000 -- 93 % complete
Erasing 64 Kibyte @ 1e10000 -- 93 % complete
Erasing 64 Kibyte @ 1e20000 -- 94 % complete
Erasing 64 Kibyte @ 1e30000 -- 94 % complete
Erasing 64 Kibyte @ 1e40000 -- 94 % complete
Erasing 64 Kibyte @ 1e50000 -- 94 % complete
Erasing 64 Kibyte @ 1e60000 -- 94 % complete
Erasing 64 Kibyte @ 1e70000 -- 95 % complete
Erasing 64 Kibyte @ 1e80000 -- 95 % complete
Erasing 64 Kibyte @ 1e90000 -- 95 % complete
Erasing 64 Kibyte @ 1ea0000 -- 95 % complete
Erasing 64 Kibyte @ 1eb0000 -- 95 % complete
Erasing 64 Kibyte @ 1ec0000 -- 96 % complete
Erasing 64 Kibyte @ 1ed0000 -- 96 % complete
Erasing 64 Kibyte @ 1ee0000 -- 96 % complete
Erasing 64 Kibyte @ 1ef0000 -- 96 % complete
Erasing 64 Kibyte @ 1f00000 -- 96 % complete
Erasing 64 Kibyte @ 1f10000 -- 97 % complete
Erasing 64 Kibyte @ 1f20000 -- 97 % complete
Erasing 64 Kibyte @ 1f30000 -- 97 % complete
Erasing 64 Kibyte @ 1f40000 -- 97 % complete
Erasing 64 Kibyte @ 1f50000 -- 97 % complete
Erasing 64 Kibyte @ 1f60000 -- 98 % complete
Erasing 64 Kibyte @ 1f70000 -- 98 % complete
Erasing 64 Kibyte @ 1f80000 -- 98 % complete
Erasing 64 Kibyte @ 1f90000 -- 98 % complete
Erasing 64 Kibyte @ 1fa0000 -- 98 % complete
Erasing 64 Kibyte @ 1fb0000 -- 99 % complete
Erasing 64 Kibyte @ 1fc0000 -- 99 % complete
Erasing 64 Kibyte @ 1fd0000 -- 99 % complete tar: Read checkpoint 90000
Erasing 64 Kibyte @ 1fe0000 -- 99 % complete
Erasing 64 Kibyte @ 1ff0000 -- 99 % complete
Erasing 64 Kibyte @ 1ff0000 -- 100 % complete
max_index=61
Writing br_bct_BR.bct (parittion: BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/br_bct_BR.bct
Writing /qspi/internal/br_bct_BR.bct (2888 bytes) into  /dev/mtd0:0
Copied 2888 bytes from /qspi/internal/br_bct_BR.bct to address 0x00000000 in flash
Writing /qspi/internal/br_bct_BR.bct (2888 bytes) into  /dev/mtd0:4096
Copied 2888 bytes from /qspi/internal/br_bct_BR.bct to address 0x00001000 in flash
Writing /qspi/internal/br_bct_BR.bct (2888 bytes) into  /dev/mtd0:32768
Copied 2888 bytes from /qspi/internal/br_bct_BR.bct to address 0x00008000 in flash
Writing mb1_t194_prod_sigheader.bin.encrypt (parittion: mb1) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb1_t194_prod_sigheader.bin.encrypt
Writing /qspi/internal/mb1_t194_prod_sigheader.bin.encrypt (249312 bytes) into  /dev/mtd0:131072
Copied 249312 bytes from /qspi/internal/mb1_t194_prod_sigheader.bin.encrypt to address 0x00020000 in flash
Writing mb1_t194_prod_sigheader.bin.encrypt (parittion: mb1_b) into /dev/mtd0
Writing /qspi/internal/mb1_t194_prod_sigheader.bin.encrypt (249312 bytes) into  /dev/mtd0:393216
Copied 249312 bytes from /qspi/internal/mb1_t194_prod_sigheader.bin.encrypt to address 0x00060000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (parittion: MB1_BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
Writing /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (30336 bytes) into  /dev/mtd0:655360
Copied 30336 bytes from /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x000a0000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (parittion: MB1_BCT_b) into /dev/mtd0
Writing /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (30336 bytes) into  /dev/mtd0:720896
Copied 30336 bytes from /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x000b0000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (parittion: MEM_BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mem_coldboot_sigheader.bct.encrypt
Writing /qspi/internal/mem_coldboot_sigheader.bct.encrypt (198656 bytes) into  /dev/mtd0:786432
