Fused Orin NX R36.4.4 -> R36.5 bootloader-only OTA capsule hard-hangs before Linux
We are debugging a secure/fused Jetson Orin NX product on a custom carrier. The
unit full-flashes successfully through APX/initrd and writes QSPI/rootfs
normally. Same-BSP secure R36.5 → R36.5 full OTA with a bootloader capsule also
succeeds. The remaining failure is specifically the cross-BSP secure bootloader
move from Jetson Linux R36.4.4 to R36.5.0.
We understand custom-carrier support boundaries. The reason we are asking here
is that the same hardware full-flashes, boots both BSP rootfs states, and accepts
same-BSP secure capsules; the failure appears only when R36.4.4 firmware
processes an R36.5 bootloader payload.
The strongest reproduction uses NVIDIA OTA tooling directly:
Clean R36.4.4 secure bootloader/QSPI and R36.4.4 rootfs, A/A slots
NVIDIA image-based OTA bootloader-only payload generated for R36.4.4 → R36.5
nv_ota_start.sh stages TEGRA_BL.Cap successfully
reboot hard-hangs before Linux/USB/APX
Primary question:
Is an R36.4.4 UEFI/FMP path expected to consume an R36.5.0 bootloader-only
capsule/BUP on a fused Orin NX from a clean R36.4.4 system, or must
R36.4.4 → R36.5.0 be performed as a full NVIDIA image-based OTA transaction
with rootfs and bootloader movement owned together by NVIDIA OTA tooling?
Context:
Module: Jetson Orin NX / P3767-0000 class
Carrier: custom carrier
Security: fused secure boot, PKC/SBK boot-chain signing, UEFI capsule auth
Base BSP: Jetson Linux R36.4.4
Target BSP: Jetson Linux R36.5.0
Storage: external NVMe, rootfs A/B, encrypted rootfs, encrypted data/UDA,
read-only rootfs
OTA tooling in the discriminator: NVIDIA ota_tools_r36.5.0_aarch64.tbz2,
nv_ota_start.sh, bootloader-only ota_payload_package.tar.gz
Known-good controls:
  1. Secure APX/initrd full flash works repeatedly on this exact hardware and
    returns the unit to R36.4.4 with clean ESRT.
  2. The direct official OTA failure below starts from clean R36.4.4 rootfs and
    R36.4.4 bootloader, both A/A, with clean ESRT.
  3. Same-BSP secure R36.5 → R36.5 full OTA with a bootloader capsule works on
    the same device family. The target rootfs and bootloader slot boot, ESRT
    reports success, and the update completes.
  4. Non-secure full OTA with capsule is proven separately.
  5. Updating ESP contents to R36.5 is not sufficient. R36.4.4 firmware can boot
    normally with R36.5 ESP contents when no capsule is staged, but still hangs
    when the R36.5 bootloader capsule is staged.
  6. NVIDIA’s DA-12672 Orin QSPI MB1-BCT overlay was checked against the current
    R36.5 generated inputs and payloads; the relevant trimmer2-val setting is
    already present.
Official OTA discriminator:
Direct clean-R36.4.4 negative control:
A p3509-native BUP was not selected at first because R36.4.4 reported the
generic compatible spec:
  COMPATIBLE_SPEC=3767-000-0000--1--p3509-a02-p3767-0000-
The payload had exact p3509 entries, so nv_ota_start.sh stopped before
staging with:
  No image is found for compatible SPEC 3767-000-0000-
Direct clean-R36.4.4 important failure:
We reran with the compatible spec overridden to the exact p3509 target:
  3767-301-0000-G.1-1-0-p3509-a02-p3767-0000-nvme0n1p1
nv_ota_start.sh then selected the BUP, returned success, staged:
  /boot/efi/EFI/UpdateCapsule/TEGRA_BL.Cap size=11069002
and rebooted. The device hard-hung for the full monitor window before
Linux/USB/APX. A normal APX-off power cycle also did not recover it. Recovery
required forced APX and full flash.
Earlier post-rootfs-hop negative control:
We first staged a payload whose wrapper board_name was adjusted to
p3509-a02-p3767-0000, but whose BUP table still contained
jetson-orin-nano-devkit entries. nv_ota_start.sh staged the capsule and
rebooted. Linux returned, bootloader stayed R36.4.4, and ESRT showed:
  last_attempt_status=6151
  last_attempt_version=0
We treat that as a clean bad-target rejection.
