I’d be happy to help you with your questions about provisioning fTPM on the Jetson device.
1. Generating the fTPM EK CSR
The diagram you mentioned is likely referring to a tool that generates the Endorsement Key (EK) Certificate Signing Request (CSR). Unfortunately, the provided documentation does not explicitly mention a specific tool for generating the EK CSR.
However, based on the context, I can provide some guidance. The EK CSR is typically generated using a tool that creates a certificate signing request for the EK certificate. This tool is usually provided by the TPM manufacturer or the platform vendor (in this case, NVIDIA).
After reviewing the documentation, I found a mention of the tpm2-tools package, which is a collection of tools for working with TPM2 devices, including the fTPM. One of the tools in this package is tpm2_createek, which can be used to create an EK CSR.
To generate the EK CSR using tpm2_createek, you can follow these steps:
- Install the
tpm2-tools package on your system.
- Run the following command to create an EK CSR:
tpm2_createek -c <EK_CSR_FILE> -g <EK_CSR_GENERATION_PARAMS>
Replace <EK_CSR_FILE> with the desired output file name for the EK CSR, and <EK_CSR_GENERATION_PARAMS> with the generation parameters for the EK CSR (e.g., -g sha256 for SHA-256).
Please note that you may need to consult the tpm2-tools documentation for more information on the available options and parameters for the tpm2_createek command.
If you are unable to find the tpm2_createek tool or need further assistance, I recommend reaching out to NVIDIA support or the Jetson developer community for more guidance.
Additional notes
- Make sure you have the necessary dependencies and tools installed on your system before attempting to generate the EK CSR.
- The EK CSR generation process may require additional parameters or configuration files, depending on your specific use case and requirements.
- If you are using a different tool or process to generate the EK CSR, please provide more information about the tool or process, and I’ll do my best to assist you.
I hope this helps! If you have any further questions or concerns, feel free to ask.