Copied 198656 bytes from /qspi/internal/mem_coldboot_sigheader.bct.encrypt to address 0x000c0000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (parittion: MEM_BCT_b) into /dev/mtd0
Writing /qspi/internal/mem_coldboot_sigheader.bct.encrypt (198656 bytes) into  /dev/mtd0:1048576
Copied 198656 bytes from /qspi/internal/mem_coldboot_sigheader.bct.encrypt to address 0x00100000 in flash
Writing spe_t194_sigheader.bin.encrypt (parittion: spe-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/spe_t194_sigheader.bin.encrypt
Writing /qspi/internal/spe_t194_sigheader.bin.encrypt (94960 bytes) into  /dev/mtd0:1310720
Copied 94960 bytes from /qspi/internal/spe_t194_sigheader.bin.encrypt to address 0x00140000 in flash
Writing spe_t194_sigheader.bin.encrypt (parittion: spe-fw_b) into /dev/mtd0
Writing /qspi/internal/spe_t194_sigheader.bin.encrypt (94960 bytes) into  /dev/mtd0:1572864
Copied 94960 bytes from /qspi/internal/spe_t194_sigheader.bin.encrypt to address 0x00180000 in flash
Writing nvtboot_t194_sigheader.bin.encrypt (parittion: mb2) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/nvtboot_t194_sigheader.bin.encrypt
Writing /qspi/internal/nvtboot_t194_sigheader.bin.encrypt (181232 bytes) into  /dev/mtd0:1835008
Copied 181232 bytes from /qspi/internal/nvtboot_t194_sigheader.bin.encrypt to address 0x001c0000 in flash
Writing nvtboot_t194_sigheader.bin.encrypt (parittion: mb2_b) into /dev/mtd0
Writing /qspi/internal/nvtboot_t194_sigheader.bin.encrypt (181232 bytes) into  /dev/mtd0:2097152
Copied 181232 bytes from /qspi/internal/nvtboot_t194_sigheader.bin.encrypt to address 0x00200000 in flash
Writing preboot_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-preboot) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/preboot_c10_prod_cr_sigheader.bin.encrypt
Writing /qspi/internal/preboot_c10_prod_cr_sigheader.bin.encrypt (24016 bytes) into  /dev/mtd0:2359296
Copied 24016 bytes from /qspi/internal/preboot_c10_prod_cr_sigheader.bin.encrypt to address 0x00240000 in flash
Writing preboot_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-preboot_b) into /dev/mtd0
Writing /qspi/internal/preboot_c10_prod_cr_sigheader.bin.encrypt (24016 bytes) into  /dev/mtd0:2424832
Copied 24016 bytes from /qspi/internal/preboot_c10_prod_cr_sigheader.bin.encrypt to address 0x00250000 in flash
Writing mce_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-mce) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mce_c10_prod_cr_sigheader.bin.encrypt
Writing /qspi/internal/mce_c10_prod_cr_sigheader.bin.encrypt (143200 bytes) into  /dev/mtd0:2490368
Copied 143200 bytes from /qspi/internal/mce_c10_prod_cr_sigheader.bin.encrypt to address 0x00260000 in flash
Writing mce_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-mce_b) into /dev/mtd0
Writing /qspi/internal/mce_c10_prod_cr_sigheader.bin.encrypt (143200 bytes) into  /dev/mtd0:2686976
Copied 143200 bytes from /qspi/internal/mce_c10_prod_cr_sigheader.bin.encrypt to address 0x00290000 in flash
Writing mts_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-proper) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mts_c10_prod_cr_sigheader.bin.encrypt
Writing /qspi/internal/mts_c10_prod_cr_sigheader.bin.encrypt (3430416 bytes) into  /dev/mtd0:2883584
tar: Read checkpoint 100000
40906+0 records in
40906+0 records out
41887744 bytes (42 MB, 40 MiB) copied, 74.7976 s, 560 kB/s
tar: Read checkpoint 110000
