To complement this thread, I’m using the shiftr/shiftl among others, to work in these fast log functions:
Summary
! SPDX-FileCopyrightText: 2016-2022 Federico Perini <perini@wisc.edu>
! SPDX-License-Identifier: MIT
!> @brief A module to compute FAST logarithm functions, based on Perini and Reitz, "Fast **
!> approximations of exponential and logarithm functions combined with efficient **
!> storage/retrieval for combustion kinetics calculations" Comb Flame 194(2018), 37-51. **
module fast_log
use, intrinsic :: iso_fortran_env, only: dp=>real64
use utilities
implicit none
private
public :: flog_p3, flog_p5
interface flog_p3
module procedure flog_p3_dp
end interface
interface flog_p5
module procedure flog_p5_dp
end interface
contains
elemental function flog_p3_dp(x) result(y)
integer, parameter :: wp = dp
real(wp), intent(in) :: x
real(wp) :: y
!-- Internal Variables
real(wp) :: xi,xf
integer(wp) :: iwp
integer(wp), parameter :: mantissa_left = 2_wp**52
integer(wp), parameter :: mantissa = -9218868437227405313_wp ! not(shiftl(2047_wp,52))
integer(wp), parameter :: bias = 1023_wp
integer(wp), parameter :: ishift = mantissa_left*bias
real(wp), parameter :: log2 = log(2._wp)
real(wp), parameter :: rlog2 = 1._wp/log2
real(wp), parameter :: sqrt2 = sqrt(2._wp)
real(wp), parameter :: s(3)= [rlog2,3.0_wp-2.5_wp*rlog2,1.5_wp*rlog2-2.0_wp]
iwp = transfer(x,iwp)
xi = shiftr(iwp,52)-bias
! Take mantissa part only
xf = transfer(iand(iwp,mantissa)+ishift,xf)-1._wp
! Apply cubic polynomial
xf = xf*(s(1)+xf*(s(2)+xf*s(3)))
! Compute log and Change of basis: log_2(x) -> log_e(x) = log2*log_2(x)
y = (xf+xi)*log2
end function flog_p3_dp
elemental function flog_p5_dp(x) result(y)
real(wp) :: y
real(wp) :: xi,xf
integer(wp) :: iwp
real(wp), parameter :: s(5)= [ 1.44269504088896e+0_wp,&
-7.21347520444482e-1_wp,&
4.42145354110618e-1_wp,&
-2.12375830888126e-1_wp,&
4.88829563330264e-2_wp]
! Apply quintic polynomial
xf = xf*(s(1)+xf*(s(2)+xf*(s(3)+xf*(s(4)+xf*s(5)))))
y = (xf+xi)*log2
end function flog_p5_dp
end module fast_log
Here
integer(wp), parameter :: mantissa = not(shiftl(2047_wp,52))
I get the error
NVFORTRAN-S-0155-Intrinsic not supported in initialization: not (././src/fast_log.f90: 36)
0 inform, 0 warnings, 1 severes, 0 fatal for flog_p3_dp
NVFORTRAN-S-0155-Intrinsic not supported in initialization: not (././src/fast_log.f90: 67)
0 inform, 0 warnings, 1 severes, 0 fatal for flog_p5_dp
So I had to define the constant -9218868437227405313_wp but enabling evaluation of intrinsic functions for declaring a parameter value is something standard with other compilers.
