The following code raises a floating point exception when compiled with -Ktrap=divz -O2.
MODULE m1
CONTAINS
SUBROUTINE s1(r1,r2,r3)
DOUBLE PRECISION r1,r2,r3
DOUBLE PRECISION r4,r5,r6
DOUBLE PRECISION r7,r8,r9
INTRINSIC ABS, ATAN, COS, SIN
PRINT '(6(ES23.16,","))',r1,r2,r3
r4 = r1
r5 = r2
r6 = r3
PRINT '(3ES24.16)',r4,r5,r6
PRINT '(2ES24.16)',ABS(r5-r4),ABS(r6)
PRINT *,ABS(r5-r4).LE.ABS(r6)
IF(ABS(r5 - r4).LE.ABS(r6))THEN
r7 = 1.0D0
ELSE
r7 = ATAN(r6/(r5 - r4))
ENDIF
PRINT*,'check 1'
r8 = COS(r7)
r9 = SIN(r7)
PRINT*,'check 2'
r4 = r8
PRINT*,'check 3'
END
END MODULE m1
PROGRAM p1
USE m1
CALL s1(0D0,0D0,1D0)
END
$ nvfortran -V
nvfortran 22.5-0 64-bit target on x86-64 Linux -tp haswell
$ nvfortran -Ktrap=divz -O2 code.f90 && ./a.out
0.0000000000000000E+00, 0.0000000000000000E+00, 1.0000000000000000E+00,
0.0000000000000000E+00 0.0000000000000000E+00 1.0000000000000000E+00
T
Floating point exception (core dumped)
It seems to work with lower optimisation -Ktrap=div -O1:
$ nvfortran -Ktrap=divz -O1 code.f90 && ./a.out
T
check 1
check 2
check 3