Copied 3430416 bytes from /qspi/internal/mts_c10_prod_cr_sigheader.bin.encrypt to address 0x002c0000 in flash
Writing mts_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-proper_b) into /dev/mtd0
Writing /qspi/internal/mts_c10_prod_cr_sigheader.bin.encrypt (3430416 bytes) into  /dev/mtd0:7077888
tar: Read checkpoint 120000
tar: Read checkpoint 130000
Copied 3430416 bytes from /qspi/internal/mts_c10_prod_cr_sigheader.bin.encrypt to address 0x006c0000 in flash
Writing warmboot_t194_prod_sigheader.bin.encrypt (parittion: sc7) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/warmboot_t194_prod_sigheader.bin.encrypt
Writing /qspi/internal/warmboot_t194_prod_sigheader.bin.encrypt (65504 bytes) into  /dev/mtd0:11272192
Copied 65504 bytes from /qspi/internal/warmboot_t194_prod_sigheader.bin.encrypt to address 0x00ac0000 in flash
Writing warmboot_t194_prod_sigheader.bin.encrypt (parittion: sc7_b) into /dev/mtd0
Writing /qspi/internal/warmboot_t194_prod_sigheader.bin.encrypt (65504 bytes) into  /dev/mtd0:11403264
Copied 65504 bytes from /qspi/internal/warmboot_t194_prod_sigheader.bin.encrypt to address 0x00ae0000 in flash
Writing slot_metadata.bin (parittion: SMD) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/slot_metadata.bin
Writing /qspi/internal/slot_metadata.bin (191 bytes) into  /dev/mtd0:11534336
Copied 191 bytes from /qspi/internal/slot_metadata.bin to address 0x00b00000 in flash
Writing slot_metadata.bin (parittion: SMD_b) into /dev/mtd0
Writing /qspi/internal/slot_metadata.bin (191 bytes) into  /dev/mtd0:11599872
Copied 191 bytes from /qspi/internal/slot_metadata.bin to address 0x00b10000 in flash
Writing xusb_sil_rel_fw_sigheader.encrypt (parittion: xusb-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/xusb_sil_rel_fw_sigheader.encrypt
Writing /qspi/internal/xusb_sil_rel_fw_sigheader.encrypt (133120 bytes) into  /dev/mtd0:11665408
Copied 133120 bytes from /qspi/internal/xusb_sil_rel_fw_sigheader.encrypt to address 0x00b20000 in flash
Writing xusb_sil_rel_fw_sigheader.encrypt (parittion: xusb-fw_b) into /dev/mtd0
Writing /qspi/internal/xusb_sil_rel_fw_sigheader.encrypt (133120 bytes) into  /dev/mtd0:11862016
Copied 133120 bytes from /qspi/internal/xusb_sil_rel_fw_sigheader.encrypt to address 0x00b50000 in flash
Writing cboot_t194_sigheader.bin.encrypt (parittion: cpu-bootloader) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/cboot_t194_sigheader.bin.encrypt
Writing /qspi/internal/cboot_t194_sigheader.bin.encrypt (470384 bytes) into  /dev/mtd0:12058624
Copied 470384 bytes from /qspi/internal/cboot_t194_sigheader.bin.encrypt to address 0x00b80000 in flash
Writing cboot_t194_sigheader.bin.encrypt (parittion: cpu-bootloader_b) into /dev/mtd0
Writing /qspi/internal/cboot_t194_sigheader.bin.encrypt (470384 bytes) into  /dev/mtd0:13500416
Copied 470384 bytes from /qspi/internal/cboot_t194_sigheader.bin.encrypt to address 0x00ce0000 in flash
Writing tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt (parittion: bootloader-dtb) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
Writing /qspi/internal/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt (203344 bytes) into  /dev/mtd0:14942208
Copied 203344 bytes from /qspi/internal/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt to address 0x00e40000 in flash
Writing tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt (parittion: bootloader-dtb_b) into /dev/mtd0
Writing /qspi/internal/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt (203344 bytes) into  /dev/mtd0:15400960
