If the following simple program was compiled with options of -O and -Ktrap=fp, the program would produce floating exception (core dumped). The nvfortran version is 23.1-0 64-bit target on x86-64 Linux.
The nvfortran pack two dividend in one xmm register, and two divisor in another xmm register, then generates simd instruction vdivps for the two divisions. The xmm registers contain 4 packed single precision numbers, two are dividends or divisors, the others two are set 0, which cause divide by zero floating exception by vdivps.
module mtt
type :: tt
real :: a, b
contains
procedure, pass(this) :: init => tt_init
end type tt
contains
subroutine tt_init(this, a, b)
implicit none
class(tt), intent(inout) :: this
real, intent(in) :: a, b
this%a = a
this%b = b
end subroutine tt_init
end module mtt
program test
use mtt
implicit none
type(tt) :: tt1, tt2
integer :: c
call tt1%init(1.0, 2.0)
call tt2%init(3.0, 4.0)
c = tt1%a/tt2%a + tt1%b/tt2%b
print*, c
end program test
