I finally managed to start the full moonshotai/Kimi-K3 on 16x GB10 cluster, on a MikroTik Switch CRS804-4DDQ with 4x 400-to-4x100gbit breakout cables running with dspark runing on coherent corpus llama-benchy at 21t/s avg and 38t/s peak, 750tps prefill, as first try with dspark enabled using Inferact/Kimi-K3-DSpark. looking forward to improving this. I’ll be adding image and instructions to git soon:
Very nice @ciprianveg ! On the the whole DGX Station vs DGX Spark - advantage of the Spark, I still think is flexibility. You can go anywhere from serving on 1 to 16 nodes, and have power usage advantages that way. Also, the amount of memory :) Great solution if you mostly do batch work.
Question: Do you think performance will be better with pp=2, tp=8?
Amazing work and looking very much forward to your git. We will try and run it on our 16x Spark cluster and report back our findings and potential improvements.
Are you planning on adding dcp support? How much wiggle room do you have left for ctx / kvcache?
