I think I’ve found a bug in nvfortran 22.5, when compiling and running the following code
MODULE m1
IMPLICIT NONE
SAVE
LOGICAL :: l1, l2, l3(1)
TYPE t1
INTEGER :: i
TYPE (t1), POINTER :: n
ENDTYPE t1
TYPE (t1), TARGET :: t2
CONTAINS
SUBROUTINE s1
TYPE(t1),POINTER :: t3
DOUBLE PRECISION :: r1, r2, r3, r4, r5, r6, r7(2,1), r8(1)
LOGICAL :: l4
INTEGER :: i1(1)
l4 = .FALSE.
r7 = 0
IF ( l1 ) THEN
IF ( l2 ) l4 = r7(2,1) > 0
IF( l4 ) THEN
CALL s2
ENDIF
ENDIF
t3 => t2
DO WHILE ( ASSOCIATED(t3) )
IF ( l3(t3%i) ) THEN
r2 = r3 / r4
r5 = r2**3
r5 = r5 * r6
ENDIF
t3 => t3%n
ENDDO
CONTAINS
SUBROUTINE s2
END SUBROUTINE
END SUBROUTINE
END MODULE
PROGRAM p1
use m1
IMPLICIT NONE
l1 = .FALSE.
l2 = .FALSE.
l3 = .FALSE.
t2%i = 1
NULLIFY(t2%n)
CALL s1
END PROGRAM
$ nvfortran -V
nvfortran 22.5-0 64-bit target on x86-64 Linux -tp haswell
$ nvfortran -Ktrap=fp -Kieee -O2 code.f90
$ ./a.out
Floating point exception (core dumped)
None of the floating point operations should be executed, so the floating point exception shouldn’t occur. The problem goes away when compiling without “-Kieee” or with “-O0” instead of “-O2”.
Hi Andrew,
I think what’s happening is that since “r2”, “r3”, and “r4” are invariant in the do while loop, it’s safe for the compiler to hoist this line so it’s only computed once. However since they are uninitialized, the “invalid” floating point exception is getting triggered. If “r3” and “r4” as initialized, then the FP exception goes away.
Is it your intent to have these variables be uninitialized?
-Mat
Hi Mat,
Thanks for the response.
In the original function, r3 and r4 are both initialised within the loop and they are not invariant, but I still get a floating point exception.
You’re right that the problem goes away if they’re initialised in the simplified code I posted. The original code is much more complex. I’ll see if I can produce another example that reproduces the problem and get back to you.
I’ve tweaked the original example so that r2 is no longer invariant. (Strictly speaking r2 isn’t invariant in the original either unleass l3(t3%i) == .TRUE.
on the first iteration of the loop.)
It still shows the same problem.
MODULE m1
IMPLICIT NONE
SAVE
TYPE t1
INTEGER :: i
DOUBLE PRECISION :: r9
ENDTYPE t1
CONTAINS
SUBROUTINE s1
LOGICAL :: l4
INTEGER :: i1(1)
l4 = .FALSE.
r7 = 0
IF ( l1 ) THEN
IF( l4 ) THEN
CALL s2
ENDIF
ENDIF
IF ( ANY(l3) ) THEN
r3 = 1D0
r4 = 1D0
r6 = 1D0
ENDIF
t3 => t2
r2 = r3 / r4 / t3%r9
r5 = r2**3
r5 = r5 * r6
ENDIF
t3 => t3%n
ENDDO
CONTAINS
SUBROUTINE s2
END SUBROUTINE
END SUBROUTINE
END MODULE
PROGRAM p1
use m1
IMPLICIT NONE
l1 = .FALSE.
l2 = .FALSE.
l3 = .FALSE.
t2%i = 1
t2%r9 = 1D0
NULLIFY(t2%n)
CALL s1
END PROGRAM
I tried a few different systems (Haswell, Epyc, Skylake) and compiler versions (22.3, 22.5), but unfortunately I’m not able to reproduce the error.
% nvfortran -V22.5 -Kieee -Ktrap=fp -O2 code.f90 ; a.out
I think I posted the wrong version.
Try changing the line
to
r2 = r3 / r4 / (1D0 + t3%r9)
Looks to be a similar issue where “r3/r4” gets hoisted and since they are uninitialized variables, the invalid exception is being triggered. If “l3” gets initialized to true, and therefore r3 and r4 are set, then the error goes away.
I can submit an issue report. Though I’m concerned that the “fix” would be to disable invariant hoisting which is generally very useful for performance. Especially here given divides are expensive. Granted, they might be able to limit disabling to when -Kieee is used, given “-Kieee” deoptimizes code anyway.
Then again the “invalid” exception is extraneous in this case and shouldn’t impact the execution of the code Would it be ok for you to ignore this by not using the aggregate “fp” sub-option and instead use “-Ktrap=divz,ovf” to check just for overflows and divide-by-zero?
Thanks for your help.
I need to be able to trap all floating point exceptions, so -Ktrap=divz,ovf
isn’t an option, unfortunately.
I can fix the problem either by initialising r3 and r4 with dummy values when .NOT.ANY(l3) or by hoisting the invariant r3/r4 and placing it in the IF statement by hand.
Could you submit an issue report, please? I have to say that I’m bothered that the compiler can produce an incorrect binary from correct code for any choice of optimisations. This problem doesn’t occur with pgfortran 20.4, gfortran or Intel. I don’t think the developers should have to take account of what the compiler might do when it’s optimising a loop.
Couldn’t the compiler check whether it’s safe to hoist an invariant and, if it’s unsafe, print a warning instead?
Done. Filed TPR #31984 and sent it engineering for further investigation.
-Mat
