Description
A clear and concise description of the bug or issue.
I want to gain more insight into a tensorrt engine, and it seems that creating an EngineInspector would do the trick. I load the model using runtime, and do engine.create_execution_context() but I would also like to do engine.create_engine_inspector() which should work, since the inspector works on ICudaEngine, according to ICudaEngine — NVIDIA TensorRT Standard Python API Documentation 8.4.3 documentation. But this doesn’t work, throws this error, inspector = engine.create_engine_inspector()
AttributeError: ‘tensorrt.tensorrt.ICudaEngine’ object has no attribute ‘create_engine_inspector’
Environment
8.0.1.6:
**Jetson Nano 4gb **:
Nvidia Driver Version:
10.4:
CUDNN Version:
Jetpack 4.6:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
