I’m building custom carrier with interface to Sony Block cameras.
FPGA is outputting UYVY data stream at 1920x1080@29.97.
I have managed to get video output from camera https://youtu.be/uy282qG25Hw
but it has flashing green screen and framerate reported by vlc is 26fps.
gst pipeline:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! 'video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1' ! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)NV12' ! omxh264enc ! qtmux ! filesink location=test.mp4 -ev
Output from console:
[ 731.288853] kmtifpga 6-0036: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 731.302988] kmtifpga 6-0036: camera_common_dpd_disable: csi 0
[ 731.315017] kmtifpga 6-0036: camera_common_dpd_disable: csi 1
[ 731.327043] kmtifpga 6-0036: ov5693_power_on: power on
[ 731.364918] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.377440] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.391211] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.403743] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.416471] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.429093] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.441550] kmtifpga 6-0036: camera_common_try_fmt: size 1 x 1
[ 731.453420] kmtifpga 6-0036: camera_common_try_fmt: invalid resolution supplied to set mode 1920 1080
[ 731.468692] kmtifpga 6-0036: camera_common_try_fmt: size 32768 x 32768
[ 731.481244] kmtifpga 6-0036: camera_common_try_fmt: invalid resolution supplied to set mode 1920 1080
[ 731.496652] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.509086] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.521565] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.533899] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.546008] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.558217] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.570391] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.582452] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.594466] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.606754] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.619034] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.631223] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.643399] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.655641] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.667562] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.679525] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.691299] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.703011] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.714781] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.726689] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.738642] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.750572] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.762465] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.774442] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.786190] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.797959] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.809715] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.821545] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.833254] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.845221] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.857271] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.869239] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.881160] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.893093] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.904911] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.916765] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.928500] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.940303] kmtifpga 6-0036: camera_common_try_fmt: size 800 x 480
[ 731.952035] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.963943] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.975995] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.987879] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 731.999843] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 732.012548] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 732.024484] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 732.036526] kmtifpga 6-0036: camera_common_s_fmt(8207) size 1920 x 1080
[ 732.048706] kmtifpga 6-0036: camera_common_try_fmt: size 1920 x 1080
[ 732.102127] kmtifpga 6-0036: camera_common_g_fmt++
[ 732.112664] misc tegra_camera_ctrl: vi_v4l2_update_isobw:Set iso bw 143078 kbyteps at 17885 KHz
[ 732.127425] misc tegra_camera_ctrl: tegra_camera_isomgr_request++ bw=143078, lt=4
[ 732.140950] misc tegra_camera_ctrl: tegra_camera_isomgr_request: tegra_camera isomgr latency is 4 usec
[ 732.156669] vi 54080000.vi: Calibrate csi port 0
[ 732.167599] kmtifpga 6-0036: ov5693_s_stream++
[ 732.178072] kmtifpga 6-0036: ov5693_s_stream--
[ 734.392148] kmtifpga 6-0036: ov5693_s_stream++
[ 734.402739] misc tegra_camera_ctrl: vi_v4l2_update_isobw:Set iso bw 0 kbyteps at 0 KHz
[ 734.417474] misc tegra_camera_ctrl: tegra_camera_isomgr_request++ bw=0, lt=4
[ 734.431635] misc tegra_camera_ctrl: tegra_camera_isomgr_request: tegra_camera isomgr latency is 4 usec
[ 734.447432] kmtifpga 6-0036: camera_common_g_fmt++
[ 734.458802] misc tegra_camera_ctrl: vi_v4l2_update_isobw:Set iso bw 143078 kbyteps at 17885 KHz
[ 734.474180] misc tegra_camera_ctrl: tegra_camera_isomgr_request++ bw=143078, lt=4
[ 734.488430] misc tegra_camera_ctrl: tegra_camera_isomgr_request: tegra_camera isomgr latency is 4 usec
[ 734.505185] vi 54080000.vi: Calibrate csi port 0
[ 734.516806] kmtifpga 6-0036: ov5693_s_stream++
[ 734.529483] kmtifpga 6-0036: ov5693_s_stream--
[ 734.584521] video4linux video0: Syncpoint already enabled at capture done!0
[ 734.675447] video4linux video0: MW_ACK_DONE syncpoint time out!0
[ 734.688200] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000004
[ 734.701077] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000090
[ 734.714000] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 734.726205] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 734.738452] kmtifpga 6-0036: ov5693_s_stream++
[ 734.749478] misc tegra_camera_ctrl: vi_v4l2_update_isobw:Set iso bw 0 kbyteps at 0 KHz
[ 734.763934] misc tegra_camera_ctrl: tegra_camera_isomgr_request++ bw=0, lt=4
[ 734.777548] misc tegra_camera_ctrl: tegra_camera_isomgr_request: tegra_camera isomgr latency is 4 usec
[ 734.793596] kmtifpga 6-0036: camera_common_g_fmt++
[ 734.804920] misc tegra_camera_ctrl: vi_v4l2_update_isobw:Set iso bw 143078 kbyteps at 17885 KHz
[ 734.820210] misc tegra_camera_ctrl: tegra_camera_isomgr_request++ bw=143078, lt=4
[ 734.834246] misc tegra_camera_ctrl: tegra_camera_isomgr_request: tegra_camera isomgr latency is 4 usec
[ 734.850815] misc tegra_camera_ctrl: vi_v4l2_update_isobw:Set iso bw 0 kbyteps at 0 KHz
[ 734.865237] misc tegra_camera_ctrl: tegra_camera_isomgr_request++ bw=0, lt=4
[ 734.878914] misc tegra_camera_ctrl: tegra_camera_isomgr_request: tegra_camera isomgr latency is 4 usec
[ 734.915042] kmtifpga 6-0036: ov5693_power_off: power off
[ 734.927727] kmtifpga 6-0036: camera_common_dpd_enable: csi 0
[ 734.940116] kmtifpga 6-0036: camera_common_dpd_enable: csi 1
[ 734.952253] kmtifpga 6-0036: camera_common_mclk_disable: disable MCLK
There seems to be error on first frame, but I think this is unimportant. Or is this framerate problem? (29.96 vs 30fps)
I have checked CSI signals and there seems to be no blank data signals. Could this be a problem with encoding?
