C Possible bug in Portland Group 15.4 Fortran compiler.
C Compile with
C pgfortran -O1 -g -o kwktest_O1 kwktest.F
C pgfortran -O2 -g -o kwktest_O2 kwktest.F
C Run the codes:
C kwktest_O1 > kwktest_O1.out
C kwktest_O2 > kwktest_O2.out
C
C The two output files are different, diff kwktest_O[12].out gives:
C48c48
C< 256.4083 256.4083 256.4083 256.4083 256.4083
C---
C> 266.6667 266.6667 266.6667 266.6667 256.4083
C
C I believe the output from the -O1 compilation is correct, and
C the output from the -O2 compilation is incorrect.
C Using the gfortran compiler gives the same answer as pgfortran with -O1.
C This problem does not occur with the PGI 15.1 compiler, PGI 15.1 with
C -O1 and -O2 give identical correct output.
C
C I believe the problem arises from an incorrect handling of the IF clause
C inside the double loop in subroutine KWFKWK:
C DO L = LS,LE
C DO J = JS,JE
C ...
C IF (IBWF(J,L).EQ.-1) THEN
C ...
C ELSE
C ...
C ENDIF
C ...
C ENDDO
C ENDDO
C
C Compiler used:
C pgfortran -V
C pgfortran 15.4-0 64-bit target on x86-64 Linux -tp sandybridge
C
PROGRAM KWKTEST
C
IMPLICIT NONE
INTEGER, PARAMETER :: JD=621, KD=11, LD=3
INTEGER, PARAMETER :: JS=221, JE=226, LS=1, LE=3
REAL*8, PARAMETER :: REY=25000.
C
INTEGER :: J,K,L,KP
INTEGER, DIMENSION(JS:JE,LS:LE) :: IBWF
REAL*8, DIMENSION(JS:JE,LS:LE) :: YWALL,USTAR,VMUT1
REAL*8, DIMENSION(JD,KD,LD) :: RHO
REAL*8, DIMENSION(JD,KD,LD,2) :: QT
REAL*8, DIMENSION(JD,KD,LD) :: VMUL
REAL*8, DIMENSION(JD,KD,LD) :: VMUT
C
C
RHO(:,:,:) = 1.D0
YWALL(:,:) = 0.01D0
USTAR(:,:) = 0.3129165D0
VMUT1(:,:) = 13.76896D0
IBWF(:,:) = -1
QT(:,:,:,1) = 0.D0
QT(:,:,:,2) = 266.6667D0
VMUL(:,:,:) = 1.D0
VMUT(:,:,:) = 0.0125D0
K = 1
KP = 2
C
CALL KWFKWK ( JS,JE,K,KP,LS,LE,REY,
& IBWF,YWALL,USTAR,VMUT1,
& RHO,QT,VMUL,VMUT,JD,KD,LD )
C
C
END PROGRAM KWKTEST
C
C
SUBROUTINE KWFKWK ( JS,JE,K,KP,LS,LE,REY,
IMPLICIT NONE
REAL*8, PARAMETER :: KAPPA=0.41D0
REAL*8, PARAMETER :: CMU=0.09D0
REAL*8, PARAMETER :: BETAST=0.09D0
REAL*8, PARAMETER :: CON1=60.
