hwang4
August 27, 2024, 3:57pm
1
Hardware: TX2
Software: L4T 32.7.4
PowerMode: MAXN, all VI/ISP/NVCSI clocks maxed out
I am running 3 pipelines for 3 image sensors.
Pipeline1:
Sensor1(4k@30) ->nvarguscamerasrc → tee
|-> nvvideoconvert(1280x720) → nvv4l2h264enc → h264parse → rtph264pay → udpsink
|-> nvvideoconvert → jpegenc → multifilesink (ondemand)
|-> nvstreammux → nvvideoconvert ->nvinfer → nvtracker → nvdsanalytics → …
|-> nvvideoconvert → clockoverlay → nvvideoconvert → nvv4l2h264enc → h264parse → splitmuxsink
Pipeline 2&3:
Sensor2/3(4k@30) ->nvarguscamerasrc → tee
Problem description:
When I have all three pipelines running, I noticed frames dropped in the JPEG branch by the discontinuity of the frame number in the metadata. in the order of 2~3 frames per second.
If I stop either of pipeline 2 or 3, the remaining two pipelines would stop having such issue.
If I stop the nvinfer branch or h264 branch in the first pipeline, the frame drop would also go away.
When frame drop happens: I noticed high VIC load(always ~99%)
RAM 3845/7849MB (lfb 185x4MB) SWAP 0/3924MB (cached 0MB) CPU [57%@2031 ,0%@1728 ,0%@1728 ,56%@2029 ,59%@2028 ,57%@2026 ] EMC_FREQ 35%@1866 GR3D_FREQ 46%@1300 NVENC 345 VIC_FREQ 99%@1024 APE 150 MTS fg 0% bg 0% PLL@58C MCPU@58C PMIC@50C Tboard@51C GPU@58C BCPU@58C thermal@58C Tdiode@55C VDD_SYS_GPU 1410/1410 VDD_SYS_SOC 4569/4569 VDD_4V0_WIFI 38/38 VDD_IN 11348/11348 VDD_SYS_CPU 1459/1459 VDD_SYS_DDR 2913/2913
When I kill pipeline 2 or 3, VIC load drops to 60~90%. So this appears to be correlated with VIC load.
Question:
How can I be sure this is really caused by VIC overload?
If so, how can I mitigate this issue?
Hi @hwang4
I have a couple of suggestions:
Could you try adding maxperf-enable=1 to the nvv4l2h264enc instances?
Could you try adding queue elements before and after each tee (on both branches)?
Regards,
Enrique Ramirez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
hwang4
August 27, 2024, 11:39pm
4
Thanks for the reply, Enrique.
I already have queue before/after the tee.
I tried the maxperf-enable, it’s not making any difference.
hwang4
August 27, 2024, 11:42pm
5
I made some changes to only enable the RTSP branch when there’s active session.
That appears to fix the problem for now; but still would like to know if VIC is the bottleneck and how we can potentially improve the max performance.
It looks like the VIC could be the bottleneck. I see multiple nvvidconv, could you try using the nvjpegenc instead of “nvvideoconvert + jpegenc”?
Regards,
-Enrique
hwang4
August 30, 2024, 4:00pm
7
Thanks gain, Enrique.
I have changed jpegenc to nvjpegenc. that should help a little.
However this pipeline will cause segmentation fault.
gst-launch-1.0 nvarguscamerasrc bufapi-version=1 num-buffers=1 ! nvjpegenc ! filesink location=/tmp/test.jpg
If I change to old api: bufapi-version=0 it will work fine.
So the nvjpegenc is not compatible with new buffer API, but I didn’t see this mentioned anywhere.
hello hwang4,
did you work with DeepStream SDK? it’s due to nvjpegenc is not a DeepStream plugin.
Or, you may use software encoder to encode mjpeg with nvvideoconvert.
$ gst-launch-1.0 -e nvarguscamerasrc bufapi-version=true ... ! nvvideoconvert ! 'video/x-raw, format=(string)NV12, width=1920, height=1080, framerate=30/1' ! jpegenc ! filesink location=file.mjpeg
Or… you can encode H264 or H265 streams with the pipeline:
$ gst-launch-1.0 -e nvarguscamerasrc bufapi-version=true ... ! nvvideoconvert ! queue ! nvv4l2h264enc ! h264parse ! filesink location=file.264
hwang4
September 3, 2024, 4:11pm
9
Thanks for the reply, Jerry.
I did see the note that nvv4l2jpegenc is not compatible with DeepStream SDK. However in such a simple pipeline, only other plugin is nvarguscamerasrc, and I thought it’s not part of deepstream, but l4t-camera, right?
hello hwang4,
nvarguscamerasrc it’s only plugins.
you may see-also deepstream samples, i.e. /opt/nvidia/deepstream/deepstream/samples/
system
Closed
October 9, 2024, 2:56am
12
