Garbage when reading from shared memory
Hello all,
Could any of you please run this code (see below) and check if there is any garbage in output? Judging from the kernel I expected ‘out’ array to be filled with ones; but on my OSX 10.6.2, Cuda 2.3, GF9400 for some reason ‘out’ contains some garbage numbers. If I change ‘lId / 2’ to ‘lId’, or decrease shared memory size along with thread number, bug disappears.
Example output:
$ make clean; make; release/test_cuda
nan
0: 1.000000
1: -165970779523315961984400771799580672.000000
2: -169949038053089037631926039430826033152.000000
3: -138290592331389744016850419712.000000
4: 35736483056626696192.000000
5: 2638969508086798374919131611799748608.000000
6: nan
7: -85049812401595674729494317898999529472.000000
8: nan
9: -0.000000
10: nan
11: -0.000000
12: 340280805175398982284751963493419188224.000000
13: -10382680480738939701846136061952000.000000
14: -1.468738
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
// includes, project
#include <cutil_inline.h>
extern "C"{
__global__ void test(float *out)
		float sMem[128];
		int lId = threadIdx.x;
	sMem[lId] = 1;
	__syncthreads();
	out[lId] = sMem[lId / 2];
int main( int argc, char** argv)
	if(cutCheckCmdLineFlag(argc, (const char**)argv, "device"))
		cutilDeviceInit(argc, argv);
	else
		cudaSetDevice(cutGetMaxGflopsDeviceId());
	int N = 128;
	float *h_out_buf = (float*)malloc(N * sizeof(float));
	float *d_out_buf;
	cutilSafeCall(cudaMalloc((void**)&d_out_buf, N * sizeof(float)));
	test<<<1, N>>>(d_out_buf);
	cutilCheckMsg("test");
	cutilSafeCall(cudaMemcpy(h_out_buf, d_out_buf, N * sizeof(float), cudaMemcpyDeviceToHost));
	float sum = 0;
	for(int i = 0; i < N; i++) sum += h_out_buf[i];
	printf("%f\n", sum);
	for(int i = 0; i < N; i++) printf("%d: %f\n", i, h_out_buf[i]);
	cutilSafeCall(cudaFree(d_out_buf));
	free(h_out_buf);
	cudaThreadExit();
that should be a shared float sMem[128], not a float sMem[128].
Yep, I’m so sorry ) Got carried away while reducing buggy code. The bug is still there, but the reproducing code is not so simple and the bug is reproduced only on PyCuda… but that’s offtopic for this forum, I suppose.