REAL*8, PARAMETER :: MUTMIN_WF=0.001D0
C
INTEGER, INTENT (IN) :: JS,JE,K,KP,LS,LE,JD,KD,LD
REAL*8, INTENT (IN) :: REY
INTEGER, DIMENSION(JS:JE,LS:LE), INTENT (IN) :: IBWF
REAL*8, DIMENSION(JS:JE,LS:LE), INTENT (IN) :: YWALL,USTAR,VMUT1
REAL*8, DIMENSION(JD,KD,LD), INTENT (IN) :: RHO
REAL*8, DIMENSION(JD,KD,LD,2), INTENT (INOUT) :: QT
REAL*8, DIMENSION(JD,KD,LD), INTENT (IN) :: VMUL
REAL*8, DIMENSION(JD,KD,LD), INTENT (INOUT) :: VMUT
C
INTEGER :: J,L
REAL*8 :: REI
REAL*8 :: VNUW,RDIST,OMEGAW,TEMP1,TEMP2
C
C
C begin debug printing
WRITE(*,"('Start KWFKWK, JD,KD,LD,JS,JE,LS,LE=',7I5)")
& JD,KD,LD,JS,JE,LS,LE
L = 2
WRITE(*,"('IBWF')")
DO J = JS,JE,10
WRITE(*,"(10I5)") IBWF(J:MIN(J+9,JE),L)
ENDDO
WRITE(*,"('YWALL')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") YWALL(J:MIN(J+4,JE),L)
ENDDO
WRITE(*,"('USTAR')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") USTAR(J:MIN(J+4,JE),L)
ENDDO
WRITE(*,"('VMUT1')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") VMUT1(J:MIN(J+4,JE),L)
ENDDO
WRITE(*,"('RHO(,K,L)')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") RHO(J:MIN(J+4,JE),K,L)
ENDDO
WRITE(*,"('RHO(,KP,L)')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") RHO(J:MIN(J+4,JE),KP,L)
ENDDO
WRITE(*,"('VMUL')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") VMUL(J:MIN(J+4,JE),K,L)
ENDDO
WRITE(*,"('VMUT')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") VMUT(J:MIN(J+4,JE),K,L)
ENDDO
WRITE(*,"('QT(.,K,.,1)')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") QT(J:MIN(J+4,JE),K,L,1)
ENDDO
WRITE(*,"('QT(.,K,.,2)')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") QT(J:MIN(J+4,JE),K,L,2)
ENDDO
C end debug printing
REI = 1./REY
DO L = LS,LE
DO J = JS,JE
VNUW = REI*VMUL(J,K,L)/RHO(J,K,L)
RDIST = 1./YWALL(J,L)
OMEGAW = (CON1/BETAST)*(VNUW*RDIST**2)
VMUT(J,KP,L) = 0.6*MAX(VMUT1(J,L),MUTMIN_WF)
TEMP1 = (6./0.075)*(VNUW*RDIST**2)
TEMP2 = USTAR(J,L)*RDIST/(SQRT(CMU)*KAPPA)
QT(J,KP,L,2) = SQRT(TEMP1**2 + TEMP2**2)
QT(J,KP,L,1) = QT(J,KP,L,2)*REI*VMUT(J,KP,L)/RHO(J,KP,L)
QT(J,K,L,2) = 0.
QT(J,KP,L,2) = MIN(QT(J,KP,L,2),OMEGAW)
ELSE
QT(J,K,L,2) = OMEGAW
ENDIF
QT(J,K,L,1) = 0.
VMUT(J,K,L) = 0.
ENDDO
ENDDO
WRITE(*,"('End KWFKWK')")
L = 2
WRITE(*,"('VMUT(K)')")
DO J = JS,JE,5
ENDDO
WRITE(*,"('VMUT(KP)')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") VMUT(J:MIN(J+4,JE),KP,L)
ENDDO
DO J = JS,JE,5
ENDDO
DO J = JS,JE,5
ENDDO
WRITE(*,"('QT(.,KP,.,1)')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") QT(J:MIN(J+4,JE),KP,L,1)
ENDDO
WRITE(*,"('QT(.,KP,.,2)')")
DO J = JS,JE,5
WRITE(*,"(5G15.7)") QT(J:MIN(J+4,JE),KP,L,2)
ENDDO
C
C
RETURN
END
Thanks Dennis. This looks like a problem with our new conditional vectorizer. Adding “-Mvect=nocond” works around the problem. I added TPR#21740 and sent on to engineering for further investigation.
- Mat
TPR 21740 has been fixed in the current 15.7 release.
thanks,
dave