Copied 203344 bytes from /qspi/internal/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt to address 0x00eb0000 in flash
Writing bmp.blob (parittion: BMP) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/bmp.blob
Writing /qspi/internal/bmp.blob (149554 bytes) into  /dev/mtd0:15859712
Copied 149554 bytes from /qspi/internal/bmp.blob to address 0x00f20000 in flash
Writing bmp.blob (parittion: BMP_b) into /dev/mtd0
Writing /qspi/internal/bmp.blob (149554 bytes) into  /dev/mtd0:16056320
Copied 149554 bytes from /qspi/internal/bmp.blob to address 0x00f50000 in flash
Writing tos-trusty_t194_sigheader.img.encrypt (parittion: secure-os) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/tos-trusty_t194_sigheader.img.encrypt
Writing /qspi/internal/tos-trusty_t194_sigheader.img.encrypt (410560 bytes) into  /dev/mtd0:16252928
Copied 410560 bytes from /qspi/internal/tos-trusty_t194_sigheader.img.encrypt to address 0x00f80000 in flash
Writing tos-trusty_t194_sigheader.img.encrypt (parittion: secure-os_b) into /dev/mtd0
Writing /qspi/internal/tos-trusty_t194_sigheader.img.encrypt (410560 bytes) into  /dev/mtd0:18874368
tar: Read checkpoint 140000
Copied 410560 bytes from /qspi/internal/tos-trusty_t194_sigheader.img.encrypt to address 0x01200000 in flash
Writing eks_sigheader.img.encrypt (parittion: eks) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/eks_sigheader.img.encrypt
Writing /qspi/internal/eks_sigheader.img.encrypt (5136 bytes) into  /dev/mtd0:21495808
Copied 5136 bytes from /qspi/internal/eks_sigheader.img.encrypt to address 0x01480000 in flash
Writing eks_sigheader.img.encrypt (parittion: eks_b) into /dev/mtd0
Writing /qspi/internal/eks_sigheader.img.encrypt (5136 bytes) into  /dev/mtd0:21561344
Copied 5136 bytes from /qspi/internal/eks_sigheader.img.encrypt to address 0x01490000 in flash
Writing adsp-fw_sigheader.bin.encrypt (parittion: adsp-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/adsp-fw_sigheader.bin.encrypt
Writing /qspi/internal/adsp-fw_sigheader.bin.encrypt (81312 bytes) into  /dev/mtd0:21626880
Writing kernel partition done
writing item=52, 1:3:kernel_b, 15099514880, 67108864, boot_sigheader.img.encrypt, 41887744, fixed-<reserved>-3, d2e11688bb258601aa1012d454ecb5580187a9a5
Writing kernel_b partition with boot_sigheader.img.encrypt
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/boot_sigheader.img.encrypt of=/dev/sda bs=1K skip=0  seek=14745620 count=40906
Copied 81312 bytes from /qspi/internal/adsp-fw_sigheader.bin.encrypt to address 0x014a0000 in flash
Writing adsp-fw_sigheader.bin.encrypt (parittion: adsp-fw_b) into /dev/mtd0
Writing /qspi/internal/adsp-fw_sigheader.bin.encrypt (81312 bytes) into  /dev/mtd0:22675456
Copied 81312 bytes from /qspi/internal/adsp-fw_sigheader.bin.encrypt to address 0x015a0000 in flash
Writing camera-rtcpu-rce_sigheader.img.encrypt (parittion: rce-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/camera-rtcpu-rce_sigheader.img.encrypt
Writing /qspi/internal/camera-rtcpu-rce_sigheader.img.encrypt (272752 bytes) into  /dev/mtd0:23724032
Copied 272752 bytes from /qspi/internal/camera-rtcpu-rce_sigheader.img.encrypt to address 0x016a0000 in flash
Writing camera-rtcpu-rce_sigheader.img.encrypt (parittion: rce-fw_b) into /dev/mtd0
Writing /qspi/internal/camera-rtcpu-rce_sigheader.img.encrypt (272752 bytes) into  /dev/mtd0:24772608
Copied 272752 bytes from /qspi/internal/camera-rtcpu-rce_sigheader.img.encrypt to address 0x017a0000 in flash