Earlier post-rootfs-hop failure:
We then generated a p3509-native bootloader-only BUP whose entries are
The capsule wrapper metadata was:
  FwVersion=0x00240500
  LowestSupportedVersion=0x00240404
Payload identifiers:
  ota_payload_package.tar.gz sha256=9f1bb6426788b5e70cbb2c8407afe9cd33cb8fbd8921035b6daeaa9bb3575804
  TEGRA_BL.Cap sha256=b00f9cf86ea6c5ff24ab1589dd1dd37d77c81bd2774d9aa5b59c46271fc6e8bc
nv_ota_start.sh returned success and staged the capsule under the ESP update
capsule directory. On reboot the device hard-hung before Linux/USB/APX. We
recovered only by forcing APX and performing a full flash. The later
clean-R36.4.4 result above shows this is not only a mixed-rootfs-state
problem.
Pre-reboot state captured on the equivalent real update path:
OsIndications=0x4 was set with efivar -w
BootChainFwNext was absent
BootChainFwStatus was absent
ESRT before reboot was clean:
fw_version=2360324
lowest_supported_fw_version=2360324
last_attempt_status=0
What we have already ruled out:
Rootfs extraction/write failure: rootfs-only secure update works and completes.
Generic A/B rollback issue: same-BSP secure OTA with capsule works.
Capsule wrapper auth as the only issue: same-BSP secure capsule works with the
trusted wrapper path; cross-BSP still fails.
ESP freshness as the only issue: both ESP partitions were updated to R36.5 and
no-capsule boot worked, but cross-BSP capsule still hung.
FmpCapsuleSinglePartitionChain=0 as a quick fix: still hung.
Missing DA-12672 QSPI MB1-BCT overlay: audited and present.
Stale BootChainFwNext: absent before the failing reboot.
Focused questions:
  1. Is R36.4.4 UEFI/FMP expected to apply an R36.5.0 bootloader-only capsule/BUP
    on fused Orin NX from a clean R36.4.4 system, or is the supported
    R36.4.4 → R36.5.0 path only a full NVIDIA image-based OTA transaction?
  2. Should R36.4.4 report the generic compatible spec above on this module, and
    should a valid R36.4.4 → R36.5 p3509 payload use generic or exact BUP
    entries for matching?
  3. Are there required BR-BCT, ratchet, rollback, or BootChain variables beyond
    staging TEGRA_BL.Cap and setting OsIndications=0x4?
  4. Is overriding COMPATIBLE_SPEC to the exact p3509 target a valid diagnostic,
    or does that bypass an important NVIDIA compatibility guard?
  5. What firmware logs or UEFI debug switches can capture failures before Linux
    when UART capture is empty and the unit does not return to ESRT?
  6. Is AutoUpdateBrBct required for this R36.4.4 → R36.5 secure transition?
    If yes, how should it be set when it appears boot-service/nonvolatile only
    and cannot be written from Linux runtime with efivar?
  7. What exactly does ESRT last_attempt_status=6151 mean for Jetson FMP in
    R36.4.4 when the BUP target is wrong?
  8. Is /dev/mtdblock0 expected to be available from Linux on secure Orin NX
    R36.5 for nv_bootloader_payload_updater, or is that helper not intended for
    this production layout?
  9. For bootloader-only l4t_generate_ota_package.sh -b, which inputs are
    mandatory on external NVMe + rootfs A/B + encrypted rootfs/UDA + UEFI secure
    boot? Should bootloader-only mode still include rootfs UUIDs, UDA UUID,
    disk encryption key, ROOTFS_AB=1, ROOTFS_ENC=1, --uefi-keys, --uefi-enc,
    and exact custom-board spec entries?
  10. If NVIDIA image-based OTA must own rootfs and bootloader movement together,
    what is the recommended migration shape for a production fleet currently
    on R36.4.4 with an existing rootfs A/B update client?
