fTPM provisioning fails with "Invalid provision mode!" on Jetson Orin (JP-6.2.2)
Environment
  • Device: reComputer Industrial Orin J401
  • JetPack: 6.2.2 (L4T R36.5.0)
  • OP-TEE: fTPM feature enabled
Issue Summary
fTPM device provisioning fails with “Invalid provision mode!” error when running ftpm_device_provision.sh. The TEEC_InvokeCommand returns error code 0xffff000a origin 0x4.
Steps Taken
  1. In addition to the procedure being carried out in Topic367455,
    I performed the following steps to enable the fTPM EK verification function:
  2. Re-flashed the device
  3. After boot, executed the fTPM provisioning script
Expected vs Actual Behavior
Expected:
fTPM provisioning completes successfully with both RSA and ECC EK certificates created.
Actual:
  • Provisioning fails with “Invalid provision mode!”
  • Only RSA_EK_HANDLE (0x81010001) is registered
  • ECC_EK_HANDLE (0x81010002) is not registered
Error Output
Provisioning script error:
root@test-desktop:/home/test/Documents/ftpm_prov# sudo ./ftpm_device_provision.sh -r ek_cert_rsa.der -e ek_cert_ec.der -p owner
[fTPM device]: === fTPM device provisioning ===
[fTPM device]: === Extracting the EK Certs from EKB ===
ca_query_prov_mode: TEEC_InvokeCommand failed 0xffff000a origin 0x4
Could not open file or uri for loading certificate from ek_cert_rsa.der
2030B0A5FFFF0000:error:16000069:STORE routines:ossl_store_get0_loader_int:unregistered scheme:../crypto/store/store_register.c:237:scheme=file
2030B0A5FFFF0000:error:80000002:system library:file_open:No such file or directory:../providers/implementations/storemgmt/file_store.c:267:calling stat(ek_cert_rsa.der)
Unable to load certificate
[ftpm device]: fTPM provisioning failed.
Current TPM State
After the failed provisioning attempt, I verified the TPM state:
Summary:
  • ✅ RSA_EK_HANDLE (0x81010001): Present and functional
  • ❌ ECC_EK_HANDLE (0x81010002): Not registered
  • ❌ No NV indices found
Checking TPM handles:
root@test-desktop:~# tpm2_getcap handles-persistent -T device:/dev/tpmrm0
- 0x81010001
root@test-desktop:~# tpm2_getcap handles-nv-index -T device:/dev/tpmrm0
RSA EK public key details:
root@test-desktop:~# tpm2_readpublic -c 0x81010001 -f pem -o ekPub.pem
qualified name: 000b71e8069ad0efaebb07333d567bb6e75fbe7f3863ba698e4eae6826d7aa151118
name-alg:
  value: sha256
  raw: 0xb
attributes:
  value: fixedtpm|fixedparent|sensitivedataorigin|adminwithpolicy|restricted|decrypt
  raw: 0x300b2
type:
  value: rsa
  raw: 0x1
exponent: 65537
bits: 2048
scheme:
  value: null
  raw: 0x10
scheme-halg:
  value: (null)
  raw: 0x0
sym-alg:
  value: aes
  raw: 0x6
sym-mode:
  value: cfb
  raw: 0x43
sym-keybits: 128
rsa: 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
authorization policy: 837197674484b3f81a90cc8d46a5d724fd52d76e06520b64f2a1da1b331469aa
Exported public key:
root@test-desktop:~# cat ekPub.pem
-----BEGIN PUBLIC KEY-----
MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAwvD3Rk5GWa3y4a7o5TO8
nafpCViAC+Xsf4MhBsdUCz9aSgf9HEU14zFhX5fuw7l5z8K0JR52cODz0ruiqUAB
/XlsLVJVVsMxJbxpHBmHkQCu0A+8f3i5Wehau6UgpP3pkHkGlFTlbk9y1rc5b1C/
mi35ZMJYydOLJXiV9cmRNiYLxtHPVNt/olIOop+tEsqWNJyoCOIZWv23LdpErLre
ktXViKwrt4M8FDjDyC1o/3bLkslsAWlmptw3rQZ/rr5nWJ5kFOrKOFdvJzg+RRFs
cN8gwz+Qaho+ZcUJb3UofnOIBY3tG+wMr+/G24XDVd1MqmnlvTtpJ6mEIV5puVhp
tQIDAQAB
-----END PUBLIC KEY-----
Questions
  1. What does the “Invalid provision mode!” error indicate, and how can I resolve it?
  2. Why is the ECC_EK_HANDLE (0x81010002) missing after flashing?
  3. Are there any missing prerequisites or configuration steps?
Any insights would be greatly appreciated!
hello mori.ycb.c2,
may I know all your key combinations, did you also enable UEFI payload encryption (--uefi-enc) on fused Orin-NX?
could you please also share the bootloader logs for cross check.
BTW,
we’ve tested fTPM, please refer to Topic 353623 for some crucial steps.
hello JerryChang,
may I know all your key combinations, did you also enable UEFI payload encryption (–uefi-enc) on fused Orin-NX?
Based on the information from the cheat sheet below, I’d like to share these details with you.
Could you please verify whether this information fully covers the key combinations and the UEFI payload encryption status?
UPI Image Generation (aka User Partition Image: UPI)
Note
In the commands below, the key in --uefi-enc <key> option is used for UEFI payload encryption. This key value is the sym_t234.key defined and added into the EKB by the OEM.
The OEM EKB generation specifies --in_sym_key ~/JETSONNX/oem-keys/sym_t234.key:
~/JETSONNX/Linux_for_Tegra/source/optee/samples/ftpm-helper/host/tool$ ./oem_ekb_gen.py \
-oem_k1_key ~/JETSONNX/oem-keys/OemK1.key \
-in_sym_key ~/JETSONNX/oem-keys/sym_t234.key \
-in_sym_key2 ~/JETSONNX/oem-keys/sym2_t234.key \
-in_auth_key ~/JETSONNX/oem-keys/auth_t234.key \
-in_ftpm_odm_ekb odm_out
For flashing specifies --uefi-enc ~/JETSONNX/oem-keys/sym_t234.key:
sudo BOARDID=3767 FAB=301 BOARDSKU=0000 CHIP_SKU=00:00:00:D3 RAMCODE_ID=1 ./tools/kernel_flash/l4t_initrd_flash.sh \
--external-device nvme0n1p1 \
-u ~/JETSONNX/odm-keys/rsa3k.pem \
-v ~/JETSONNX/odm-keys/sbk-32.key \
--uefi-keys ~/JETSONNX/oem-keys/uefi-keys/uefi_keys.conf \
--uefi-enc ~/JETSONNX/oem-keys/sym_t234.key \
-c tools/kernel_flash/flash_l4t_t234_nvme.xml \
-p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
--showlogs \
--network usb0 \
recomputer-industrial-orin-j401 internal
Will dmesg logs suffice? I will attach them.
dmesg.log (74.0 KB)
hello JerryChang,
Is the key combination for UEFI payload encryption (–uefi-enc) correct?
If there are any other additional information or feedback, sharing it would be greatly appreciated.
hello mori.ycb.c2,
unfortunately, we will need bootloader logs for cross check.
please setup serial console to gather the details.