[ 124]: l4t_flash_from_kernel: Warning: skip writing sce-fw partition as no image is specified
[ 124]: l4t_flash_from_kernel: Warning: skip writing sce-fw_b partition as no image is specified
Writing bpmp_t194_sigheader.bin.encrypt (parittion: bpmp-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/bpmp_t194_sigheader.bin.encrypt
Writing /qspi/internal/bpmp_t194_sigheader.bin.encrypt (856352 bytes) into  /dev/mtd0:27918336
tar: Read checkpoint 150000
Copied 856352 bytes from /qspi/internal/bpmp_t194_sigheader.bin.encrypt to address 0x01aa0000 in flash
Writing bpmp_t194_sigheader.bin.encrypt (parittion: bpmp-fw_b) into /dev/mtd0
Writing /qspi/internal/bpmp_t194_sigheader.bin.encrypt (856352 bytes) into  /dev/mtd0:29491200
Copied 856352 bytes from /qspi/internal/bpmp_t194_sigheader.bin.encrypt to address 0x01c20000 in flash
Writing tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt (parittion: bpmp-fw-dtb) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
Writing /qspi/internal/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt (199808 bytes) into  /dev/mtd0:31064064
Copied 199808 bytes from /qspi/internal/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt to address 0x01da0000 in flash
Writing tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt (parittion: bpmp-fw-dtb_b) into /dev/mtd0
Writing /qspi/internal/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt (199808 bytes) into  /dev/mtd0:32112640
Copied 199808 bytes from /qspi/internal/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt to address 0x01ea0000 in flash
[ 130]: l4t_flash_from_kernel: Warning: skip writing CPUBL-CFG partition as no image is specified
[ 130]: l4t_flash_from_kernel: Warning: skip writing CPUBL-CFG_b partition as no image is specified
Writing qspi_bootblob_ver.txt (parittion: VER) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/qspi_bootblob_ver.txt
Writing /qspi/internal/qspi_bootblob_ver.txt (102 bytes) into  /dev/mtd0:33292288
Copied 102 bytes from /qspi/internal/qspi_bootblob_ver.txt to address 0x01fc0000 in flash
Writing qspi_bootblob_ver.txt (parittion: VER_b) into /dev/mtd0
Writing /qspi/internal/qspi_bootblob_ver.txt (102 bytes) into  /dev/mtd0:33357824
Copied 102 bytes from /qspi/internal/qspi_bootblob_ver.txt to address 0x01fd0000 in flash
Writing gpt_secondary_3_0.bin (parittion: secondary_gpt) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/gpt_secondary_3_0.bin
Writing /qspi/internal/gpt_secondary_3_0.bin (16896 bytes) into  /dev/mtd0:33537536
Copied 16896 bytes from /qspi/internal/gpt_secondary_3_0.bin to address 0x01ffbe00 in flash
Reach the end of the SPI device
[ 130]: l4t_flash_from_kernel: Successfully flash the qspi
[ 130]: l4t_flash_from_kernel: Flashing success
tar: Read checkpoint 160000
tar: Read checkpoint 170000
tar: Read checkpoint 180000
tar: Read checkpoint 190000
tar: Read checkpoint 200000
tar: Read checkpoint 210000
tar: Read checkpoint 220000
tar: Read checkpoint 230000
tar: Read checkpoint 240000
tar: Read checkpoint 250000
40906+0 records in
40906+0 records out
41887744 bytes (42 MB, 40 MiB) copied, 74.7089 s, 561 kB/s
tar: Read checkpoint 260000
tar: Read checkpoint 270000
tar: Read checkpoint 280000
tar: Read checkpoint 290000
Writing kernel_b partition done
writing item=53, 1:3:kernel-dtb, 15166623744, 458752, kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt, 203344, fixed-<reserved>-4, 991b27a229c8271b90944ffdf8a99acd841d1a4e