We can provide redacted l4t_generate_ota_package.sh logs, BUP table summaries,
FMP metadata, nv_ota_start.sh logs, pre-reboot ESRT/nvbootctrl/efivars,
post-recovery ESRT/slot state, and full-flash success logs.
hello 997paul,
may I double check.. p3509 is the name of the Jetson Xavier NX Developer Kit.
please aware there’s a footnote according to Jetson FAQ | NVIDIA Developer
let me re-cap as below..
†† Jetson Orin NX & Jetson Orin Nano series modules are not pin-compatible with Jetson Xavier NX series modules, but you can design a carrier board for the I/Os they have in common, such that both modules are supported.
it’s suggest to update l4t_generate_ota_package.sh and ota_board_specs.conf for customize board to create OTA payloads.
see-also Topic 332980 for an example, please update CUSTOMIZE_JETSON , and customize-jetson to your board name accordingly.
last_attempt_status=6151 that case looks like BUP target/image mismatch.
please confirm whether the OTA package contains entries matching the device’s actual /etc/nv_boot_control.conf TNSPEC and COMPATIBLE_SPEC, and provide the BUP table/image list.
BTW,
did you also test the full NVIDIA image-based OTA flow instead of bootloader-only update?
Thanks Jerry.
On p3509: understood. In our case the name comes from the NVIDIA p3509-a02+p3767-0000 Orin NX config path we derived from. The module is Orin NX / P3767 on a custom carrier, so I agree the custom-board ota_board_specs.conf path is the right area to audit.
From a clean R36.4.4 recovery flash, the device reports:
/etc/nv_boot_control.conf:
TNSPEC 3767-301-0000-G.1-1-0-p3509-a02-p3767-0000-nvme0n1p1
COMPATIBLE_SPEC 3767-000-0000–1–p3509-a02-p3767-0000-
UEFI efivars:
TegraPlatformSpec=3767-301-0000-G.1-1-0-p3509-a02-p3767-0000-
TegraPlatformCompatSpec=3767-000-0000–1–p3509-a02-p3767-0000-
EEPROM/device-tree:
partnumber[nvidia]: 699-13767-0000-301 G.1
/proc/device-tree/chosen/ids: 3767-0000-301
/proc/device-tree/chosen/nvidia,sku: 699-13767-0000-301 G.1
So fab 301 is real device state. EEPROM, device tree, and the UEFI efivars agree. The host-side override only made payload selection agree with that device state; the anomaly is that COMPATIBLE_SPEC generation gives the generic 3767-000-0000- string.
Agreed on 6151: that payload had non-matching devkit entries and returned cleanly to Linux. I am treating that as a bad-target BUP case, not the main failure.
The main case I am trying to understand is different. A p3509-native R36.5 bootloader-only payload has:
30 BUP entries
entries carry either exact TNSPEC 3767-301-0000-G.1-1-0-p3509-a02-p3767-0000- or blank TNSPEC
BCT-boot-chain_backup present, update_mode=2, size=32768
Example entries:
BCT, BCT_A, BCT_B, mb1: update_mode=2
MB1_BCT, MEM_BCT, mb2, cpu-bootloader: update_mode=0
BCT-boot-chain_backup: update_mode=2
This p3509-native bootloader-only payload stages successfully. On the capsule reboot, the unit does not reach Linux or USB gadget. Recovery requires forced RCM/APX and a full reflash.
Controls that may help narrow this down:
  • Secure APX/initrd full flash works on this hardware.
  • Same-BSP R36.5 → R36.5 secure full OTA with a bootloader capsule works on this unit/class: target rootfs and bootloader slot boot, ESRT reports success, and the update completes.
  • A same-version R36.4.4 control capsule has returned ESRT success.
  • Updating the ESP contents to R36.5 is not sufficient by itself. R36.4.4 firmware can boot normally with R36.5 ESP contents when no capsule is staged, but still hangs when the R36.5 bootloader capsule is staged.
  • A BUP-table comparison across the passing R36.4.4 control, a R36.4.4-era failing diagnostic, the current R36.5 payload, and the p3509-native official R36.5 payload shows that table shape alone does not explain the outcome.
We also checked the full NVIDIA image-based OTA path. A full-system p3509 package with update_control containing both bootloader and rootfs was generated. It only selected the p3509 images when the target compatible spec was overridden to the exact device TNSPEC. Without that override, the device’s generic COMPATIBLE_SPEC selected 3767-000-0000- and no image was found.
