Continuing the discussion from FPS in test apps.:
• Hardware Platform (Jetson / GPU) Tesla P4
• DeepStream Version 5.1
@DaneLLL Hi I was looking out for adding FPS display for deepstream test apps that are in c++ and came across the below post and got the solution working and fps is displayed in the terminal log
Output in the terminal
Fps info: rendered: 20, dropped: 0, current: 39.67, average: 39.67
Fps info: rendered: 40, dropped: 0, current: 38.32, average: 38.98
Fps info: rendered: 58, dropped: 0, current: 34.70, average: 37.54
Fps info: rendered: 77, dropped: 0, current: 36.09, average: 37.18
Fps info: rendered: 97, dropped: 0, current: 36.44, average: 37.02
Fps info: rendered: 117, dropped: 0, current: 38.77, average: 37.31
Fps info: rendered: 134, dropped: 0, current: 33.34, average: 36.75
Here the video, Im running it over a video file that has a fps of 25 frames/sec.
But while I run the video after adding the code block provided in the solution post, the video frames are faster.
Is there any way/method to fix this issue. Please advice