Writing kernel-dtb partition with kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
203344 bytes from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt to /dev/sda: 1KB block=198 remainder=592
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sda bs=1K skip=0  seek=14811156 count=198
198+0 records in
198+0 records out
202752 bytes (203 kB, 198 KiB) copied, 0.1996 s, 1.0 MB/s
tar: Read checkpoint 300000
tar: Read checkpoint 310000
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sda bs=1 skip=202752  seek=15166826496 count=592
592+0 records in
592+0 records out
592 bytes copied, 0.00999918 s, 59.2 kB/s
tar: Read checkpoint 320000
tar: Read checkpoint 330000
tar: Read checkpoint 340000
tar: Read checkpoint 350000
tar: Read checkpoint 360000
Writing kernel-dtb partition done
writing item=54, 1:3:kernel-dtb_b, 15167082496, 458752, kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt, 203344, fixed-<reserved>-5, 991b27a229c8271b90944ffdf8a99acd841d1a4e
Writing kernel-dtb_b partition with kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sda bs=1K skip=0  seek=14811604 count=198
198+0 records in
198+0 records out
202752 bytes (203 kB, 198 KiB) copied, 0.195887 s, 1.0 MB/s
tar: Read checkpoint 370000
tar: Read checkpoint 380000
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sda bs=1 skip=202752  seek=15167285248 count=592
592+0 records in
592+0 records out
592 bytes copied, 0.0101724 s, 58.2 kB/s
tar: Read checkpoint 390000
tar: Read checkpoint 400000
tar: Read checkpoint 410000
Writing kernel-dtb_b partition done
writing item=55, 1:3:recovery, 15167541248, 66060288, recovery_sigheader.img.encrypt, 49641472, fixed-<reserved>-6, 5e08d5f08f1cb232c38f0e64b7c91eb644e0293e
Writing recovery partition with recovery_sigheader.img.encrypt
49641472 bytes from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/recovery_sigheader.img.encrypt to /dev/sda: 1KB block=48478 remainder=0
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/recovery_sigheader.img.encrypt of=/dev/sda bs=1K skip=0  seek=14812052 count=48478
tar: Read checkpoint 420000
tar: Read checkpoint 430000
tar: Read checkpoint 440000
tar: Read checkpoint 450000
tar: Read checkpoint 460000
tar: Read checkpoint 470000
tar: Read checkpoint 480000
tar: Read checkpoint 490000
tar: Read checkpoint 500000
writing item=3, 9:0:kernel, 118111621120, 67108864, boot_sigheader.img.encrypt, 41887744, fixed-<reserved>-2, 97b25dae52b11dd84096cffc89b955cc80797ae3
41887744 bytes from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/boot_sigheader.img.encrypt to /dev/sdd: 1KB block=40906 remainder=0
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/boot_sigheader.img.encrypt of=/dev/sdd bs=1K skip=0  seek=115343380 count=40906
48478+0 records in
48478+0 records out
49641472 bytes (50 MB, 47 MiB) copied, 73.503 s, 675 kB/s
Writing recovery partition done
writing item=56, 1:3:recovery-dtb, 15233601536, 524288, tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt, 203344, fixed-<reserved>-7, c403f81de55ddbe5fddc384c40d983cf781dcb97
Writing recovery-dtb partition with tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt
203344 bytes from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt to /dev/sda: 1KB block=198 remainder=592
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt of=/dev/sda bs=1K skip=0  seek=14876564 count=198
198+0 records in
198+0 records out
202752 bytes (203 kB, 198 KiB) copied, 0.18175 s, 1.1 MB/s
