How does fTPM generate or derive the Storage Root Key?
The fTPM (firmware-based Trusted Platform Module) on the Jetson Orin NX series generates or derives the Storage Root Key (SRK) through a key derivation process that relies on the secure boot mechanism. Here’s a step-by-step explanation of how fTPM generates the SRK:
In comparison to other Jetson modules, the key derivation process for the SRK is similar. However, the specific implementation details may vary depending on the module and the secure boot mechanism used.
For example, on the Jetson AGX Orin series, the SRK is derived using a similar key derivation process, but with some differences in the specific implementation details.
Here’s a comparison of the key derivation process for the SRK on different Jetson modules:
| Module | Key Derivation Process |
| Jetson Orin NX | Uses Silicon ID (SID) and OEM public key to derive SRK |
| Jetson AGX Orin | Uses Silicon ID (SID) and OEM public key to derive SRK, with some differences in implementation details |
| Jetson Orin Nano | Uses a similar key derivation process, but with some differences in implementation details |
In summary, the fTPM on the Jetson Orin NX series generates the SRK through a key derivation process that relies on the secure boot mechanism, using the Silicon ID (SID) and OEM public key. The specific implementation details may vary depending on the module and the secure boot mechanism used.
