Hi, all.
I’m a beginner cuDNN developer and I’m trying to fuse operators for inference.
When going through the documentation (Developer Guide :: NVIDIA Deep Learning cuDNN Documentation), I learned that this might be done by using backend API. (Please correct me if I’m wrong. I’m not 100% sure because the “seem-to-be” relevant functions are in training library.)
Although this post provides a good high-level overview, I’m still not sure how to actually implement operator fusion.
For example, it seems like the following functions might be necessary.
cudnnCreateFusedOpsPlan()
cudnnCreateFusedOpsVariantParamPack()
cudnnCreateFusedOpsConstParamPack()
cudnnMakeFusedOpsPlan()
cudnnFusedOpsExecute()
Are these sufficient enough to get the right results?
Also, I’m not sure how to pass the input/output tensor information and detailed parameters for convolution, relu, etc.
I went through cuDNN sample codes to find the code example but unfortunately, I had no luck.
If anyone can provide any hint/feedback/idea/code sample, that will be greatly helpful.
Finally :) Thank you so much!
This is exactly what I’ve been looking for.
One quick question.
Say we provided operations we want to fuse.
Do we have guarantee that all of them will be fused? Or does the engine perform some kind of pattern matching and try its best?
For example, if we provide (conv, batchnorm, relu, add),
I’m wondering if only conv+batchnorm+relu but leave add alone since the engine only supports fused operation for conv+batchnrom+relu.
Because batchnorm involves several reductions and broadcasts across multiple cuda blocks, currently it cannot be fused as a whole into the end of a convolution.
For more details on supported fusion combinations in v8.1.0, refer to our release notes: https://docs.nvidia.com/deeplearning/cudnn/release-notes/rel_8.html#rel-810
If a pattern is within the support, we’ll fuse everything into one kernel.
Note we’ll keep adding support to more things as we develop, so we may support a different way of fusing BN into conv in a future release.
With runtime op fusion, the engine can generate and compile fused tensor-core kernels on the fly for the specified operation graph during the execution plan finalization stage. Some of the operation graph patterns supported in this preview are: convolution or matrix multiplication operation with arbitrary combination of one or more pointwise operations, and reduction operations fused onto the output tensor.
Although this gives a high-level idea of the supported patterns, I want more guarantee that all the operations I provide are fused.
Is there any way to check whether all operations are successfully fused?
If there is not, I’m wondering if there is a complete set of supported patterns.
Thank you so much for your help. It is a great help!
Our engineers has been working on the documentation. In the mean time, you can refer to the recent release notes for fusion support https://docs.nvidia.com/deeplearning/cudnn/release-notes/rel_8.html#rel-811
We have also released a new version of C++ frontend that includes a bunch of fusion samples - we recommend you to try it out