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt of=/dev/sda bs=1 skip=202752  seek=15233804288 count=592
592+0 records in
592+0 records out
592 bytes copied, 0.00261162 s, 227 kB/s
Writing recovery-dtb partition done
writing item=57, 1:3:kernel-bootctrl, 15234125824, 262144, kernel_bootctrl.bin, 20, fixed-<reserved>-8, 6768033e216468247bd031a0a2d9876d79818f8f
Writing kernel-bootctrl partition with kernel_bootctrl.bin
20 bytes from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_bootctrl.bin to /dev/sda: 1KB block=0 remainder=20
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_bootctrl.bin of=/dev/sda bs=1 skip=0  seek=15234125824 count=20
20+0 records in
20+0 records out
20 bytes copied, 0.0151339 s, 1.3 kB/s
Writing kernel-bootctrl partition done
writing item=58, 1:3:kernel-bootctrl_b, 15234387968, 262144, kernel_bootctrl.bin, 20, fixed-<reserved>-9, 6768033e216468247bd031a0a2d9876d79818f8f
Writing kernel-bootctrl_b partition with kernel_bootctrl.bin
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_bootctrl.bin of=/dev/sda bs=1 skip=0  seek=15234387968 count=20
20+0 records in
20+0 records out
20 bytes copied, 0.0237802 s, 0.8 kB/s
Writing kernel-bootctrl_b partition done
writing item=59, 1:3:RECROOTFS, 15234650112, 314572800, , , fixed-<reserved>-10,
[ 373]: l4t_flash_from_kernel: Warning: skip writing RECROOTFS partition as no image is specified
writing item=60, 1:3:UDA, 15549222912, 208760320, , , expand-<reserved>-11,
[ 373]: l4t_flash_from_kernel: Warning: skip writing UDA partition as no image is specified
writing item=61, 1:3:secondary_gpt, 15757983232, 16896, gpt_secondary_1_3.bin, 16896, fixed-<reserved>-0, a73c0d1e93c4355c544657cbadd176be90b40ad7
[ 374]: l4t_flash_from_kernel: Successfully flash the emmc
40906+0 records in
40906+0 records out
41887744 bytes (42 MB, 40 MiB) copied, 5.04469 s, 8.3 MB/s
writing item=4, 9:0:kernel_b, 118178729984, 67108864, boot_sigheader.img.encrypt, 41887744, fixed-<reserved>-3, 97b25dae52b11dd84096cffc89b955cc80797ae3
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/boot_sigheader.img.encrypt of=/dev/sdd bs=1K skip=0  seek=115408916 count=40906
40906+0 records in
40906+0 records out
41887744 bytes (42 MB, 40 MiB) copied, 3.69451 s, 11.3 MB/s
writing item=5, 9:0:kernel-dtb, 118245838848, 458752, kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt, 203344, fixed-<reserved>-4, c403f81de55ddbe5fddc384c40d983cf781dcb97
203344 bytes from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt to /dev/sdd: 1KB block=198 remainder=592
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sdd bs=1K skip=0  seek=115474452 count=198
198+0 records in
198+0 records out
202752 bytes (203 kB, 198 KiB) copied, 0.0138401 s, 14.6 MB/s
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sdd bs=1 skip=202752  seek=118246041600 count=592
592+0 records in
592+0 records out
592 bytes copied, 0.000448957 s, 1.3 MB/s
writing item=6, 9:0:kernel-dtb_b, 118246297600, 458752, kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt, 203344, fixed-<reserved>-5, c403f81de55ddbe5fddc384c40d983cf781dcb97
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sdd bs=1K skip=0  seek=115474900 count=198
198+0 records in
198+0 records out
202752 bytes (203 kB, 198 KiB) copied, 0.0615813 s, 3.3 MB/s
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sdd bs=1 skip=202752  seek=118246500352 count=592
592+0 records in
592+0 records out
592 bytes copied, 0.00265589 s, 223 kB/s
