Flashing Jetson Orin Nano Super through USB on nvme not working
I am trying to install Jetpack 6.2 in NVME on Jetson Orin Nano Super but I get error:
I followed the steps provided in
https://docs.nvidia.com/sdk-manager/wsl-systems/index.html
Additional information:
SDKM_logs_JetPack_6.2_Linux_for_Jetson_Orin_Nano_[8GB_developer_kit_version]_2025-01-26_14-53-54.zip (531.4 KB)
NVME is 256GB with ext4 partition
I also tried to install Jetpack 6.1. Logs are attached.
SDKM_logs_JetPack_6.1_(rev._1)Linux_for_Jetson_Orin_Nano[8GB_developer_kit_version]_2025-01-26_15-00-43.zip|attachment (756.7 KB)
I did succeed with installing on SD card before. I have removed the SD card before attempting any of the above.
Please check
Windows Subsystem for Linux (WSL) — SDK Manager
  1. Flashing an external storage device is not supported.
Would be great if you can have a Ubuntu host PC. So you can follow the guiadance to flash the Orin Nano developer kit:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
My apologies I provided the wrong link. I am attempting to install on Ubuntu host system.
This is the link I followed:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
I realized the issue was I was trying to install on an M.2 SATA SSD and not NVMe SSD. It worked as intended after changing the SSD.
Please delete the post if you wish.