That full-system flow did not reach capsule handoff on our current partition layout. The stock updater expects the inactive encrypted rootfs as APP_ENC_b plus separate boot partition handling. This layout has APP/APP_b as ext4 boot/container partitions, with the encrypted rootfs as a loop-LUKS file inside the container. I did not force the stock updater through that mismatch because it would no longer be a clean stock NVIDIA image-based OTA test.
What I am trying to pin down is:
  1. Is bootloader-only R36.4.4 → R36.5 capsule update expected to work on a fused Orin NX with PKC/SBK signing and UEFI capsule authentication enabled, when the BUP table matches the live TegraPlatformSpec? If yes, what preconditions should we verify before staging it?
  2. If bootloader-only cross-release update is not a supported path, what is the expected supported path for a product layout that cannot use the stock APP_ENC/APP_ENC_b rootfs updater directly? Is the intended approach to provide a custom rootfs updater while preserving the standard NVIDIA bootloader capsule handoff?
  3. For custom-board BUP matching, should ota_board_specs.conf generate entries for the exact TegraPlatformSpec, the generic TegraPlatformCompatSpec, or both? And is a generic COMPATIBLE_SPEC of 3767-000-0000–1–… expected on a fab-301 module?
I can provide redacted BUP tables and nv_ota_start logs if useful.
hello 997paul,
please aware there’s package update, you should work with the latest.. OTA Tools r36.5 (updated on 5/22).
please add a real custom board name instead of using inherited p3509 identity.
you should setup serial console to gather complete bootloader logs since it’s hard-hangs before linux.
BTW,
we’ve tested with JP-6.1/r36.4.0 to confirmed OTA update success on fused Orin-Nano + RootfsA/B + disk encryption.
Hi Jerry, thank you for the replies. Our embedded engineers are continuing to debug. Presently we are still having issues with the capsule hop on fused Orin on our custom carrier, works non fused. Will report back when we have more logs and some questions if we don’t solve it.
Hey Jerry
Thanks. We went back through the controls and the post-hang QSPI readbacks. I
will try and be precise, because the useful split is not simply fused versus
non-fused.
Current matrix:
secure/fused R36.5 -> R36.5, our rootfs updater + NVIDIA FMP capsule: PASS
non-secure R36.4.4 -> R36.5, our rootfs updater + NVIDIA FMP capsule: PASS
secure/fused R36.4.4 -> R36.5, our rootfs updater + NVIDIA FMP capsule: FAIL
For the secure same-BSP control, the artifact used the same encrypted rootfs
wrapper shape as our release artifacts. The capsule was staged through the
normal FMP path by setting OsIndications; BootChainFwNext was absent. The
device booted B/B, ESRT reported last_attempt_status=0, / mounted from
/dev/mapper/cryptfs_rootfs read-only, /data mounted from
/dev/mapper/cryptfs_datafs, and a second reboot stayed healthy.
For the failing secure cross-BSP case, the starting point is a clean R36.4.4
legacy image on fused hardware. The R36.5 rootfs install completes, the capsule
is staged through OsIndications, and the device hangs before Linux/USB gadget
after reboot. We then force RCM/APX before recovery and read QSPI.
The new useful result is from a field diff of the QSPI readbacks:
case                    live BCT       BCT-boot-chain_backup    result
fullflash_aa             e9e149e0...    9fe59f56...              boots A/A
exact_capsule_hang       15403cf3...    9fe59f56...              hangs
direct_b_hang            15403cf3...    9fe59f56...              hangs
secure_twohop_hang       8cf3c5e8...    c29f558f...              hangs
secure_singlehop_hang    5a4281d0...    c29f558f...              hangs
same_bsp_bb_pass         336ee8c9...    c29f558f...              boots B/B
The exact_capsule_hang and direct_b_hang rows are diagnostic controls, not
normal release update paths. I am using them only to compare the state that was
left in QSPI after a hang.
Three points from that:
  1. The exact-full-flash capsule hang and a direct B-slot diagnostic hang have
    byte-identical live BCT and BCT-boot-chain_backup.
  2. The secure cross-BSP failures and the passing same-BSP B/B control share
    the same BCT-boot-chain_backup family, but they land on different live
    BCT values.
