There’s a bunch of context I could provide, but it’s not all that relevant. I want to flash RootFS with A/B partition on my NVMEs and a separate partition for some decently large sized personal data that needs to be permanent.
I looked through the documentation, and discussions, and couldn’t find a meaningful answer. I did write a flash.xml, that looks like this
<partition name="APP" id="1" type="data">
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> APPSIZE </size>
<file_system_attribute> 0 </file_system_attribute>
<allocation_attribute> 0x8 </allocation_attribute>
<align_boundary> 16384 </align_boundary>
<percent_reserved> 0 </percent_reserved>
<unique_guid> APPUUID </unique_guid>
<filename> APPFILE </filename>
<description> **Required.** Contains the rootfs. This partition must be assigned
the "1" for id as it is physically put to the end of the device, so that it
can be accessed as the fixed known special device `/dev/nvme0n1p1`. </description>
</partition>
<partition name="APP_b" id="2" type="data">
<unique_guid> APPUUID_b </unique_guid>
<filename> APPFILE_b </filename>
the "2" for id as it is physically put to the end of the device, so that it
can be accessed as the fixed known special device `/dev/nvme0n1p2`. </description>
</partition>
But I’m not sure how do I force it to use NVME and the other partition on the MMC. Any help is appreciated!
