Hi all,
I am using a Xavier NX on a Nvidia devkit carrier board. Im able to correctly flash the Jetson with a NVME ssd using these steps: Quick Start — Jetson Linux Developer Guide documentation and then using this command to flash the Jetson:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_l4t_t194_qspi_p3668.xml" –showlogs --network usb0 jetson-xavier-nx-devkit-emmc internal
This all works fine etc. Now I am trying to do the same thing but then inside a Docker container. This works up to the point of Step 3: Start the flashing process
Then It says
Waiting for target to boot-up…
Timeout
Cleaning up…
The Fan on the Jetson starts to spin at max speed and it doesnt boot. What can cause this issue?
Also is this the only way to flash the os a nvme ssd? Or can I also somehow use the ./flash.sh script?
