Hello:
I’m trying to use CUBLAS 4.1 in a program and I’m a bit confused about a warning in the compilation proccess. I’m using this simple code (in a file called cublaswarn.c):
#include<cublas_v2.h>
int main()
double** a;
cudaMalloc((void**)a,10*sizeof(double));
cudaFree(a);
return 0;
As you can see, the program only allocates and deallocates memory.
If I compile with gcc 4.6.3 (from debian sid) as
gcc cublaswarn.c -o cublaswarn -lcublas
all runs OK
But if I compile with the options
gcc -std=c99 -Wnested-externs cublaswarn.c -o cublaswarn -lcublas
two warnings appears
cublaswarn.c: In function ‘main’:
cublaswarn.c:5:5: warning: implicit declaration of function ‘cudaMalloc’ [-Wimplicit-function-declaration]
cublaswarn.c:5:5: warning: nested extern declaration of ‘cudaMalloc’ [-Wnested-externs]
cublaswarn.c:6:5: warning: implicit declaration of function ‘cudaFree’ [-Wimplicit-function-declaration]
cublaswarn.c:6:5: warning: nested extern declaration of ‘cudaFree’ [-Wnested-externs]
I’ve searched in cublas_v2.h and in all the *.h files included the definitions of cudaMalloc() and cudaFree() but I didn’t find. I searched too the file cuda.h and I didn’t found the definitions.
The program runs, but I don’t understand where are the missing functions
Cheers