  3. The secure readbacks consistently decode these platform spec variables:
    TegraPlatformCompatSpec=3767-000-0000--1--p3509-a02-p3767-0000-
On the BUP/image-list point: I am treating the earlier 6151 case as a
separate bad-target/BUP-selection rejection. In the hangs we are focused on
now, capsule staging succeeds and post-hang QSPI shows the checked
boot-critical entries were written.
For the exact-full-flash-bytes diagnostic capsule, the BUP was generated from
already-signed full-flash files using the live device TNSPEC above. Extracting
that BUP matched the source files 30/30. After the hang, the checked A/B
boot-critical entries matched both the healthy full-flash baseline and the BUP
prefixes:
MB1_BCT, MEM_BCT, mb1, mb2, cpu-bootloader, secure-os, VER
BCT-boot-chain_backup also matched the full-flash baseline and the BUP
prefix. The checked differences versus the healthy full-flash baseline were
BCT and uefi_variables.
For the secure cross-BSP failures, the checked B-chain readback prefixes matched
the staged BUP for:
BCT_B, mb1, MB1_BCT, MEM_BCT, mb2, cpu-bootloader, secure-os,
BCT-boot-chain_backup, VER
So the remaining difference appears to be live BCT / BR-BCT / boot-chain
handoff state and related UEFI/FMP state, not an obviously missing
boot-critical partition write.
On your specific points:
  • We compared the 2026-05-22 ota_tools_R36.5.0_aarch64.tbz2 against the R36.5
    tools tree used in our proofs. The key runtime scripts match byte-for-byte.
    The only deliberate local differences are board/spec generation changes in
    l4t_generate_ota_package.sh and ota_board_specs.conf.
  • Agreed on the custom board name. We should not keep a p3509-derived product
    identity long term. For this debug pass we have kept the existing identity to
    avoid changing board identity and capsule behavior at the same time.
  • We attached UART during the secure hard-hang tests, but the captures were
    empty. Instead, we captured QSPI immediately after the hang via RCM/APX before
    recovery. If there is a specific way to increase MB1/MB2/UEFI capsule-reboot
    logging on a fused device, please point me at it.
We also checked the stock NVIDIA image-based OTA flow. A full-system package
with both bootloader and rootfs was generated. It did not reach capsule
handoff on our current legacy image. First, the runtime compatible spec reduced
to the generic 3767-000-0000- image key while the package contained the exact
3767-301-0000-G.1 image directory. After a diagnostic image-directory alias,
the stock updater then stopped in the rootfs/partition helpers.
That second stop is because our legacy image does not expose encrypted rootfs
as stock APP_ENC / APP_ENC_b partitions. It uses APP / APP_b as
container partitions with loop-LUKS rootfs files inside. The stock scripts
could not map /dev/mapper/cryptfs_rootfs back to the NVMe device and
APP_ENC model. I did not force the stock updater through that mismatch,
because at that point it would no longer be a clean NVIDIA stock image-based
OTA test.
My main questions now are:
    when the BUP/image entries match the live TegraPlatformSpec? If yes, what
    preconditions should we verify before staging the capsule?
  2. If the supported cross-release path relies on NVIDIA’s full image-based OTA
    sequence, which pre-capsule state changes does that sequence perform that a
    product-specific rootfs updater must preserve or reproduce before handing
    off to FMP?
  3. For custom-board BUP matching, should ota_board_specs.conf generate exact
    TegraPlatformSpec entries, generic TegraPlatformCompatSpec entries, or both?
    Is the generic compatible spec 3767-000-0000--1--... expected on a fab-301
    module?
  4. Is there a supported R36.5 Orin NX way to decode live BR-BCT/BCT boot-chain
    selector, fallback/reset/scratch state, and FMP BootChain state from QSPI
    readbacks on a fused device?
I have kept the raw artifacts out of this public thread. I do have a small
redacted QSPI field table packet with hashes, offsets, and parsed
boot/capsule variables only, if that would be useful.
hello 997paul,
please see-also Topic 310011 for OTA update on fused Orin-Nano.
besides..
may I also check your steps to generate OTA payload for running OTA update.
please have bootloader logs captured for cross-check.
Hi Jerry we found the issue in our generated secure boot package: the EKS/boot-firmware payload was not compatible with the legacy R36.4.4 secure state. Thank you for your help.
