I have a case where pgfortran 14.1 with -O2 -Ktrap=fp has no problem,
but pgfortran 15.1 with the same flags gives a floating point exception.
Here is the code, comments at the start explain things.
Is this a problem with pgfortran 15.1?
C
C Is there a bug in the PGI 15.1 Fortran compiler?
C Look at this:
C % pgfortran -g -O1 -Ktrap=fp -o bndf bndf.F
C % ./bndf
C DBNI(NBNDR-1)= 8.11920E-01
C
C % pgfortran -g -O2 -o bndf bndf.F
C % ./bndf
C
C % pgfortran -g -Ktrap=fp -o bndf bndf.F
C % ./bndf
C
C % pgfortran -g -O2 -Ktrap=fp -o bndf bndf.F
C % ./bndf
C Floating point exception (core dumped)
C
C % pgfortran -g -fast -Ktrap=fp -o bndf bndf.F
C % ./bndf
C
C The combination of -O2 and -Ktrap=fp causes a floating-point exception?
C
C Compiler used:
C % pgfortran -V
C pgfortran 15.1-0 64-bit target on x86-64 Linux -tp sandybridge
C
C Hardware is: Intel Xeon CPU E5-2630 0 @ 2.30GHz
C
C This problem does not occur with the 14.1 compiler.
C This code is a small extract from a much larger program, I have
C not tried to clean it up or boil it down to the smallest possible size.
C
PROGRAM BNDF
IMPLICIT NONE
INTEGER :: NDM,NNODE,NNODE1,NFACE,NFBND,NBNDR,MXPPF
REAL(KIND=8), DIMENSION(:), ALLOCATABLE :: FBN,DBNI,FBF
REAL(KIND=8), DIMENSION(:,:), ALLOCATABLE :: COORD
REAL(KIND=8), DIMENSION(:), ALLOCATABLE :: XFC,YFC,ZFC
INTEGER, DIMENSION(:), ALLOCATABLE :: NUMPPF
INTEGER, DIMENSION(:,:), ALLOCATABLE :: IFACE,IPNT
INTEGER :: I,J
REAL(KIND=8) :: S
C
C
C Just make up some numbers here.
C
NDM = 3
NNODE = 810
NNODE1 = 900
NFACE = 925
NFBND = 129
NBNDR = 133
MXPPF = 3
ALLOCATE ( XFC(NFBND),YFC(NFBND),ZFC(NFBND) )
DO I = 1,NFBND
XFC(I) = I - 0.5
YFC(I) = 2.
ZFC(I) = 3.
ENDDO
ALLOCATE ( IFACE(NFACE,2),NUMPPF(NFACE),IPNT(NFACE,MXPPF),
& COORD(NNODE1,NDM),FBN(NBNDR),DBNI(NBNDR),FBF(NFBND) )
IFACE(1:NFACE,1) = 0
IFACE(1:NFACE,2) = 4
NUMPPF(1:NFACE) = 3
DO J = 1,MXPPF
DO I = 1,NFACE
C
C IPNT(I,J) = quasi-random number between 1 and NBNDR
C Not using random for portability/repeatability/checkability reasons.
C Instead use something with cosine function.
C
S = ABS(COS( REAL(I + (J-1)*NFACE) ))
IPNT(I,J) = REAL(NBNDR)*S
IPNT(I,J) = MAX(IPNT(I,J),1)
IPNT(I,J) = MIN(IPNT(I,J),NBNDR)
ENDDO
ENDDO
DO I = 1,NFBND
FBF(I) = I
ENDDO
DO I = 1,NNODE1
COORD(I,1) = I
COORD(I,2) = 2.
COORD(I,3) = 3.
ENDDO
CALL BNDF_TO_BNDN( NDM,NNODE,NNODE1,NFACE,NFBND,NBNDR,MXPPF,
& COORD,FBN,DBNI,IFACE,NUMPPF,IPNT,FBF,
& XFC,YFC,ZFC )
C
C Phony printout here so compiler doesn't optimize everything away.
C
WRITE(*,"('DBNI(NBNDR-1)=',ES15.5)") DBNI(NBNDR-1)
END PROGRAM BNDF
C
C
SUBROUTINE BNDF_TO_BNDN( NDM,NNODE,NNODE1,NFACE,NFBND,NBNDR,MXPPF,
& XFC,YFC,ZFC )
IMPLICIT NONE
INTEGER :: IFACE(NFACE,2),NUMPPF(NFACE),IPNT(NFACE,MXPPF)
REAL(8) :: COORD(NNODE1,NDM),FBN(NBNDR),DBNI(NBNDR),FBF(NFBND)
REAL(8), DIMENSION(NFBND) :: XFC,YFC,ZFC
C
INTEGER :: NF,MTYPE,K,IP,I
REAL(8) :: DX,DY,DZ,RBND
C
DBNI(:) = 0.0
FBN(:) = 0.0
C
LOOP1: DO NF = 1,NFBND
MTYPE = IFACE(NF,2)
IF (MTYPE.NE.4 .AND. MTYPE.NE.44) CYCLE LOOP1
DO K = 1,NUMPPF(NF)
IP = IPNT(NF,K)
DX = XFC(NF) - COORD(IP,1)
DY = YFC(NF) - COORD(IP,2)
DZ = ZFC(NF) - COORD(IP,3)
RBND = 1.0/SQRT(DX*DX+DY*DY+DZ*DZ)
FBN(IP) = FBN(IP) + RBND*FBF(NF)
DBNI(IP) = DBNI(IP) + RBND
ENDDO
ENDDO LOOP1
DO I = 1,NBNDR
IF (DBNI(I).NE.0.) FBN(I) = FBN(I)/DBNI(I)
ENDDO
C
RETURN
END SUBROUTINE BNDF_TO_BNDN
