I’m getting these errors when I try to run an old code on a 64-bit machine with the 64-bit PGI compiler:
Line 673–> chi1 = 8.0sqrt(pi/elmass)avgcharge**4/(3.(2.boltz)1.5)
Line 674–> chi2 = log(boltz3/(piavg*charge**6))
pgf77 -c -g -C -O npchemin.f
PGFTN-W-0130-Floating point underflow. Check constants and constant expressions (npchemin.f: 673)
PGFTN-W-0130-Floating point underflow. Check constants and constant expressions (npchemin.f: 674)
PGFTN-W-0132-Floating pt. invalid oprnd. Check constants and constant expressions (npchemin.f: 674)
0 inform, 3 warnings, 0 severes, 0 fatal for npchemin
PGFTN/x86-64 Linux 7.1-6: compilation completed with warnings
These are defined in a file name npcomon:
BOLTZ=1.380622D-23
PI=3.1415926536
AVG=6.022169D+26
BOLTZ=1.380622D-23
I tried changing from “E” to “D” in the constants.
This code has run fine in the past on a 32-bit SGI machine. I get the same errors using the 32-bit PGI compiler.
I get a “floating exception” error. If I add the -Ktrap=inv,unf,fp flags, I get a NaN followed by a segmentation fault.