writing item=7, 9:0:recovery, 118246756352, 66060288, recovery_sigheader.img.encrypt, 49641472, fixed-<reserved>-6, 20492d7c310403d4b5bb9e68a09cf433d2fab0c9
49641472 bytes from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/recovery_sigheader.img.encrypt to /dev/sdd: 1KB block=48478 remainder=0
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/recovery_sigheader.img.encrypt of=/dev/sdd bs=1K skip=0  seek=115475348 count=48478
48478+0 records in
48478+0 records out
49641472 bytes (50 MB, 47 MiB) copied, 4.62664 s, 10.7 MB/s
writing item=8, 9:0:recovery-dtb, 118312816640, 524288, tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt, 203344, fixed-<reserved>-7, c403f81de55ddbe5fddc384c40d983cf781dcb97
203344 bytes from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt to /dev/sdd: 1KB block=198 remainder=592
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt of=/dev/sdd bs=1K skip=0  seek=115539860 count=198
198+0 records in
198+0 records out
202752 bytes (203 kB, 198 KiB) copied, 0.0484793 s, 4.2 MB/s
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt of=/dev/sdd bs=1 skip=202752  seek=118313019392 count=592
592+0 records in
592+0 records out
592 bytes copied, 0.00692321 s, 85.5 kB/s
writing item=9, 9:0:kernel-bootctrl, 118313340928, 262144, kernel_bootctrl.bin, 20, fixed-<reserved>-8, 6768033e216468247bd031a0a2d9876d79818f8f
20 bytes from /home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_bootctrl.bin to /dev/sdd: 1KB block=0 remainder=20
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_bootctrl.bin of=/dev/sdd bs=1 skip=0  seek=118313340928 count=20
20+0 records in
20+0 records out
20 bytes copied, 0.01304 s, 1.5 kB/s
writing item=10, 9:0:kernel-bootctrl_b, 118313603072, 262144, kernel_bootctrl.bin, 20, fixed-<reserved>-9, 6768033e216468247bd031a0a2d9876d79818f8f
dd if=/home/scs/Documents/jet/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_bootctrl.bin of=/dev/sdd bs=1 skip=0  seek=118313603072 count=20
20+0 records in
20+0 records out
20 bytes copied, 0.000392877 s, 50.9 kB/s
writing item=11, 9:0:RECROOTFS, 118313865216, 314572800, , , fixed-<reserved>-10,
[ 390]: l4t_flash_from_kernel: Warning: skip writing RECROOTFS partition as no image is specified
writing item=12, 9:0:UDA, 118628438016, 9234902528, , , expand-<reserved>-11,
[ 390]: l4t_flash_from_kernel: Warning: skip writing UDA partition as no image is specified
writing item=13, 9:0:secondary_gpt, 127863340544, 16896, gpt_secondary_9_0.bin, 16896, fixed-<reserved>-0, 8de3986c9fbd778604f0ea1ca12f6a4830398f1b
[ 390]: l4t_flash_from_kernel: Successfully flash the external device
[ 390]: l4t_flash_from_kernel: Flashing success
[ 390]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
Note: The flash process might have added some nvidia-flash-* connections in
NetworkManager to set up USB ethernet through flashing port (L4t USB Device mode).
You might want to check your NetworkManager configuration if you have some special
configuration.
Reboot target
Run command: sync; { sleep 1; reboot; } >/dev/null & on root@fe80::1%enp0s20f0u3
Success
Cleaning up...
But device got stuck on Nvidia Logo when it boots up.
Dump the uart log.
I guess it is same issue as below.
JP4.6 still has this issue.
No mine is working good if I flashed in emmc but I need it on sdcard or nvme for more storage space. Also how I can share the uart logs as I am not able to find the log file. do you mean ‘dmesg’ sorry I am new in this.
Successfully flashed by using
$ sudo ./flash.sh jetson-xavier-nx-nx215b mmcblk1p1
