Flashing orin nano
I have a 8gb orin nano. my tx2 nx has never successfully flashed using the sdkmanager, only from the command line. I assume it is due to the a203v2 carrier board. like the tx2 nx the orin nano 8gb is detected by the sdkmanager and fails to flash. What is the command that somebody would use to flash the orin nano 8gb? have flashed it twice using the jetson-orin-nano-devkit or jetson-orin-nano-devkit-nvme. I have a 128gb nvme ssd which is pcie as well. it seemed to succeed with nvme but hang the other way. Is there a way I can install on a flashdrive to see if the nvme is the issue. Also not sure if I need a specific dtb to use the a203v2 with the orin nano 8gb module
I used this command got it to go to this point:
    sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg" --network usb0 jetson-orin-nano-devkit-nvme external
 Entering RCM boot
[   0.0372 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0373 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0373 ] rcm boot with presigned binaries
[   0.0383 ] tegrarcm_v2 --instance 2-1.6 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0390 ] BR_CID: 0x80012344705DD4578400000003000280
[   0.0515 ] Sending bct_br
[   0.0585 ] Sending mb1
[   0.0590 ] Sending psc_bl1
[   0.0699 ] Sending bct_mb1
[   0.0764 ] Generating blob for T23x
[   0.0805 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0819 ] The number of images in blob is 18
[   0.0828 ] blobsize is 73393246
[   0.0831 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3182656
[   0.1141 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[   0.1147 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[   0.1153 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[   0.1157 ] Not supported type: mb2_applet
[   0.1159 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437984
[   0.1165 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[   0.1170 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[   0.1201 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.1217 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1047936
[   0.1223 ] Added binary blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt of size 110080
[   0.1229 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[   0.1234 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[   0.1239 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[   0.1244 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.1248 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[   0.1253 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.1258 ] Added binary blob_boot0.img of size 55418880
[   0.1513 ] Added binary blob_tegra234-p3767-0003-p3768-0000-a0.dtb of size 345518
[   0.2014 ] tegrarcm_v2 --instance 2-1.6 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.2027 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[   0.3053 ] Sending bct_mem
[   0.3186 ] Sending blob
[   3.4456 ] RCM-boot started
~/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Cleaning up...
Is there a way to flash a ssd through a usb a enclosure? here is the error I get from the sdkmanager.
SDKM_logs_JetPack_5.1.1_Linux_for_Jetson_Orin_Nano_modules_2023-04-04_21-02-20.zip (292.7 KB)
this is attempting to flash through the a203v2 using the sdkmanager and selecting nvme for the rootfs
None devkit is not able to use SDK manager, suggest to contact with the vendor to know how to flash with the A203v2 carrier board.
Is there a way prepare a ssd in a usb enclosure? I assume I should be able to boot the module with usb or sd card.
Hi AlexW,
So, which external device you want to boot from? (NVMe, USB, SD)
To flash into USB storage, please use sda1 instead of nvme0n1p1 in above flash command.
so from my host pc that has ubuntu 18.04 and the sdkmanager am I able to mount my ssd that is in an enclosure. it would show up as sdx at that point. And this would be without the device connected at all. I am not sure if there is anything on the orin nano 8gb that would need to be done for the bootloader. I also realized that seeedstudio just released the a603 meant for the orin. This board looks to be the same as the a203 minus the sdcard reader. I am going to find my usb serial cable to see if I can at least see what is happening on boot and during the flash process until I can get the a603. It doesnt look like the dev kit carrier board is sold separately.
NVMe SSD should be connected on the carrier board…
Do you get the custom BSP package of Jetpack 5.1.1 from seeedstudio?
Please let me know the exactly requirement of you.
I haven’t been able to order the a603 due to issues with the it site. What’s interesting is that with the a203 I am able to detect the Orin nano etc. not sure what differences there are in the boards other than the lack of microscopic card port. I still need to get bsp from them unless I can use Xavier nx bsp with Orin nano
Hi AlexW,
Yes, if you are using the custom carrier board, please get the custom BSP package from your vendor first.
Hi AlexW,
I don’t know if you already solved the problem but i came across the same issue when placing an Orin NX in Xavier Dev kit board. the flashing would time out checking for a successfull boot.
I noticed via a different forum post that if you place a ttl/usb cable on the Orin’s debug console it doesn’t time out and correctly identifies the Orin NX module.
Perhaps of some convenience for someone experiencing the same issue.
I had actually tried flashing and watched through a prolific usb to serial ftdi cable. I noticed it hanging there as well. I now have the a603 and was able to successfully flash the board.
